Question about Kodak Digital Science 3520DP Path-Through Scanner
How do i connect a "fujitsu 4750 scanner to my PC.
I have a scanner that came with a scsi 50 pin cable on btoh ends.Is there a converter that can be attached so that i may connect to my PC?
  • Niels Boehme May 11, 2010
    Do you mean you need to convert the 50 pin cable to the connector on the scsi card in your pc? (What connector is on your pc?)
  • 25 Answers
You need to get a SCSI board for your computer. This board will plug into a pci slot. There is no "converter" for usb to scsi that I have ever heard of. I don't think scsi voltages or commands can be put on a serial usb bus. Check with Adaptec for scsi cards.
Posted on Jul 09, 2008
My pc does not have a 50pin connector. so i need (i Guess) a converter that will go from the 50 pin to a usb on my pc?
thanks.
Posted on Jun 03, 2008
My cable that came with my ricoh is01 does not seem to be compatible with with my scanner and neither can I plug it into the pc.
The Ricoh IS01 uses a SCSI 2 (50 pin) interface. It should look like the one here: http://www.amazon.com/Cables-Go-03564-SCSI-2-Cable/dp/B000051312 . There are SCSI to USB converters but I'm not sure if you need a specific version. (Scanners require bidirectional communication with the computer so there were few interfaces that required a special connection.)
Depending on your computer's OS, there may be other issues. (Some may not be compatible with Windows Vista or Win7, for example.) Drivers for some OS versions are available here: http://www.ricoh-usa.com/downloads/downloads.aspx . Search for the IS01 (no other information is needed)
I hope this helps.
Jan 01, 2011 | Ricoh Aficio IS01 Flatbed Scanner
Connector question
dear,
well to rectify this problem you have 2 options:
1. either you can purchase a PCMCIA card with 50 pin Scsi connector.
2.or USB to SCSI convertor.
all this kind of connectors and convertor are available in IT shops
Regards
May 15, 2008 | Agfa DuoScan T1200 Flatbed Scanner
I have fujitsu 4120c and it doesnot work,it have error 8.can anybody help me
Error code 8 means the SCSI fuse is blown off. This alarm is detected during initial processing immediately after power-on.
Probable causes:
- Defective SCSI cable
- Other SCSI device malfunction
Check if the SCSI cable or other SCSI devices connected to the scanner cause this error.The scanner can work even after this error occurs.
If the issue persists, you may have to contact Authorised Fujitsu Engineer to rectify the error.
Hope the above information is helpful.
Thank you for contacting Fixya.
Regards,
TechSatya
tech.satya@gmail.com
Nov 13, 2010 | Fujitsu fi-4120C Path-Through Scanner
SCSI to USB connection
You would need a USB to SCSI (50 pin Centronics) adapter. That would get it connected, but i don't you are going to find any software or drivers that will then see the scanner so you could use it.
May 11, 2010 | Apple OneScanner 1200 Flatbed Scanner
Fujitsu fi-5750c Flatbed Scanner need to
The back panel of the scanner should have a USB connection to the right of the SCSI ID selection switch (the farthest right on the back). Just get from any source a standard male/male A/B USB cable.
Then get the correct drivers here: http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/twain/v921720c.html . Additional software may be found here: http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/drivers-downloads_index.html
I hope this helps.
Apr 30, 2010 | Fujitsu fi-5750C Flatbed Scanner
I would like to connect my old SCSI coolscan iii
If your macbook doesn't have the correct SCSI card (SCSI II - d-sub mini 50 pin x2 connector) installed, you aren't going to be able to do this. You will need to find this SCSI card and install it in a computer that will accept it.
Rich
Dec 16, 2009 | Nikon Coolscan III Film Scanner
Need replacement SCSI cable for scanner. 50 pins male- I think HD. Can't figure out what to order
try google: (50 pin scsi cable).
or look here: http://www.nextag.com/scsi-50-pin-cable/search-html
Apr 20, 2009 | Office Equipment & Supplies
I need info on the make of scsi card that is bundled with scanner
It may be an old Adaptec SLIM-SCSI series. Very popular on Late 90s
1. Adaptec PCMCIA Fast SCSI Controller ( 1807600 ) - SCSI Controller ...
    "Adaptec Storage SCSI Controller Card, Storage 1807600, Adaptec PCMCIA Fast SCSI Controller."
    www.superwarehouse.com/Adaptec_PCMCIA_Fast_SCSI_Controller/1807600/p/88814
2. Adaptec SlimSCSI 1460 review - IT Reviews
    "Adaptec is the king of SCSI connectivity devices and currently offers two PC Card (PCMCIA) SCSI cards. The 1460 is the jack-of-all-trades model, ..."
    www.itreviews.co.uk/hardware/h82.htm
3. Download Adaptec SlimSCSI 16-Bit PCMCIA SCSI Host Adapter 5.0 ...
    "Download Adaptec SlimSCSI 16-Bit PCMCIA SCSI Host Adapter 5.0.2183.1 - Adaptec SlimSCSI 16-Bit PCMCIA SCSI Host Adapter."
    www.soft32.com/download_171850.html
Jan 18, 2009 | Umax PowerLook 2100XL Flatbed Scanner
Interfase doesnt work, cable is damaged.
I should be a scsi 2 cable -- 50-pin mini-din male/male...
Double check the scanner and the card, if you don't know the difference between mini-din and regular, let me know and I'll try to find images to show you.
Maggie B
Feb 21, 2008 | Agfa Arcus 1200 Flatbed Scanner
Kodak Digital Science 3520DP Path-Through Scanner Logo
193 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
