Question about Refrigerators
What is the lowest ambient temperature that GE fridge model gts18fbsww can operate at
    Sergeant:
    Champion:
  • 351 Answers
Around 40
Posted on Oct 08, 2010
I have a GE Hotpoint fridge Model CTX14CAXKRWH. Freezer is over freezing & main unit warm/wet with condensation. Is this a thermostat issue? Is it even worth replacing in a unit from 1994?
Check the freezer fan motor if one. Also check the doorway that allows freezer air into the refrigerator part for proper operation.
Feb 22, 2017 | GE Refrigerators
Why does my GE top-freezer have hot spots in the freezer area
Probably the door heaters. They prevent the door from freezing shut.
Sep 19, 2016 | GE Refrigerators
What does the code E5 mean on my fridge freezer? It's turned on but not working.
E5 on Freezer Display Ambient temperature sensor error Unplug the refrigerator and check the wiring connections in the ambient temperature sensor circuit. If the wiring connections are okay, replace the ambient temperature sensor. If the problem persists, replace the electronic control board. Ambient temperature sensor, Electronic control board
Mar 21, 2015 | Refrigerators
What sort of oil does my harley rocker c take
You do not mention engine or primary or transmission. HD SYN3 can be used in any or all. I believe for the engine the best is Harley-Davidson 360 (20/50) in most operating temperatures I am operating in. If you know how HD tested, developed and otherwise came up with this oil it is quite impressive. You could use synthetic (SYN3) but I don't I just use the regular HD 360 motorcycle oil. You do need motorcycle oil because it has necessary, very beneficial additives that are not in automotive oils. Unless you are running in very hot outside temperatures I do not see the benefit to SYN3 but if one has money to throw around it is very good oil also. Thing is to change it always before it gets a chance to break down and or turn dirty. HD recommends changing the oil and filter at 5000 miles or 8000 km intervals and I would recommend that or sooner in very hot or dusty conditions. Using synthetic oil does not extend these mileages between changes. If you have been using one type of oil for an extended time it is usually not recommended to change to a different type i.e. HD 360 to SYN3 or vice versa. If you do not know what was used before pick a type now and stick with it. SYN3 is all 20W50. (The W stands for winter.) The oil has a viscosity of 20 cold and will not thin out more than a 50 weight would when it is hot.
Harley recommends HD 360 engine oil as follows:
H.D. Multi-Grade SAE 10W40 as excellent for cold weather starts below 50 degrees F and for use with lowest ambient temperature below 40 degrees F (4 degrees C).
H.D. Multi-Grade SAE 20W50 as good for cold weather starts below 50 degrees F and for use with lowest ambient temperature above 40 degrees F (4 degrees C).
H.D. Multi-Grade SAE 50 as poor for cold weather starts below 50 degrees F and for use with lowest ambient temperature above 60degrees F (16 degrees C).
H.D. Multi-Grade SAE 60 as poor for cold weather starts below 50 degrees F and for use with lowest ambient temperature above 80 degrees F (27 degrees C).
For transmission and/or primary use SYN3 or FORMULA+ TRANSMISSION AND PRIMARY CHAINCASE LUBRICANT (Part No. 99851-05, US quart size).
I won't deal with fork oil at all.
Whatever you do, NEVER use anything but DOT 4 Brake Fluid.in a DOT 4 system. Also be careful with it as it will eat away any and all painted surfaces and even the black powder coated brake fluid reservoir coatings.
If DOT 5 goes into a DOT4 system or DOT 4 goes into a DOT5 system all rubber brake system components will be destroyed.
John
Aug 23, 2014 | 2007 Harley Davidson FXST Softail Standard
Ge psh25sgsa - Wont hold temperature
The water is from the heating element that does the autodefrost. There should be a drain for it though.
Dec 16, 2013 | Refrigerators
My dehumidifier keeps turning off is hooked up to hose no water draining air filter is clean. model #ld450eal 45 pint
The most common problem is that the humidity extraction level is set to high. Set it to it's lowest setting. If you have an LED screen on your unit, the lowest setting will probably be 35%. Or in the case of no LED screen, Minimal will be the setting you want to use.
Since you're using a drain hose, I assume the unit is in the basement. If that's the case, the ambient air temperature at floor level, may be to cold for the unit to operate properly. Most dehumidifiers struggle at air temperatures between 40 and 60 degrees F. Try placing the unit up off the floor on something sturdy that can handle the weight (including a full tank of water) and the vibration during operation.
Hope this helped you trouble shoot and solve the problem.Please let me know. Thanks.
Jun 01, 2011 | LG Dehumidifiers
This unit is used in a garage as a 2nd unit. It
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Whirlpool 25.2 cu. ft. Side-by-Side...
Can a refrigerator be placed in a garage that houses the electric furnace?
Hi, all fridge freezers work on ambient room temperatures, ie room temperature. Also it will depend on the classification of your fridge freezer. On a normal classification fr/free 70 degrees should be a constant maximum. On a sub normal classification room temp should not exceed 50 degrees. on a sub tropical room temp can be pretty much as warm as you like. On the rating plate inside your fridge freezer two small letters exist (N) normal. (SN) sub normal. (ST) sub tropical. Most fridges will work for a while in the wrong temp but will work too hard and pack up
Mar 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
It freezes everything in the fridge,I have it on the lowest setting
depending on the make and model of your fridge, you most likely have a faulty temperature control which needs to be replaced.
some newer GE side by sides have a different issue.
Mar 01, 2010 | Refrigerators
HEAT PUMP OPERATION FOR TEMPSTAR SMART COMFORT 2400, MODEL THC436AKC1. LOWEST OUTSIDE TEMPERATURE FOR OPERATION?
I have installed many heat pumps and if it is installed without and ouside temperature sensor I would not recommend running it below freezing 32 degrees farenheheit. Running a heat pump at low outside ambient temps. can hurt your compressor and that is the most expensive part of the outside unit.
Dec 20, 2009 | Heating & Cooling
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
