Question about Garden
I have A LANDA PRESSURE WASHER (ZG3-2000) Problem is lack of pressure.
    Scholar:
  • 45 Answers
Because the ZG series uses a bolt on unloader it is a little difficult to properly test your machine. What you will need to do is completely remove the unloader valve and then hook your garden hose directly to the inlet of the pump (the 1/2" port on the bottom of the head). You then need to hook your high pressure hose to the outlet port (the 3/8" port on the top of the head). What you have done is bypassed the safety relief valve on the pump. Now you need to tie open the trigger on your trigger gun so that it can not shut. If it shuts while the machine is running you will damage your pump. Now fire up the machine. Let it run for a few seconds then shut it off.
If you had full pressure during this test you have a failed unloader valve and will need to replace it. If you did not your problem lies inside the pump and you will need to rebuild it. On a ZG you can expect the unloader to cost around $100 and the pump rebuild parts to be around $150. If you need further assistance or parts please feel free to contact me using the information below.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Posted on Feb 13, 2011
How do i fix a honda landa 3500 pressure washer, when the water doesn't come out when started?
Check out the trigger mechanism. Water should come out at any time, even when you do not have the unit started.
Aug 22, 2016 | Honda Landa PG 3500 PSI Pressure Washer
What type of pump oil does the landa pressure washer use
to get this answer it is simple , google landa pressure washers then look for your model number and that shall tell you the exact oil you need
Oct 08, 2014 | Garden
Need wiring diagram for the burner on. a Landa 5-3500 pressure washer
If you can provide the full model and serial from the model tag on the machine I would be happy to send you a wiring diagram. The model tag is normally located on either the frame of the equipment or on the side of the electrical panel. Depending you your model it should look something like the following.
Model: PGHW5-35324ESerial: P0108-890345
We are the original Landa factory in Portland, Oregon and have digital copies of user manuals, breakdowns and wiring diagrams for every machine that Landa has ever produced. If you have any questions please feel free to contact me using the information below.
Sincerely,Aron KerrLanda Northwest, Inc.aron.kerr@landanw.comwww.landanw.com800.247.8103
Apr 16, 2012 | Garden
I asked your experts a question on Saturday March 5th. As of today Monday March 7 I have yet to recieve a reply, This is totally unacceptable. Please reverse my credit card account with a credit or I will...
I am sorry you have had a poor experience on this website. I would be happy to answer your question if you can post it in this thread or if you would prefer to contact me directly at 800.247.8103. I am a certified pressure washer service technician for Landa and Karcher and have over 4 years of experience fixing pressure washers for 8 hours a day.
Aron Kerr
Landa Northwest
www.landanw.com
Mar 08, 2011 | Northstar Pressure Washer 3000 PSI
Looking for owners manual for Landa PC4-2000 pressure washer
We are the original Landa store in Portland, OR and have every Landa manual available both in digital and hard copies. If you can provide a serial number and email address I would be happy to send one of these out to you right away. You can reach me using the information below.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Oct 27, 2010 | Garden
13hp honda motor what is the right psi for it
It will depend on the pump that you have but the most common versions will be the 13HP PC4-35324 which is a direct drive unit or a PG4-35324 which is a belt drive unit. In both cases the machine would be 4GPM at 3500PSI.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
800.247.8103
503.255.6508
Jun 03, 2010 | Honda Landa PG 3500 PSI Pressure Washer
I have a landa hmp-4-3500 heated pressure washer and i am problems with the water heater. where can i find a trouble shooting guide for this machine
Landa does not have a model HMP so I am not sure which machine you have. If you can provide a full model and serial off of the model tag on the machine I can provide you with a digital copy of the manual you are looking for.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
800.247.8103
503.255.6508
May 19, 2010 | Honda Landa PG 3500 PSI Pressure Washer
I have an older Landa Pressure Washer. The burner is not working. Once I get the machine running and water flowing to the pressure washer, with the wand pressed, I flip the burner on switch....and...
Check for 12V at the igniter connector with the unit running. If you have 12V and no igniter it may be stuck or bad. Thrun the unit off and read continuity across the DISCONNECTED igniter plug / terminals to the igniter. No resistance = open igniter.
If all of the above checks out your going to have to look at the fuel pressure switch to see if it closes and passes 12V to the igniter.
Before you give up... Check the fuse.
Landa's website is www.landa.com
You will have to select a local dealer for parts.
Thanks for using FixYa!
Kelly
Mar 10, 2010 | Garden
I need to buy a pressure washer for residential/commercial work
Were I to pick from one of those three, I would pick the Landa. The most reliable pumps are Hotsy and since Karcher bought Landa and Hotsy, those three brands now have Hotsy pumps, though it doesn't say it on the machines.
Jan 01, 2010 | Honda Pressure Washer PSI 3000
Landa pressure washer manuals
send them an email at info@landa.com or contact them directly at 800-526-3248 for more info specific to your model which was not listed above. hope this helps you
Aug 09, 2009 | Heavy Duty Garden
Garden Logo
436 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
