Question about Whirlpool Duet GHW9150P Front Load Washer
Have a code on it that says DL and then flash's F
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error "dlf" or F dl means a door latch failure. This means that you'll need to replace the door latch assembly however before doing that you can leave the washer unplugged for 30minutes so that it resets itself. In the meantime when it's unplugged just inspect the door latch wiring to ensure all the connector plugs are intact and not loose or broken. You can access the door latch wiring harness by removing the top panel of the washer. To remove the top panel just remove the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then lift off. Locate the door latch assembly behind the front panel on the right hand side. Trace all the connectors from the door latch to the Central Control Unit (CCU) and make sure they are properly seated at both ends. If after doing this still the issue is not resolved then unfortunately you have to get the door latch replaced. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 06, 2010
What does flashing code mean on a Kenmore elite 110.4597 front load washer?
DL is a door lock code. Did the door feel firm when closed?
Feb 29, 2016 | Kenmore Washing Machines
My maytag bravos washer is flashing DL, what does this mean, its not spinning!
The "dL" error code appears when an item inside the washer prevents the lid from locking properly. Open the washer and readjust any items that may be hitting the lid. The error code should go away once you properly close the lid
May 03, 2012 | Maytag Bravos 3.8 Cu. Ft. Washer
Flashes a code of "dL" and "F"
NOT MUCH INFO TO GO ON, BUT HERE GOES" A DL CODE IS A DOOR LOCK ERROR, A F CODE USUALLY HAS A # AFTER IT AND WOULD INDICATE AN ERROR. W/P HAD SOME MODELS THAT REQUIRED CHANGING THE DOOR LOCK-MECH AND CONTROL BOARD . HOPES THIS HELPS, PLEASE CONTACT ME @ HUBAPPLIANCE@COMCAST.NET AND PLEASE RATE ME.... THANKS
Jun 24, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Error code DL...
DL indicated a door lock failure. it will flash DL, then a F followed by a number (80, 82, 84, 85)
Jan 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
I am getting an DL F code on my front loader
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
DL flashes over and over
unplug machine for 2 minutes this will reset the computer if problem continues look behind bottom front cover and there is a tech sheet that will tell you what the f code is the DL code is bad door lock assembly. it could be the main control (mother board throwing you these codes) Ive seen this happen before
Dec 14, 2007 | Kenmore Elite 45986 Front Load Washer
Flash on ist DL
Looks like its true... Another major disadvantage. Removing TTL means removing one more hardware piece - TTL sensor. Pentax removed almost every nice feature, which needs some aditional or more expensive hardware: no TTL flash, less AF points, pentamirror... Seems like I bought Ds right in time.
Sep 08, 2005 | Pentax *ist DL Digital Camera
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
