Question about Ricoh Office Equipment & Supplies
The tool bar came on . my machine will not make copies , nor print or Fax . on the screen it said funtional problem with the copier code : sc543 my serial number is K9465200472
  • hrow6 Oct 06, 2010
    well I do not if his solution will help ,however it make since . so I will try it .
    Yes I would like to continue with Daniel S
    Daniel is thermistors expensive if I need one ? and how do I clean it ?
  • 4,323 Answers
Hi
Error code SC543 means Fuser Overheat Error 1, Hot Roller Fusing Lamp Overheat. This has happened due to faulty or dirty/worn out heating roller thermistor. Try turning off the copier for 1-2 hours and let it cool down. Now check if error disappears. If error is still there you'll need to clean/replace the thermistors. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Oct 06, 2010
  • Daniel Scott
    Daniel Scott Oct 07, 2010
    Hi!
    To access the thermistors remove the fuser cover. Check if they have any toner deposit on them. There are 2 thermistors on Ricoh printers/copiers, check for the connections on both the thermistors(one on left
  • Daniel Scott
    Hi!
    To access the thermistors remove the fuser cover. Check if they have any toner deposit on them. There are 2 thermistors on Ricoh printers/copiers, check for the connections on both the thermistors(one on left & other on right).
    Thanks
    Daniel
Aficio spc242 service call sc543
There may still be small fragments of the paper jammed in the machines roller system that you might be able to get to.
At worsethe roller has teeth busted on the gears and pulleys.
Aug 03, 2014 | Ricoh Aficio SP-C242SF - 21 PPM Flatbed...
Copy streaked
try to clean the print , by print clean print head
Sep 06, 2013 | HP Officejet Pro 8600
I have an all in one and I can print, scan, and
On the printer press setup-->choose tools option-->under tools-->choose print a fax test page.
Find out how is the printer connected with the fax line.
Note:- Line 1 at the back of the printer should be connected directly to the wall jack of phone line.
Now Follow the instrcution below.
  1. Send a one page black and white text fax to 1-888-hpfaxme (1-888-473-2963).
  2. When your fax is received by the HP Test Fax Service, They will generate a return fax to you within five minutes confirming that they have received your fax. This verifies that you can both send and receive a fax with your fax machine.
If you do not receive a return fax within 5-7 minutes, there may be a problem with the setup of your fax machine. Note:-The most common cause of failure is that the fax number set in the Fax Header on the machine does not match the number of the phone line connected to the fax. Also, ensure that the fax header contains the full 10-digit telephone number of the fax machine, including the area code.
May 10, 2010 | HP Officejet 4215v All-in-One Printer
I have Multi funtional Lexmark x342n machin. but i don't know,How to send fax from my machin.
have you installed the driver properly then good .in printer a fax printer is also installed when you install the full software of printer driver .for sending fax from any document choose the print option and in printer select the fax printer and send the fax.
but make sure fax printer is installed.
Jan 14, 2010 | Lexmark X342n All-In-One Laser Printer
REMOVE ACCESS CODE
Enter in the user tools and select the password cancel or machine settings and set the machine.
Sep 24, 2009 | Ricoh 3310LE Plain Paper Laser Fax
The wrench icon is on and code SC543-00 show up in the screen
That code indicates a fuser overheat error or hot roller fusing lamp overheat. Refer to your manual if you have it. Good luck.
Mar 16, 2009 | Ricoh Aficio 355 All-In-One Laser Printer
Printing a report
Funtion #7, userparameters, go down in the menu, you will find the wrong number there and can correct it.
Jul 17, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Faxing problems
Are u using a dedicated line for the fax or is it shared.....
If u are using an answering mech...then u need to set the rings...on the fax greater than the answering mech...
Or else Clear the NVRAM....(Note u will loose all the contacts saved in the fax mech)
a. Make sure the printer is in “Copy Mode”.
b. Press the “Menu” button once.
c. The screen will display “COPY MENU: Copies”.
d. Press the left arrow button once. The screen will display “COPY MENU: Tools”.
e. Press the button once. The screen with read “Tools: Maintenance”.
f. Press the button once. The screen with read “Maintenance: Ink Levels”.
g. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
h. Press the button once.
i. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The printer will prompt u to set it up
Jun 16, 2008 | Lexmark X5470 All-In-One InkJet Printer
1,031 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
