Question about Garden
STARTER WILL NOT TURN OVER JUST CLICK HAS NEW SOL. BATT IS GOOD FULL CHARGE
  • 26 Answers
If you're absolutely certain about the battery being fully charged, you may want to check the connections at the battery and the starter. A good cleaning and tightening of all the electrical connections may get the engine to turn over.
Posted on Oct 07, 2010
I have a 1996 toyota previa,starter just spins, replaced starter,now it makes a grinding sound. Checked flywheel-can turn it with screw drive.Full charge on batt. cables are good,connections tight.???
Check the housing the starter goes into sounds like the teeth that the starter locks into have been destroyed.
This would mean it is just spinning inside with the new starter, it is probably just not worn like the old one would have been so it is probably just touching hence the grinding.
Regards Craig
Feb 09, 2018 | Toyota Cars & Trucks
Try to start my suzuki grand vitara v6 and the motor won't fully turn over. But the starter is doing its job, and there's full power inside vehicle.
Even if you have power the starter is not getting enough cold cranking amps to fully turn the starter.
Charge or jump battery.
This can also be caused by dirty batt cable connections clean them at batt if not fixed clean and tighten at starter
Hope this helps mike
Jan 30, 2016 | Suzuki Cars & Trucks
Starter wont turn engine over
Why did you change the starter in the first place? The battery need a full charge for the starter to operate properly, Need year make and model for more help. If the starter is grinding now and wasn't prior to replacement, it may have to be shimmed or the starter could be defective.
Jun 20, 2015 | Cars & Trucks
Jeep doesn't start. Turn key, hear slight click in fuse box but nothing else? Took battery out to be checked Pep Boys says its good, needs a "slight" charge. Went home reinstalled the clean...
clean all connections very good ( batt post connectors,gound wire from batt to frame/motor, also clean starter connections,and alternator connections) I know pep boys checked but you cannot properly check a battery unless it has a full charge!!!!! If it wont accept a full charge then batt is bad, If it charges to a full charge and fails a draw test the batt is bad. also when a draw test is done you can have the charging system checked also to make sure batt is recieving the proper charge input. all inexpensive checks, get it running and take it to a garage, 3 min test usually not even a charge most of the time. NOT A DEALER, and have them show you what they are doing. if you are a female have a male friend go with you or have it done. I dont care what anybody says!!!!!! When it comes to a inexperienced female, the DEALERSHIP,the REPAIR GARAGES will all try to get some kind of MONEY out of you before you leave their place of business.
Jan 10, 2011 | 1996 Jeep Cherokee Sport
Rv well not start starter well click but well not turn motor over and battery is at full charge
even though the battery can measure a full voltage (which measure a difference in potenual) the battery can still be bad by not being able to provide enough current to the starter to turn motor over. if you have a battery charger that can be used to jump start the car or use jumper cables from another running car and it starts the problem is the batt. if it doesnt start the you have to check if starter is binding up. this could be from engine siezing up or starter binding on fly wheel
Oct 24, 2009 | 2003 Ford F350 Super Duty DRW SuperCab
My car wont turn over, do you think its the starter?
check ign. fuses,batt.cables if theyre tight,make sure batt.is full charge,if every thing checks ok pull starter out of car and have it checked at local part store to make sure its defect,if so replace it.
Sep 23, 2009 | 1995 Toyota Camry
Where is my starter and if all I get is a click (all other buzzers, LCD lights, Stereo works) is it my starter? Battery is 6 months new.
starter is on passenger side of engine where tranny and engine mate.make sure batt. is full charge,connections at batt. are all tight,if every thing checks out and starter still only clicks pull it out have tested to make sure its defect and replace.
May 09, 2009 | 1991 Chevrolet S-10 Blazer
Battery is not charging nokia
check batt model r it arthorised batt and check charger and batt model no
Jan 23, 2009 | Nokia 6630 Cellular Phone
New starter good batt. only clicks wont turn over 1995 montero
The Batt does not have a full charge or it is the wrong cranking AMP's for the car... find out if it is the right Batt and also that it is put on a "slow charge" over night or at least 6 hr's
Jan 20, 2009 | 1995 Mitsubishi Montero
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
