Question about Hotpoint WMA50 Front Load Washer
Hello my washer is leaking water from the detergent draw it happens as the wash is doing its final spin.any ideas on the problem?thanks.stephanie
    Problem Solver:
  • 15 Answers
Clean the softner box or pour boiled water inside it
Posted on Oct 06, 2010
Testimonial: "thanks that seems to have done the trick"
Detergent dispenser drawer leaks.
give the draw a good clean by pulling it out, and check the level of the machine
Mar 15, 2014 | Hotpoint Washing Machines
GLTF1670ASO full spin
Hay Stephanie ,your whole problem is your using too much or not HE detergent I suggest you run a empty load with afresh once a month.good luck APPLIANCES R EN
Mar 01, 2013 | Frigidaire ATF6000ES Front Load Washer
Our Bosch washer leaks but only during the spin cycle.It is a Classixx.
Try cleaning the detergent draw somtimes this can cause water to spill out and ofcourse check the filter and exit pipe :)
Hope this helps
TalkAppliance.co.uk
Apr 12, 2012 | Bosch Washing Machines
When on final spin, water leaks from detergent draw
You probably need to clean the filter.
Remove lower rear cover of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 18, 2010 | Hotpoint WMA58 Front Load Washer
Hello. My frontload LG Washer started leaking
I have the same problem I think. During the wash cycle, water sometimes starts spraying/leaking from the detergent dispenser drawer. This orignally only happened during a 'NORMAL' wash and when I ran a 'SPEED WASH' it was ok. Now all of a sudden it's doing it during the 'SPEED WASH' also. I though it might be the water pressure so I turned down the flow going to the washer but that doesn't seem to help. If I knew how the detergent system worked maybe it would be easier to solve this problem.
Nov 11, 2009 | LG WM2277H Front Load Washer
Water leaking through detergent tray of my Hotpoint WF860
It sounds like the washer is not draining properly.
Remove lower rear cover of washer, locate and remove the large black hose fastened to bottom of tub.
remove plastic filter inside hose, and clean same.
Refit filter and hose, making sure it is on properly.
Be careful when you remove the hose, as there will be water in there.
As an extra precaution, remove soap draw,and thoroughly clean all parts, particularly,the conditioner parts
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint Ultima WF860 Front Load Washer
Whirlpool® 4.6 Cu. Ft. Cabrio® HE Washer leaking water
coins may have breached the outer tub. expensive way to learn to remove loose objects fro clothes before washing them
Sep 14, 2008 | Washing Machines
Help Please!
2 screws across the bottom of front panel will allow the front panel to slide off, then you can get an idea *** to where the leak is happening. fill with just a little water and advance to spin
Mar 10, 2008 | Frigidaire FEX831CS Top Load Stacked...
Hotpoint WMA50 Front Load Washer Logo
171 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
