Question about One For All URC-8811 Remote Control
Need code for trutek dvd player to input in my one for all remote. I get the blinking lite but do not know on what screen the code is displayed. Thanks for your help
I need the code for a magnavox tv/dvd player
Posted on Jun 28, 2008
    Genius:
  • 1,224 Answers
Http://www.rockabilly.net/files/manuals/URC-6131.pdf
heres the link for manual and codes
next time we need name of dvd player model number to match correctly
Posted on May 28, 2008
I have a sansui flat with build in DVD but don't have a remote the DVD will load but when push play it says operation not possible with disk what is this do I just need a univ.remote
First, check which input you have the TV set on. There may be an Input button on the side of the TV. (On the SLEDVD197, the button just below the DVD Eject button.) Just press Input and use the Channel Up/Down arrows to navigate the menu to change to the DVD. Press Input again to Enter the selected option.
With the TV in DVD mode, try pressing Play again. If you still have the error, check the region code for the disc. The "Operation not permitted" messages is usually that something on the disc is locked. Frequently, it's the result of using a different region code disc than the DVD player knows how to interpret. Try a different DVD.
If your TV doesn't have the Input button on the TV, you absolutely need a universal remote. However, you will want one that can match the TV/DVD button, the Input/Select button and the Menu button. Usually this requires a higher end remote; you also need a remote that was programmed at least 6 months after Sansui released the TV. If you do have the Input button on the TV, a universal remote may make using the TV easier.
I hope this helps.
Apr 13, 2015 | Sansui Televison & Video
Need code for Urc-3021 for memorex dvd player
I recommend using the auto-search function to find the code for your Memorex DVD player.
To program your URC-3021 remote control to operate your TV, the remote has a code search function.
To search for a code for your DVD:
  1. On the remote control, press DVD once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the DVD and slowly alternate between pressing POWER and DVD. Stop when the DVD turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Oct 28, 2009 | One For All URC-3021 Remote Control
Need the code for one for all universal remote to
The code for a URC-3021 to control a Toshiba DVD player is 0503.
To setup your URC-3021 for the DVD player, these are the steps:
1. Turn on your DVD.
2. On the remote control, press DVD once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5. Aim the remote control at the device and press POWER once. The device should turn off.
Hope that helps.
Oct 25, 2009 | One For All URC-3021 Remote Control
Need the program code for audivox avd300
The code for a URC-3021 to control an Audiovox DVD player is not listed in the manual. These are the steps to run through all the DVD control codes to find one that is compatible with your unit:
  1. Turn on your DVD player.
  3. Press and hold SET until the LED blinks twice, then release SET.
  4. Enter 9 - 9 - 1.The LED will blink twice.
  5. Aim the remote control at the the DVD player and slowly alternate between pressing POWER and DVD. Stop when the DVD player turns off.
  6. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Oct 24, 2009 | One For All URC-3021 Remote Control
Code for lite on dvd player
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
Feb 11, 2009 | Samsung BN59-00599A Remote Control
Need an instruction manual for an AWA DP602 5.1 dvd player for connection to a fujitsu plasma screen. will i be able to get TV channels programmed into the DVD?
IF YOU HAVE CONNECTED THE DVD PLAYER VIA COMPOSITE, COMPONENT, OR HDMI CABLES YOU WILL NEED TO USE THE REMOTE FOR THE TV AND PRESS THE SOURCE OR INPUT BUTTON TO CYCLE THROUGH THE INPUTS UNTIL YOU FIND THE ONE THAT YOU CONNECTED THE DVD TO. IF YOUR REMOTE DOES NOT HAVE THESE BUTTONS YOU CAN GO INTO THE MENU SCREEN OF THE TV AND PERFORM THE SAME THING USING THE MENU CHOICES.
HOPE THIS HELPS YOU. IF MORE ASSISTANCE IS NEEDED POST A COMMENT TO THIS SOLUTION AND I WILL TRY AGAIN.
Sep 15, 2008 | Televison & Video
Remote control codes
I NEED A MANUALINSTRUCTION BOOKLETFOR MY LITEON DVD DUAL RECORDER PROGRESSIVE SCANNER MODEL NO: LVW -S115GHC TO BE ABLE TOPROGRANNE THE MACHINE.
HOME ADDRES FLAT 69 NISBET HOUSE HOMERTON HIGH STREET HACKNEY LONDON E9 6AL
Jan 14, 2008 | Lite On LVC-9016G DVD Recorder/VCR
Sanyo lost remote
I had the same problem. Just got a DVD player and hooked it up and nothing. I got the Sanyo TV from a relative. Anyway channel 3,4 not work and when I go 00 still nothing. Then I pressed Input on the remote and a blue screen popped up. Turn on the dvd and now it works with channel 4. So I think any remote will work just put the tv to channel 4 and press input on the remote.
Dec 02, 2007 | Sanyo DS31520 31" TV
Universal remote
has anyone responded, I need the codes also.
Nov 05, 2007 | Lite On LVW-5115GHC+ DVD Recorder
I need a remote code for a lite-on LVC9006 so I can control my TV and my VCR -DVD combo with my satellite receiver remote. Any ideas ?
I've got a Lite-On DVD recorder and needed a code to sync it with my ARCHOS system. I found that the only code that corresponded with the 'ilo' products worked...
Oct 11, 2006 | Lite On LVC9006 DVD Player/VCR
One For All URC-8811 Remote Control Logo
141 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
