Question about Samsung Refrigerators
Side by side F/F is making a noise it sounds as if a fan is having trouble in the twin cooling area. could it be too cold? do I need to get an expert I to look at it?
  • 828 Answers
If it is a high pitched noise that you hear it is the fan motor bearings. The evaporator fan motor should be replaced in this case.
Call the store where it was purchased from and if they have a repair man they can send him out to make the repairs for you.
Posted on May 28, 2008
I have a twin cooling sam sung frosfree side by side nd fridge side is nt cooling bt freezer is ok and fridge temperature is 16
Refrigerator get there cold air from the freezer. Fan could be bad..
Usually located on freezer side
Sep 10, 2017 | Refrigerators
Samsung model RS2530BWP side by side is not cooling fan in the back making load noise off and on
that is coming from your fan check for any ice build up if none then I would replace the fan. u can find the part at applianceparts,com
Apr 10, 2014 | Samsung RS2534 Side by Side Refrigerator
My refri is working everything but is not getting cold ???
If your temperatures are higher than what you set it to be check your fans to make sure they are blowing cool air
Aug 11, 2013 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
The fan is making a weird noise and when i open the door it stops but when it stops in makes a loud noise and the temp on the fridge wont stay down but the freezer is fine what is the problem
You have a twin cooling unit and the refrigerator fan is getting clogged up with ice possibly due to a defrost problem. You will need to remove the back wall panel of the refrigerator to access the evaporator fan motor and clean it out of the excess ice buildup. Check the defrost circuits and also the defrost drain to make sure it's clear.
Jul 20, 2011 | Samsung RS2630SH Side by Side Refrigerator
Water dispenser on Hotpoint S/S door stopped working but ice maker is making ice
could be water inlet valve in need of replacement.also cold be water filter blocked, although would only happen in an area of high mineral content.if your fridge section is lower than 0 deg c, the water holding tank may be frozen up.also if your cab is the type with twin cooling, ie has a cooling element (evaporater)
Feb 27, 2010 | Hotpoint HSS25GFP Side by Side...
I have a hotpoint csx27h side by side refrigerator. the freezer get cold but the fridge part just started to where it wouldnt cool down. any suggestions? maybe the defrost?? the only things i have noticed...
check the operation of your damper door between the freezer and refrige compartments,this door opens and closes to throttle cold air from freezer to refrigerator compartment through the cold control,sometimes they freeze upand can't move,sounds like your door has frozen closed,if so,remove entire damper door unit,clean and deice,replace and see if this rectifies your troubles
Jan 12, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
Help
Well mine went through some of the same thing the fridge put out less and less cold ait and the freezer started to thaw just a tad on max settings. Mines about 8 years old and a kenmore.
Made the decision on an opportune time when Sears was having an additional 10% off sale..... my problem will be fixed ina bout 2 hours when my new fridge is delivered. The sad truth is (I now its cliche) they don't make um like they used to. Last fridge i had lasted nearly 20 years. Now if you get more than 5 out of an appliance you're doing good. Good luck but it sounds like the compressor died. You'll either need an expert to come out (think they have a min fee of $100 or more) or repalce it.
Jun 17, 2008 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
126 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
