Question about Whirlpool Washing Machines
I have a wirlpool duet washer that keeps giving me the code - DL and then flashs F. I can not do a load - I have opened and closed the door and tried several other things and it is not working
  • 5,911 Answers
"Fdl" is a door latch error code. This is an indication of either a defective door latch, door catch, defective Central Control Unit (CCU), or an interconnecting cable problem between the two. The following link explains how to troubleshoot this problem:
http://www.fixya.com/support/r4490349-fdl_error_code
I have included parts resources, and the steps required to replace any defective parts. Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
For a full explanation of all the error codes, each one of these appliances comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and post back with your complete MODEL NUMBER if you have questions. I hope you find this information helpful.
Posted on Oct 06, 2010
Control panel displaying DL F and not starting
The door locking routine fails to lock the door after six attempts the the error code FdL flashes to indicate a failure in the door lock and switch assembly. The only viable solution is replacing the door lock and switch assembly. Click on the link below for the instructions in replacing the door lock and switch assembly.
Replacing the Door Lock and Switch Assembly on Whirlpool Duet Front-Load Washers
Nov 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9400 Door will not latch. Washer turns on, Starts clicking then flashes dL F
Hi, DL means Door Lock Failure while F is either (F80, 82,
84, 85).....
DL flashes if the following conditions occur:
  • Door lid is not closed completely due to interference.
  • Wash media buildup is preventing the lock bolt from extending.
  • Machine/motor control detects open door lid switch when attempting to lock.
  • Machine/motor control cannot determine if door lid is in a locked state.
Oct 03, 2010 | Whirlpool GHW9400 Duet Washer
My duet ffront load washer give me the error code dl then an f when I try to start the cycle. I have tried pause cancel twice then opening the door and starting the cyle and closing the door last thing...
The door is not locked after 6 trials then the Central Control Unit (CCU) will enters a failure mode and the digital display flashes FdL. This is a door lock failure and the only viable solution is the replacement of the door lock and switch assembly.
Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening.
Gently peel the part of the door gasket near the door lock and switch assembly off the lip of the door opening outer lip. Remove enough of the door gasket to access the door lock and switch assembly behind the front panel.
Remove the three screws securing the door lock and switch assembly to the front panel and slightly lift then pull it back off the front panel and out of the out of the washer cabinet.
Connect the wiring harness to the new door lock and switch assembly one at a time then install it back in place behind the front panel.
Secure the door lock and switch assembly then put the eased part of the door gasket back over the outer lip of the door opening. Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Sep 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Fdl code message
>"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washer stops
Initially, pls open the lower access panel (bottom of your washer) by removing the 3 torx screws. There would be a sheet that lists the error codes. The panel pulls forward and down, inside mounted on the right side taped to that inner panel would be the above described sheet. Additionally, to my knowledge, this indicates a door latch fault, the machine cannot activate the lock or senses that the door is not closed or the door is not locked.
In some instances, the error code F/DL could be triggered be a loose component. This could be that the plastic fitting on the door is loose and therefore will not latch on the locking assembly or the locking assembly itself is loose. You could then try opening and closing the door a couple of times.
Should this be not corrective, then the logic controller board may require close checking.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 31, 2008 | Maytag Neptune MAH5500B Front Load Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not start gives code dl&f
Power off the wall, check to see if the connections to the door lock are tight. Or
Try some WD40 on the door mechanism of machine (not door) & open shut a few times; with the mains off the wall.
May 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
24 people viewed this question
Dan Webster
Dan Webster
Sal De
