Question about Zebra 170Xi II Thermal Printer
Where can I find V18.8.0 or higher version firmware for Zebra 170XiII printer?
4 Suggested Answers
RoryMRP
  • 111 Answers
SOURCE: Zebra printer 140Xi, firmware 16.4.1, Labelview software 8.0. Click print a label which works on another computer and zebra printer and nothing happens
Try and reflash it again.
Posted on Jul 10, 2009
  • 185 Answers
SOURCE: Unable to upgrade Zebra TLP 2844-Z printers firmware
Any time you are upgrading the Firmware the light should flash red/orange, when complete the light will come solid green. Serial connections are very slow, you can do the upgrade via the Parallel port which is faster. I would not use the Ethernet port. If the upload is interrupted you could corrupt the main board which will require replacement. Firmware should only be upgraded if there is an issue to be overcome.
Posted on Dec 20, 2009
ozztech
  • 285 Answers
SOURCE: We must upgrade Zebra 170 XiII printer firmware.
The latest firmware version available for the XiII printer is V18.9.2.
Zebra P/N 49970V18.9.2M
Posted on Nov 13, 2010
How to downgrade ZM400 printer firmware
If the firmware here is the one you have, contact their support direct and ask them for the older version. You won't find it anywhere else.
ZM400 Industrial Printer Support Downloads Zebra
Jul 26, 2017 | Zebra Office Equipment & Supplies
We must upgrade Zebra 170 XiII printer firmware. We need V18.8.0 or higher version.
Oct 06, 2010 | Zebra 170Xi II Thermal Printer
I Want ot flush the printer memory in zebra s4m printer please help
You can go from the setings (overigth mem - yes)
Reset to factory defult (dowload segull driver from www.seagullscientific.com)
other solution is to install new firmware (latest version) www.zebra.com
Oct 01, 2010 | Zebra S4M Thermal Label Printer
Brady 600x Plus II Date Code Is Off
mmm...Maybe try updating the firmware. That printer is a Zebra Z96XiIII Plus printer. Zebra made a change in their code for the onboard clock in version 60.13.0.5 See if you have that version and if not, you can to to www.zebra.com and download firmware for the printer.
Hope that helps !
Apr 26, 2010 | Brady BP-THT-600X+ Thermal Label Printer
We have a 170xiII Zebra connected to an IBM 3174 (coax) need to change connection to a jet direct. What parts do I need? Basically I want to remove the coax connection and add a jet direct or network...
You should be able to add either a jet direct box or an external Zebra ZebraNet PrintServer box to the parallel port of the printer. This will give you a network connection.
Apr 09, 2010 | Black Box Coax connector (FC055-10PAK)
Zebra 105SL Prints fine through Zebra Setup Utility, but prints plain text when file copied to port. Win XP. The setup utility can never get Version Info from the printer, but Windows shows the printer...
possible fonts issue. try to change the font from the text, check setings from the driver.
try to print from the driver (test print)
Try to print from Word (need to ajust the page) with diferents text fonts.
you can check the correct firmware ( be ware with the information about the serial number) ATENTION!!! wrong firmware can cause PRINTER DEAD!!!
Install lates firmware to the printer.
Oct 12, 2009 | Zebra 105SL Thermal Label Printer
Same problem with 160S
The 160S has a different main logic board, which the processor is different. I wonder if you could try and open up the cache. There is a ZPL command for that, which is COY. You can find this in the ZPL programming manual on the website. I can supply the link if you are still in need of a fix.
Aug 25, 2009 | Zebra Z4M Printer
I need the driver for Zebra LP 2844 for MAC OS X.
OS X 10.5.2 and above have built-in ZPL and EPL drivers. Plug the printer in to USB, go to System Preferences > Print & Fax, click + , and choose the Zebra driver. For the LP2844 you choose the EPL2 driver.
Apr 09, 2009 | Zebra LP 2844 Thermal Printer
Zebra 170Xi II Thermal Printer Logo
43 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
