Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
F1 CODE ON FRIGIDAIRE CROWN. SELF CLEANING. CANNOT CANCEL IT.
5 Suggested Answers
  • 1314 Answers
SOURCE: Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
Posted on Jun 05, 2008
Krazytech
  • 725 Answers
SOURCE: frigidaire self cleaning convection range
Error code F1
1. Shorted keypad.
2. Control's internal checksum may have become corrupted.
3. Control has sensed a potential runaway oven condition. Control
may have shorted relay, RTD sensor probe may have gone bad.
1. Disconnect power, wait 30 seconds and reapply power. If fault returns
upon power-up, replace EOC.
2. Check RTD sensor probe and replace if necessary. If oven is
overheating, disconnect power. If oven continues to overheat when
the power is reapplied, replace EOC. Severe overheating may require
the entire oven to be replaced, should damage be extensive.
3. Replace EOC.
Check resistance at room temperature, if less than 500 ohms, replace
Temperature (°F) Resistance (ohms)
32 ± 1.9 1000 ± 4.0
75 ± 2.5 1091 ± 5.3
250 ± 4.4 1453 ± 8.9
350 ± 5.4 1654 ± 10.8
450 ± 6.9 1852 ± 13.5
550 ± 8.2 2047 ± 15.8
650 ± 9.6 2237 ± 18.5
900 ± 13.6 2697 ± 24.4
Hope it helps please let me know
Posted on Jun 12, 2008
Thank you tech17. It worked! My husband repeated your instructions just a couple of times and bingo - it unlocked. Thank you very much!
Posted on Jul 02, 2008
SOURCE: Frigidaire self clean electric stove 'f9' message
looking for lower element for Frigidaire ElectriClean Wall over
Posted on Nov 21, 2009
My oven is keep beeping and I can't cancel it
Good Morning Friend, that's a great question!
Typically error code F10 indicates that your Frigidaire range has detected an issue with the runaway temperature (overheating). Let's attempt reprogramming your range by either unplugging it or flipping the household circuit breaker off. It is best to wait roughly ten minutes and then turn on your range. Usually this will clear most false error codes. If issue persists, at this moment I would suggest contacting a professional to proceed further. Most likely the RTD Probe (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps! - Z
Aug 13, 2014 | Frigidaire Ovens
Fridgidaire self cleaning range: F1 error code?
You have a control board failure. First thing I would try is to unplug the range for at least 10 min. and then plug back in and see if that works. Hope that helps
May 29, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire flashing F1
Hello wills_amber - Typically, error code F1 indicates that the range has detected a runaway temperature issue (overheating). Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC (electronic oven control) on the range will need replacing.
Mar 21, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven displaying the f1 error code
You are experiencing a runaway temperature, or too hot of a temperature for the control board and sensors within the unit. When the unit gets this error code it shuts down for safety reasons. You would need a professional to diagnose the connections and control wiring to the control board, and the elements for safety.
Dec 30, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Self-Cleaning Oven Model FEF353BFW and F1 Error Code.
I just had the same problem! If I ever see that f9 again and hear that annoying constant beep....I will pick up and dispose of that oven on the front lawn. Lol. Took a pair of pliers and turned the lock clock wise till the light went out. Silence!
May 02, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
F1 ERROR
Hi. This (f-1) code represents a failed oven control board. Have this damaged board replaced asap, if possible. It has failed. Possible logic chip set failure.
Aug 22, 2009 | Frigidaire 30 in. Electric Gallery Series...
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
Frigidaire during cleaning F1 error,
F1 means its your electronic control and it will probably cost you the same amount to get this problem fixed again. The part is usually $350 plus.
Nov 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
176 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
