Question about HP PSC 1210 All-In-One InkJet Printer
How do I scan a pdf from this machine. - HP PSC 1210 All-In-One InkJet Printer
  • HP Master
  • 7,733 Answers
Put the PDF doc in the printer glass tray and scan it on the manager command.
Posted on Oct 06, 2010
I seem to have a problem scanning on the KM C351. When scanning a multiple page document I recieve 1 .pdf file per page. This happens whether or not Seperate Scan is selected. Right now the scan are sent...
the file type is set to single page
1.press the scan button on the control panel
2.select scan setting.
3.select file type.
4.select multi page to have the entire scan to be sent as a single file.
if you are sending jpegs they can only be sent as single page files on this machine. only pdf's and tiffs can be sent as multi page files
Nov 13, 2009 | Konica Minolta bizhub C351 All-In-One...
HOW I PUT PDF IN MY SACANER
hello,
When you want to scan using the scanning software choose to save in pdf.
Or configure the scanning to save to pdf.
Hope it helps. .
Sep 12, 2009 | Sharp AL-1551CS Printer
How do you scan to PDF on a Konica Minolta Bizhub 353?
Touch [Fax/Scan] to display the initial screen for fax/scan operations.
Touch [Scan Settings] to specify detailed settings for scanning
In Scan Settings >File Type , select elect the file type for saving the scan data. The following file types are available (PDF,Compact PDF, TIFF, JPEG, XPS, Compact XPS).
Touch [PDF] or [Compact PDF]
In addition, the grouping of the saved data (single PDF or multi-page PDF) and the encryption settings (encryption level, password, document permissions, and other detail settings) can be specified.
You should check the user’s manual for images and more detailed info on how to operate the machine.
You can download it from here:
http://download6.konicaminolta.eu/konmin/servlet/KonMinMaster;jsessionid=9D04D81DD26189D21B3B2B8B32D2B06F.node02?path=../search.jsp&mode=show&document=32545
Jul 21, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
MCF 6490CW SCAN AS A PDF
I was trying to figure out how to scan multi-page documents to a single file and found this on the Brother website:
Double-click on the ControlCenter3 icon located in the Task Tray to launch the program window.
Click on CONFIGURATION -> SCAN.
Choose the type of scan you require. The choices are: IMAGE,
E-MAIL, and FILE.
The Scan to configuration window will appear.
The SOFTWARE BUTTON tab configures the Scan to button within theControlCenter3 software interface. The DEVICE BUTTON tab configures the Scan to key on the Brother machine. Choose the tab you want to configure.
Under FILE TYPE select an option that allows multi-page documents:
a) PDF (*.PDF)
b) Tiff Multi-Page # Uncompressed (*.tif)
c) Tiff Multi-Page # Compressed (*.tif)
Click OK.
Apr 28, 2009 | Brother MFC 6490CW InkJet Printer
Konica Minolta bizhub 750 scan file type default settings PDF
Once you have selected PDF on the screen touch you Ulitly/Counter button, then select User settings, display settings, Scan Basic default.
can go to konicaminolta us web site and down load a operators manual for scan, copy, fax etc.
Mar 31, 2009 | Minolta Di3510f Bizhub Copier
Not able to scan to pdf file with Brother MFC-240C
What you seem to want to do is not possible. Let me explain:
A file that has its data in the Adobe company Portable Document Format (or a pdf file) contains various objects that are described to the computer using a superset of the PostScript language, some of them can be images.
A file that comes from the scanner is first a very organized set of pixels and gets put into a more compact form by using a well known process as defined by the Joint Motion Picture Experts group. This is a roundabout way of saying that it has a format that isn't PDF.
What you CAN do:
a) open the jpeg file with a Macintosh, using the Print command from the file menu make a pdf file that has the image in it.
b) buy and install a PDF printer driver on a Windows machine, and then follow the same process as A above.
c) Use your favorite PDF creation program to make a file with the image embedded.
Carl
Dec 10, 2008 | Brother MFC 420CN All-In-One InkJet...
Ricoh Aficio 2090 Printing config question
You have to scan each one individually. The machine can scan them into a pdf file. Press user tools button. Press the scanner button and check the file format settings for individual files. Select PDF if needed.
Nov 13, 2008 | Office Equipment & Supplies
Possible to change default scan setting to PDF?
go into scan mode and select pdf, then go back to printer mode and select utility. user settings. store and current settings, then press store and it should use pdf as default
Jul 15, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica 7155/7165
on the scan setting before you scan you can change the scan setting to pdf as a defauft setting press the current user and press start. hope this will solve your problem.
HH
Apr 23, 2008 | OCE 3140 Copier
HP PSC 1210 All-In-One InkJet Printer Logo
66 people viewed this question
Seeker5211
Seeker5211
