Question about Gaggia Baby Espresso Machine
New gaggia baby after setting up and priming when brewing coffee if spurts out through hole at very high pressurs going everywhere i have the correct finely ground cooffee and correct amound but it is coming out way too fast
    President:
  • 1,618 Answers
You either have to adjust the grind finer or tamp your coffee a little harder.
Posted on Oct 06, 2010
  • jaynerussell Jan 31, 2011
    Have the same problem and yet to speak to La Gaggia....and trust me it is nothing to do with grind or tamp of your coffee.
    Firstly I have owed La Gaggia for 15 years and have tried every conceivable grind etc and same horizontal spray.
    I kept trying because I was in denial that a La Gaggia could be faulty but the machine deserves the bin if having to fiddle so much is the only way to solve the situation.
Gaggia Baby Ivory, 2 weeks old.Hot coffee spurts out of side of brewing head when brewing. I called your Philips help line & was told that I had to insert a plastic disk, which is not shown on the...
If coffee is brewing out the side of the head then the group gasket needs to be replaced because it is damaged or there might be coffee grounds stuck to the gasket and it needs to be cleaned using a brush or you can also use cotton swabs.
May 23, 2011 | Gaggia Baby Espresso Machine
Water comes out of steam nossle when operating brew button
If it only happens when you are brewing a coffee, and not while you are just running the head without the portafilter in place, then the grind might be too fine and the resulting pressure is forcing through the valve. Easiest solution replace the steam valve.
Nov 27, 2009 | Gaggia Baby Espresso Machine
Gaggia baby espresso machine-Steam button is stuck
The only thing that comes to mind is that the machine is in steam/hot water mode. Unless you replace the switch and turn off the steam light so that it sends the water to the correct location. Also you might want to remove the shower screen and make sure it is clean.
Nov 26, 2009 | Gaggia Baby Espresso Machine
Gaggia baby espresso machine - water comes out of steam wand but not group head. tried priming, cleaning
Remove shower and screw, then run brew button, if that works clean shower, if not remove allen wrench screws and clean diffuser and valve on spirng.
Oct 21, 2009 | Gaggia Baby Espresso Machine
No water coming through - New Gaggia Baby Dose
Try this remove the portafilter, then press the button for brewing coffee and then turn on the machine, if both hoses are in the water reservoir, then water should flow out of the head after a few seconds.
Jul 20, 2009 | Gaggia Baby Espresso Machine
The coffee has started spitting out, spraying
The group seal gasket needs to be replaced.
Jul 15, 2009 | Gaggia Baby Espresso Machine
Gaggia Classic Spurts Everywhere
Hi there if your coffee is spurting out the sides it is because the group gasket is worn or has gone hard through use and now needs replacing. Basically when you twist your coffee handle on it doesn't always form a perfect seal and so the pressure causes the coffee to spurt out the sides. If you are not sure where to get parts get in touch with David at coffeeservice@live.com and he will be able to sort you out.
All the best
LaPavoniBoy
Jul 13, 2009 | Gaggia Classic Espresso Machine
Baby gaggia steamer doesn't work
Does the machine brew hot coffee? If yes, then remove the parnello and clean the holes at the end of the steam wand. If that does not solve problem, then it is blocked where valve is connected to boiler, Try descaling machine. If no then the thermostat on the boiler has tripped and needs to be reset.
Jun 06, 2009 | Gaggia Baby Espresso Machine
Coffee spurting everywhere!
Unlike the other person offering a solution I have experienced this problem like you when making the first cup. I found that sending a blank shot of water through first does the trick before putting the coffee grounds on. Hope this helps.
Jun 09, 2008 | Gaggia Classic Espresso Machine
Gaggia Baby Espresso Machine Logo
231 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
