Question about Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher
How do I tighten the door handle on my Bosch dishwasher model SHY56A 05UC/14?
Remove front panel then you can access the handle screws. Open the door and remove the 'torx' screws surrounding the perimeter of the door.
Posted on Nov 06, 2010
When I press the start button, Bosch dishwasher (model SHY56A 05UC) just keep running the motor pumping the water out of dishwasher, irrespective of: 1) the wash cycle it is on, 2) whether the door is...
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Nov 26, 2010 | Bosch SHY56A02 / SHY56A06 Built-in...
Loose door handle
Here is the link to the installation manual; http://www.bshextranet.com/files/techtoolbox/SHV46C13-SHX43Cii.pdf pages 14 and 9 of the manual (16 and 11 of the pdf) describe how to remove the toe panel, and the door facia panel. You should then be able to access where the handle is attached. Hope this helps :)
Jul 15, 2007 | Bosch SHV46C03 Built-in Dishwasher
Loose door handle on bosch integra ltd. dishwasher
you can loosen the inside of the door with a small torx screwdriver and lift it up far enough to get to the screw that holds the handle from the inside. I did this with mine about 1 year ago.
Aug 30, 2009 | Bosch Integra® 500 SHX46L Built-in...
Hi,I have a Bosch dishwasher SHY 66C02 UC and the handle is loose. What do I need to remove to get access to the front panel? Thanks, Will
u have to remove the torx screws on lhs and rhs of the door and a also at the top of the door.once u remove them the front panel will come out and u can tighten the handle screws.good luck.
Aug 18, 2009 | Bosch Dishwashers
Owners manual misplaced, model SHY56a02uc/14
Hi Friend,
U can download the Manual from the below link provided
http://kitchen.manualsonline.com/manuals/mfg/bosch/shy56a.html
Copy and paste the Link in the brower
in the web page will be having a download button click it u can view the manual
Or if its needed i can send u a mail kindly provide the mail id
Regards,
Ayyasamy
Jun 15, 2009 | Audiovox Bosch 718 World Cellular Phone
My bosch dishwasher handle is loose
Hi rsouthwick,
I'm Harvey the Master Plumber.
You want to know how to tighten a bosh d/w handle?
Easy! open the door and look around the perimiter. You'll see screws on the right and left, they hold the front panel on. Simply remove them. The front panel is off and you can tighten away!
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 12, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHY56A Dishwasher
if the door doesn't shut, the push buttons should not work. that way you are not running your d/w with the door open. check the door latch, as it seems to be malfunctioning. if the d/w still does not work, replace the door latch.
Aug 15, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch Door Handle: Loose
I had the same problem with my Bosch dishwasher.I came to this web site to find out how to get the door off.I took the experts advice,placed 4 pillows on the floor in fromt,opened the door,took out the screws and the front panel dropped down.It was so easy,the plastic spacers stayed in place.I put a little J B weld on the handle screws and tighted the handle and put everything back together,12 minutes tops.Thanks for the help,thankful in Georgia
Jun 09, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher Logo
667 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
