Question about Zebra 105Se Thermal Printer
We have a 105Se Zebra when it is printing in the middle of the bar code it does not print or is very light. We have cleaned the printhead and it still has the void on the barcode. We did notice a crack on the roller in the front of the machine, would this be causing the void on the barcode? If not any suggestions?
  • 96 Answers
Power off the printer and press and hold the pause key for 5 seconds while powering on the printer. This will start printing a bar across the width of the printhead. You should be able to determine whether it is a printhead issue or platen roller or both. Recycle power to exit diagnostics.
Posted on Oct 13, 2010
Darker printe for 105se printer
Enter the Setup Menu from control panel and modify the Darkness value. You have to increase the value and then Save the changes and exit the menu. On control panel Buttons you find the role of each button in the control panel. You can use the User Manual. There is an User Manual available for download from Zebra website. You will find there precious information. The manual is very explicit and you will learn how to maintain your printer and how to troubleshoot some common errors. Eventually clean your printer, assure to put the supplies on the right path, close the printhead and press Pause to enter in Ready state. You can try to tighten the 2 pressure screws from the top of the printhead assambly. This will bring the printhead surface closer to the platten roller. The screws can also be moved left and right and correct the wear of the platten roller.
Here is the link to the English version of User manual:
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/105sl-ug-en.pdf
Dec 05, 2013 | Zebra 105Se Thermal Printer
I have a Zebra 105Se zebra Printer for testing. When a label is printed it just prints 1/4th of the label,then the printer stops and paper/ribbon light,Pause light and data light is on.When I open the...
Make sure that both ribbon and media paths are clean (no glue, or sticked labels). Make shure the ribon and the media are corect installed on their paths.
Sep 23, 2011 | Zebra 105Se Thermal Printer
Have a Zebra 105SE that prints the FEED test just fine, but will not print the PAUSE test nor will it print a bar code label from the computer. The FEED test prints vertical bar codes while the PAUSE test...
Check to see if the pause light is on also. Make sure you are using the correct printer driver. (105se)
Try in ZPL and then try in ZPLII.
Check Delimiter character 2CH
Check Format prefix 5EH
Check Control prefix 7EH
Aug 24, 2010 | Zebra 105Se Thermal Printer
I have two printer and on one the label size comes out with the correct font size but when I try to print out the same label on the second one the bar code and human readable is much larger...am I missing...
Yes. You have two printers that have different "dots per inch" print heads. The printer with the correct size font is a 300dpi printer and the second one is a 203dpi printer. That's why the bar code and text is printing larger with the same code being sent to the first printer. The dots on the printhead are larger therefore, larger print.
Change the printer driver on the second printer to Z105SL-300 dpi and the print will be just fine.
Hope that helps !
Jun 15, 2010 | Zebra 105Se Thermal Printer
My Zebra 105SE is printing fine on the left
I think the 105 has an adjustment on the printhead. There are left and right hand adjusters just above the printhead. It sounds as if the right hand one does not have enough pressure on it, try increasing the RH one and see the effect on the print.
Jan 06, 2010 | Zebra 105Se Thermal Printer
Can I print in color with a Zebra 105se
Thermal printers don't have any 'color' of their own; the 'printed' text/numbers are actually only areas subjected to heat from the printhead which exposes the color of tiny beads of ink that are on the paper itself by melting them. Use a fingernail to 'score' the paper and you will see it change color just as happens in the printer.
Oct 14, 2009 | Zebra 105Se Thermal Printer
Our Zebra 105se printer has started missing labels. For ex., it will be printing a batch of 40 and every third or fourth label it shoots out an empty. sometimes it puts out two empty labels but in the end...
Clean your platen roller. It's the white rubber roller (that turns and pulls your labels through your printer) located under your printhead. When this gets slick it causes your labels to slip while printing.
You should use rubbing alcohol to clean it. Your computer guys may also have some cleaning wipes in a foil packet that you can use.
Jul 13, 2009 | Zebra 105Se Thermal Printer
Printing solid black across the label.
Sounds like a defective printhead.
Reinstall the old one to see if the problem remains or not.
Steve
Jun 25, 2008 | Zebra 105Se Thermal Printer
Zebra 105Se missing line
Try cleaning the thermal printhead. Zebra makes thermal printhead cleaners or you can use a qtip and some isopropyl alcohol.
Make sure the printer is turned off before doing this.
May 19, 2008 | Zebra 105Se Thermal Printer
Bar codes appear solid back
I have problem with the same printer, the bar code is not printed, someone can help me?
Apr 09, 2008 | Zebra 105Se Thermal Printer
Zebra 105Se Thermal Printer Logo
118 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
