Question about Linksys Instant Networking Hub
Clarification.. I have the hub unlinked to the modem. I then have all three PC's coming our of the hub and into the CPU. What have I done wrong?
  • 77 Answers
Sounds like everything is hooked up correctly. Try plugging in the computers that aren't working one by one into the same port the working one was plugged into to see if you have a bad hub. Let me know if that works for you than we can take it from there.
Posted on May 28, 2008
How to connect IBM 8224 002 Hub
Connect the ISP modem to main IN uplink port. Then connect pc to any other port. Done!
Nov 28, 2012 | IBM 8224 Ethernet Stackable Hub 73g9764...
Hai, Good Afternoon, how can i configure Local network through ADSL router to Switch (d-link DE-816TP)
Hi...
It's simple...
Reset it to the factory defaults; Connect an ethernet cable from the modem/router to the first LAN input (LAN1) in the D-Link device; Connect computers/any other device to any of the rest LAN inputs...
Done! :)
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Good luck & best regards,
Pelu.
Apr 06, 2011 | D-Link DE 816TP (DE-816TP) Networking Hub
Usb hub powering up mt pc fans??
the switching system of your mainboard is not working properly try to change the resistor and capasitor near the control panel. good luck
Apr 23, 2010 | Computers & Internet
Dont know how to put on wheel hub
While you did not mention the year, front or rear hub I have done most.
The hub bearing assembly is a sealed bearing that mounts with three bolts coming in from the axle side. An air impact gun will be required to remove the drive axle spindle nut that passes thru the center prior to disassembly. Remove the axle nut, three hub fasteners and ABS wire harness to the wheel speed sensor. Reinstall in reverse order
Feb 25, 2010 | Chevrolet HHR Cars & Trucks
Only one computer can acces the internet in my hub , I have a Linksys NH1005 hub , I'm using cable dsl , but only one computer can acces the internet , it does not matter wich port
If you want to use more than one computers you will need to replace that hub with router. Best is to get wireless router because in most routers you have places for wired connections and also wireless connection.
Reason why you can't use more than one computer is simple because most ISP are allowing only one computer to be connected from DSL modem.
Oct 24, 2009 | Computers & Internet
What modem is needed for windows xp dial up connection
You can use virtually any PCI-modem card for your computer. The Dell Dimension 2400 has 3 PCI slots and unless you have some fancy CPU cooler that takes up all the space inside the machine, any card will fit.
Take a look at these to get an idea.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 18, 2009 | Dell Dimension 2400 PC Desktop
How do i get internet on a ps3?..
You have to connect the ethernet cable coming from your modem to a hub on the 1st clips space.
Then the 2nd one don't use it, the 3rd one will be for the cable coming between the hub and the PC. Hub is a (Network Hub Switch) that you can buy it from any hardware shop.
Then the 4th one is the one you connect between the hub and the PS3.
You have to give a local IP for your PC and PS3 using the configuration of your modem, or by enabling the DHCP to let the IP getting released automatically.
It will work 100% in case you follow the procedures properly
Aug 12, 2009 | Sony Playstation 3 (PS3) Console
Router not recognizing internet connection from cable modem.
No, you do not need a Hub. You also should not need to add the mac address. On the router, you need to enable DHCP so that your PC can get its IP address from your router. Then try your reboot again. Modem------------->Router----------------->PC. Wait about 1 minute between each device for them to sync up. Make sure that your PC IP settings are set on obtain IP address automatically under Control Panel----->Network Settings
May 11, 2009 | Intellinet Active Networking (522212)...
In booting my cpu fan reads ''o'', what is this preoblem?
your cpu fan is probably plugged into the wrong slot on your motherboard or your sensor is broken. 1 of the 2...
May 09, 2009 | Dell Dimension 2350 PC Desktop
Linksys Instant Networking Hub Logo
74 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
