Question about GE Refrigerators
Condenser fan motor not working on ge model PDS22SBRBRSS
  • GE Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Oct 08, 2010
The condenser fan freezes up, I can push start it but it still stops periodically. Is there some maintenance I can do? I have cleaned it up but wondering if there is something I can lubricate
using a spray with tube lightly spray the shaft as it goes into motor and on back if able to spray where shaft ends against back housing ---I've had fans last for long time and others just to late to save it keep in mind if lubing dont work will need to replace it and since you have accessed it changing it is not hard
Jul 12, 2016 | Refrigerators
I have a ge sbs model pcp23shmffbs. the condenser fan motor is running slow, but turning freely. the fan motor is rated at 11.3 volts dc and supply to fan motor is only 6.7 volts. is the condenser fan...
If the motor is running, but running slowly, you will need to replace the motor. If there was a problem with the PCB, (control board) the motor would not run at all and you would see other problems with the refrigerator.
Here is a link to the motor.
Jan 28, 2011 | GE Refrigerators
I have a GE side by side and the freezer is not working. Not freezing food.
The first thing I would do is to check the compressor and the condenser fan. Remove the cover on the back of the fridge and check how hot is the compressor? Is the condenser fan turning well? Also check the condenser coil under the fridge, it is very possible it needs cleaning.
If the condenser fan is not working properly then it has to be replaced.
If the condenser fan motor is fine and the cleaning did not help then the sealed system is low on Freon and in such case you need a certified technician to fix a leak and to charge the system.
Good luck in solving the problem.....
Jan 27, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE PDS22S refrigerator. The surface of the unit around the front of the freezer compartment is extremely hot--the front surface between the refrigerator and freezer is so hot I could not hold my...
My older frost free GE Profile gets VERY hot on the sides and on the top during part of the cycle.
Is your temp indicator picking up the heat from the cycle? Check actual temp using a thermometer...hardware store should have one.
Are doors competely closed on the unit? No Food or plastic wraps/bags in the way?
Is the fan working properly, not squeaking or squealing?
Mar 23, 2017 | GE Profile PDS22SBRR Stainless Steel...
I have a GE Refrigerator model PD520SFSBRSS that
Strange sounds can be deceiving as to their actual location. Your problem could be one of several:
* icemaker
* freezer fan motor
* compressor
* condenser fan motor
Contact an appliance service company.
Feb 15, 2010 | GE Profile PDS20SFS Bottom Freezer...
GE side by side TFX22RLC
If the condenser fan is not running while the compressor is running could damage the compressors overload. Yes it's a serious problem if not repaired soon. (Unplug until repaired.) This can cause a weakened internal overload inside the compressor. Thanks, Sea Breeze
Sep 21, 2009 | Refrigerators
Clicking of Ge Model PDS22SBRBRSS; serial No; DL047209
IF the below mentioned information does not help, then contact a elextrical engineer worksman who can check the circuit board as it might also cause a short cicuit.
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
May 31, 2009 | PDS22SFS Stainless Steel
Clicking of Ge Model PDS22SBRBRSS; serial No; AHO45649
Replace the mother board. It is only a matter of time until you experience cooling issues.
May 26, 2009 | GE Profile PDS22MHR Bottom Freezer...
Freezer
If the freezer is in defrost then the freezer fan should be off. Only on the electronic will the freezer fan come on in defrost but the freezer door has to be held open for 3 min before the fan comes on
Jun 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
138 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
