Question about Samsung SCX4623F Laser All-in-One Printer
Manual feeder paper empty Huh? I'm not using the manual feeder. What do I do? Thanks.
  • jplunket Oct 06, 2010
    didn't work. Help!
    President:
  • 4,070 Answers
Hi! Please try this as a first course of action. Unplug the copier from power source and turn it on for 15secs. while unplugged to reset the system. After 15secs. Plug the copier from power source and see how it goes. Hope this helps and thank you for using FixYa!
Posted on Oct 06, 2010
  • Samsung Expert
  • 2,973 Answers
Please disconnect the printer from the PC/laptop after powering it off. Reconnect it after a minute or so. Check if it works. If it does not then follow the link below to uninstall and reinstall it. The reboot is as important as the drivers.
http://www.fixya.com/support/r3559995-installing_devices_on_pcs_and_laptops
Posted on Oct 07, 2010
  • Appliancerx Dec 18, 2010
    mY sAMSUNG SCX-4623F DOES THE SAME THING... IT SAYS MANUAL PAPER TRAY EMPTY AFTER ATEMPTING TO PRING FROM EXPORER WEBPAGE,,, FROM WORD OR ANYTHING WINDOWS BASED IT PRINTS PERFECT,,, FROM EXP 7 IT THROWS ERROR CODES AND i HAVE TO REINSTALL THE DRIVERS TO PROCEED. sAMSUNG TECHLINE SAYS IS MY COMPUTER,, mY COMPUTER GUY SAYS MEMORY CHIPSET IN PRINTER IS MESSED UP.
T644 Default Paper Source Problem
On the left side, near the pichup roller, of the tray there should be a "flag" hanging down in the elips hole. See if it is hanging down or stuck in the "up"position.
If so pul it down and the machine should work fine again.
Jun 26, 2013 | Lexmark T644 Laser Printer
Tip
Main Error MINOLTA DI 1611, DI 2011 Messages and Their Remedies
PAPER JAM A paper misfeed occurred in the
main unit.
Open the cover at the indicated
location, and then remove the
misfed paper. (“When the Message
(Flashing alternately)
OPEN XXX SIDE COVER
All misfed paper was not removed
from the main unit.
Check the message in the display
for the location of the paper misfeed,
and then remove the misfed paper.
ORIGINAL DOC.JAM A paper misfeed occurred in the
Document Feeder.
from the Automatic Document
Feeder.
Open the Document Feeder Cover
and the Document Feeder, and then
OPEN DOC.FEED COVER
∗REMOVE PAPER IN
BYPASS TRAY∗
Paper is loaded in the Manual
Bypass.
Remove the paper from the Manual
Bypass.
FRONT COVER OPEN The Front Cover of the main unit is
open or not securely closed.
Securely close the Front Cover.
CLOSE FRONT COVER
DUPLEX COVER OPEN The Duplex Unit Cover is open or
Securely close the Duplex Unit
Cover.
CLOSE DUPLEX COVER
DOCUMENT COVER
OPEN
The Document Feeder is lifted up
(while a document is loaded into
it).
Securely close the Document
Feeder.
CLOSE DOCUMENT
COVER
DOC.FEED COVER OPEN The Document Feeder Cover is
open.
Feeder Cover.
CLOSE DOC.FEED
COVER
TONER EMPTY The toner is empty. Copying and
printing cannot be performed.
Replace the toner bottle with a new
one.
SUPPLY TONER
PAPER EMPTY The selected paper tray has run
out of paper.
indicates the paper tray, and
“XXX” indicates the paper size.
Load paper of the specified size into
the specified paper tray.
on Dec 18, 2009 | Office Equipment & Supplies
Samsung scx-4248FN will not print. it shows "manual feeder paper emtpy" there is paper, I added more, I turned it off and on twice??
Presume that the paper sensor stopped working. If after reset it still "reuses" to recognize it has paper, you should take your printer to a repair service.
If you have some doubts about my answer, continue your quesry
Dec 13, 2012 | Samsung SCX-4828FN All-In-One Laser...
Paper transport works not properly, 3 flashes orange LED
First make sure the printers well connected and the power supply properly plugged.
  • Remove any previously loaded paper.
  • Check out the printers Auto sheet feeder/front feeder for any paper jams and remove manually any visible stuck papers.
  • Turn the printer off and on.This also helps in automatically removing any stuck papers that may not be manually removed.
  • Make sure there is no foreign objects in the Auto sheet feeder.
  • Make sure you load a fair amount of plain papers in the feeder,that is,reduce by half the amount you feed into the feeder.
  • In case the printers rear cover had been removed,fit it properly by pressing it firmly until it fully fits into the rear of the printer.
Hope this helps.Thanks!
Please rate this answer.
Oct 26, 2011 | Canon PIXMA iP3300 InkJet Photo Printer
It says paper tray is empty when it is not and so it won't feed the paper through.
It is probably asking for paper in the manual feeder. Open that door and insert a peice of paper to see if that will help.
Aug 02, 2011 | Dell 1815dn All-In-One Laser Printer
IBM 1422 not feeding 8 1/2 x 11 paper through multipurpose feeder
Go into the paper menu and set the multipurpose feeder paper size to letter. It will work if the paper size is set correctly for the MPF.
Apr 30, 2009 | IBM Infoprint 1422 Laser Printer
Won't copy document through feeder.
When you say it won't copy, do you mean that the paper won't move in the feeder or that no copies come out? Do you get any error messages? Try using alcohol on a swab or lint free cloth and clean the feed rollers in the feeder. They sometimes get paper dust on them and they can't pick up the paper. Also make sure that any paper sensors that detect when paper is in the feeder are intact. Occasionally they get stuck or broken. Hope this works.
Sep 22, 2008 | Canon imageCLASS D760 All-In-One Laser...
Paper source
I would suggest checking printer properties in the computer and ensure the paper size and source is Letter and set to Automatic Choose. Another choice may be to deleted the printer driver and re-install it. You can also go into the menu options until you get to Set factory defaults, press Select, then try the print job again.
I really suspect a program is controlling this from the computer.
To get a list of the existing printer settings, Select Menu and use the Right Arrow button until you get to Printer Menu Settings. The printed report should tell you what your actuall settings are. Maybe the default is set to Custom, instead of Letter.
The Set Factory Defaults option should fix most problems.
Good Luck John Moser
Jul 01, 2008 | Lexmark Optra S 1625 Laser Printer
Hp paper feeder wont thu printer
paper feed rollers wont feed paper through and also paper tray is empty prompt comes up when there is paper in the tray tried small amounts of paper and still says tray is empty
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Samsung SCX4623F Laser All-in-One Printer Logo
3,453 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
