Question about Vanguard International Blue Flame - Large Open Flame Mid-Size Heater
The Pilot will not light.There is gas coming through slowly
    Scholar:
  • 146 Answers
Start with cleaning the Pilot ODS assembly.
Try this link for general instructions:
http://www.msservice.net/ts/reseat_thermo-clean_pilot-ODS.htm
Thanks
Posted on Oct 08, 2010
Gas wall furnace pilot goes out when burner turns off.
When the main burner turns off, does it make a whoosh or pop? If so, this would be the issue causing the pilot to be disturbed. And have you tried to adjust the pilot/thermopile strength, if possible? A stronger pilot may help. Now if the main burner slowly goes out, and the pilot also slowly goes out, and also slow to ignite, and you've replaced about everything else, it may be the gas valve itself that has/is giving up. Gas is impure and causes a sticky residue. And if the main burner is "slow to act", this tells me the piston that's inside the valve is slowly opening or closing, and may be the reason the pilot is acting up. Make sure you check the outlet to your flue pipe also for obstructions. If the unit doesn't vent properly it can have more heat in the flue. That heat can have a downward rush when the burner goes out, kinda like forcing air through a clogged tube. And when you quit forcing the air, some of it comes back at you. Before condemning the valve try to check all else as you have done with the thermopile and such. Please work safe and I hope this helps.
Oct 09, 2017 | Williams Heating & Cooling
Vulcan Gas Heating Furnace Pilot Light Goes Off
Clean pilot may be too small blow out with tube or air line , thermocouple not working try changing it
May 19, 2012 | Heating & Cooling
Pilot light will not light
If your pilot on your gas water heater will not stay lit you need to take one step at a time.
Let's look at how you tried top light it. Turn the gas valve to the off position and then move it to the pilot position. If you can see inside under the heater and there is no glass view window you need to take a lighter or a match on an extended stick so the flame can sit right under the pilot tube. Push down on the red button and then the gas should light on the pilot burner. Hold the button down for a FULL 60 seconds.
Then slowly release the red button the main burner should then come on. Now if the pilot flame goes out right away as you're releasing the red button you have one or two more things you need to look at.
1st would be to replace the thermo coupling. You have to remove the whole burner tray to do that. If that does not work then the gas valve is bad and you need to replace it also. Make sure that when you buy a new gas valve you match up the gas type Natural gas to L P gas. They must match with the gas feeding your house or it will never work,
Thanks and best of luck
R J
Sep 08, 2011 | Rheem Water Heaters
The burners will not light. The pilot does light. I had my staff try to hit anything that looked a reset, but I don't know if the high limit switch has a reset or if the switch itself is bad.
The high limit switch has nothing to do with the pilot light, but will shut down the main burners. It the pilot light will not stay lit, then it is most likely the thermocouple. If the pilot light will not light at all, then gas is not reaching the pilot. Most likely, the pilot light tube is clogged with grease. When you push on the button to light the pilot, you are overriding all safeties inside the unit and sending gas to the pilot. Also make sure that the unit itself is getting gas. New regulations require a shut off within the hose that feeds the appliance which will shut off due to a surge of gas through the hose. To reset it, disconnect/reconnect the hose at the intake end and when you turn the gas back on, turn it on slowly.
Jun 11, 2011 | Pitco Frialator 35CS Deep Fryer
I have a Vulcan Gas wall furnace that is not working. We cannot work out how to light the pilot light. According to the documents we have it is a 26.4MJ model or the 40MJ model
The Quazar manual says....
-Thermostat control knob to 0
-Then press and hold down * (Star) button
-The press the "ignition" button one or more times until the pilot lights
CONTINUE to hold the * button for at least 15 seconds and release slowly making sure the pilot stays lighted.
-If the pilot goes out.. repeats steps above and hold the * button for much longer than 15 seconds and THEN release the * button slowly.
Kelly
May 06, 2011 | Heating & Cooling
How to light pilot light
Your gas valve has 3 positions. "OFF", "PILOT" and "ON". Turn it to "PILOT" and push it down hard. Hold it 2-4 seconds and light the pilot assembly. Keep holding it for 10-15 seconds and slowly let it up. The pilot should stay lit.
Mar 31, 2011 | Heating & Cooling
I have a Rheem gas furnace, model # RGAA-100C and need help lighting the pilot. The instructions on the metal plate tell me to set the valve to off, then to pilot, push the valve down until lit, and then...
Hi, follow what I say and it is very easy. The knob that says off, on, and pilot, is where you need to start. You don't want to turn it off now, as its been off for awhile now. Turn the knob slowly pushing down on it until you fill it go down. The knob will go down believe me. When this happens, keep holding it down as this is what starts the gas to the pilot which is back under the burner, under it. Just take a flash light and you can follow the aluminum tubing back and where it stops is where you light it with something long with a match in it or a small rolled up paper. Keep the knob down the whole time you are lighting it. When it lights, keep the knob pushed down for about another minute. Then slowly release the knob and the pilot should stay on. Once you have it on, turn the knob to on, not off. If you turn it the wrong way, it will go off and you will need to start over again. Once it stays on by itself, turn your thermostat up for heat and the burner will light and come on. Just remember that the pilot where you light it is where the tubing goes back under it, as the pilot gas goes through it. You will need a light. Look at the knob with a good light and it will tell you which way to turn it. In the pilot position, the knob will press down to let the pilot gas in, and you can reach back and light it. Then turn knob on. Pilot should stay light. Turn on thermostat and it will fire up. Let me know how it goes. You may have to try a couple of times.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Oct 05, 2010 | Heating & Cooling
Why does the pilot light keep going out?
Make sure your pilot flame is hitting the thermocoupler. If not then use air to clean pilot port and try again.
May 05, 2010 | Water Heaters
Laars Lite 2 Gas-Pilot stays on, but main burner shuts off 10 min
A polit generator produces about 750 MV without a load. Under load it will drop to about 200-250 MV. If the system is working don't worry about it. If the system is not working replace the pilot generator and retest. Pilot generators usually go bad slowly.
Jun 22, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
GE Spectra TrueTemp Oven Pilot is Out
REmove bottom panel from stove. shut gas off for at LEAST 5 min. Longer is better. Then placel open flame above gas nozzle, slowly turn to ignite posiiton. After it is lit, wait 30 seconds and turn to on positon.
If by chance this model doens't have a knob for this, then turn gas valve off for 5 min, let fumes evaporate, light flame, place over nozzle, turn gas on.replace bottom oven panel slowly.
Jan 18, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Vanguard International Blue Flame - Large Open Flame Mid-Size Heater Logo
90 people viewed this question
Top Vanguard Heating & Cooling Experts
Paul Carew
john h
Are you a Vanguard Heating and Cooling Expert? Answer questions, earn points and help others
