Question about Marantz SR-680
How do i connect a technic 1200 turntable to a marantz sr-680; when i connect to any inputs the sound is barely audible when volume is all the way up
Soulvisitor
  • 1113 Answers
SOURCE: Marantz SR-18 NO Sound No Data error for DSS (Directv) only
You need to check the connection of the lead that carries the audio from the DSS to the amp, move it to one of the other channels ie vcr and see if it can be heard when set to and switched to vcr. Then we know if we are dealing with the Amp or the source..
Posted on Dec 23, 2007
SOURCE: Marantz sr 500 going to "protect" mode when on.
Change the audio amplifiers IC´s because are on short circuit
Posted on Oct 02, 2008
cjackHD
  • 71 Answers
SOURCE: Audio glitch on Marantz SR-19
It's probably not heat due to the Marantz' large frame and heat-synchs.
This could simply be a mismatch of impedance. The amp is 120w per channel, so make sure the speakers can handle this. Check the impedance (ohms) of the speakers and the amp as well. Clipping can be caused by overpowering the speakers, which could damage the speakers in the long-run.
If this is only from 1 source- (i.e.- Blu-ray player or cable) then it could be digital clipping.. This Marantz can decode 96kHz PCM or normal Dolby Digital & DTS. If this is a Blu-ray it may be streaming 192kHz PCM... (but most likely the Marantz will not even attempt to play that audio)
I hope this helps.
Posted on May 31, 2009
  • 256 Answers
SOURCE: Marantz sr 6200 he/she only has Audio in the way 7.1
Edson I think we know each other. Are you in Miami? You have two beautiful daughters... How are they? So, you have a Marantz, which is the 2nd company I worked in Long Island, NY when I was in the Hi Fi business. In order that we give you the best service, may I suggest that you repeat your request and ask for someone in audio. I am in the repair of computers mother boards etc. If you are still in Miami here is my telephone number 786-234-0692. Mi nome e Constantinos (arzconst is my inetrnal nickname with Fixya.com). Tudo es o Prtugu?s que falo. Mi espa?ol est? mucho mejor. Gracias de su consideraci?n y opci?n de nuestro servicio...
Posted on Jun 19, 2009
  • 3600 Answers
SOURCE: Hi ,Marantz SR7200 , i am getting an audible hiss
if your hooking up a phono input lead to a digital input lead it won't work analog and digital totally different setup. when you connect the leads up it just kills the input amp so there is no noise.
Posted on Jul 10, 2009
How do I connect Marantz AV7005 to Marantz SR9600
Remove the little black jumpers on the 9600 that link the pre amp section to the main amplifier inputs. They are the top row of rca inputs on the back. Using single rca cables from the pre out of the 7005 into the main amplifier of the 9600 connect all the channels you have wired speakers for, L,R,C, SL,SR, etc up to 7. Connect all your sources to the 7005 with whatever cables you have it doesn't matter. Turn off the 9600 volume and use only the 7005 to control the volume. It works perfectly giving an awesome amp a new lease on life. Good luck!
Oct 17, 2011 | Marantz Audio Players & Recorders
I have a marantz sr4320 receiver. The volume control knob is not working---I can't get any sound no matter the volume number. "d8" is now showing, too, following the number. I have followed...
Do you mean "db"?
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING. The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Turn the volume down.
While you're squinting at the front panel, find the manual and evaluate every indicator on the face to make sure you understand what they mean and how they might affect operations. Look for Speakers NOT enabled, Muting ON, a Tape or other input inadvertantly selected. If you fail to find the errant setting, treat it like a new install and set it up all over again according to the manual.
Mar 09, 2011 | Marantz SR-4320 Receiver
Distorted sound on Technics SL-1200/1210
You could be getting acoustic feedback from the speakers to the TT's. Lower the volume or somehow isolate them from room sounds and vibrations.
Jul 05, 2010 | Technics SL-1200 Turntable
Technics SL-1700 Turntable that is barely audible
Have you have tried it on a different amp, if not do so - which if it solves you have a faulty phono pre-amp in that amp- if not I would suspect that inside the deck is a faulty pre-amp. Or is the cartridge faulty?
Sep 05, 2009 | Audio Players & Recorders
Hi ,Marantz SR7200 , i am getting an audible hiss on phono inputs and digital optical inputs . If a connect something to the front phono inputs , however there is no hiss , any ideas ? Thanks in advance .
Jul 10, 2009 | Marantz SR-7200 Receiver
I was wondering what the extra wire attcahed to the audio cords it looks like a speaker wire
the bare stripped wire is for grounding the turntable to the receiver to eliminate any hum sound. If after connecting both phono plugs, you only get sound from one channel on the turntable but sound plays out of both channels on all other inputs then replace the phono plugs as this is the most likely problem.
May 27, 2009 | Audio Players & Recorders
One cdj and one turntable
This is possible, by connecting your turntable to the Line Input on the serato box. Then just connect both to your LINE INPUT on your mixer, and set the controls on your Serato Software to LINE INPUT - NOT Phono.
- OPTiC
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Jan 18, 2009 | Technics SL-1210 Turntable
Technics SUV500 Amplifier
check volume balance between right and left-then change inter connection between sound source and amplifier with new cabel(i prefer gold plated type connectors)(see radio shack).
after that if the problem excit your fault in output transistors or output stereo ic depend on circuit design.
Feb 17, 2008 | Technics SUV500 2-Channel Amplifier
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
