Question about Texas Instruments BA-II Plus Calculator
How to determine PITI with BA 2 Plus? - Texas Instruments BA-II Plus Calculator
Calculate 2^1/5 using BA II plus
Press 2 y^x ( 1 / 5 ) =
y^x is just above the 9 key.
Oct 17, 2013 | Texas Instruments BA-II Plus Calculator
I need to calculate exponential to the power of a number with minos sign. I have a BA II Plus
Make sure you use the +/- key (located just right of the decimal point key) to enter a negative number. For example, to raise 3 to the -2 power, press 3 y^x 2 +/- =
Jan 13, 2013 | Texas Instruments BA II PLUS Financial...
How do I compute fractional exponents on the TI BA II Plus calculator?
The same way you raise a number to a non-fractional power, using the y^x button. For your example, press
3 y^x ( 1 / 1 2 ) =
or
3 y^x 1 2 1/x =
Dec 08, 2012 | Texas Instruments BA-II Plus Calculator
My BA II plus professional showing wrong answer while computing "N" during TVM calculation
Make sure you have P/Y set to 1 and BGN/END set to END. With those settings, pressing 9 I/Y 9 2 0 FV 1 0 0 +/- PMT CPT N should produce 7.00 .
Aug 25, 2012 | Texas Instruments BA-II Plus Pro...
TI BA 2 Plus Calculator: Cannot figure out how to use log(10) function, not the natural log but the base of 10 log
The BA II+ does not have a key for the common logarithm function. You can calculate the common log of a number by calculating its natural log and then dividing by the natural log of 10.
log10(x) = ln(x)/ln(10)
The same procedure works for logarithms to any base.
Dec 14, 2010 | Texas Instruments BA II PLUS Financial...
How do I find the "Log" key on the TI BA 2 Plus? Not natural log, but to the base of 10
There is no common logarithm key. You can compute the common (base 10) log of any number by using the relationship log(x) = ln(x) / ln(10).
For example, to compute the log of 2, type 2 LN / 1 0 LN =
BA-II Plus Calculator: hi. i have a texas instrument calc & its model...
There isn't one.
Sorry if that wasn't the answer you wanted to see, but there it is.
May 17, 2010 | Texas Instruments BA-II Plus Calculator
When I am trying to figure the standard deviation on my BA II plus I am not getting the right answers?
s=sqr(1/(n-1) sum (x-x_ )^2  or  sqr(1/n)......
just a slight differance  but never the less differant
hope this helps
Jan 15, 2009 | Texas Instruments BA-II Plus Calculator
Texas Instruments BA-II Plus Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
