Question about Jenn-Air JCD2297KEY 36" 22 Cu. Ft. Floating Glass Side-By-Side Refrigerator w/ TriSensor Electronic ...
Ice maker is growing 3" long rusty icicles on the front of the unit.
    Sergeant:
    Champion:
  • 351 Answers
Need to replace ice maker
Posted on Oct 08, 2010
My Kenmore refrigerator's ice maker is dripping at the front of the ice maker. it drips slowly but makes a big chunk of ice right at the front of the bucket. What should I do?
This is pretty generic without a model # but holds true with alot of them..this type of icicle is usually caused by water overflowing the ice mold of the ice maker module. The reason for the overflow could be that the ice maker module is not level. Check to see if it is tilting. This could be caused by loose screws or a warping of the liner on the side wall of the freezer.
If the ice maker is level, then the next cause could be that the ice maker is overfilling. There is an adjustment screw on the right side of the front of the ice maker module. You may have to remove the cover from the front of the module to access this screw. Turn the screw counterclockwise to decrease the water fill. Turning this screw one turn may decrease the water fill level in the mold enough to prevent the leaking. If not, you may need to make a second adjustment.
Other problems that could cause this icicle could include:
Wicking of the water over the top of the ice maker mold caused by hard water deposits in the mold.
Leaking of the ice maker water solenoid valve.
Crack or leak in the ice maker module.
If the module is level and decreasing the water fill level does not solve your ice maker problem, then I recommend checking the ice mold for hard water deposits. If you find no deposits in the mold (or clean them and still have the same problem), then you will probably need a service technician to fix the ice maker. if you need more help, re-submit your question with additional details.
or reply in comments.
Jan 02, 2018 | Kenmore Refrigerators
Gritty substance in the ice cubes and icicles
Clean and descale the inside waterways with ice machine cleaner. Check hoses for leaks. Instal in-line filter
Apr 04, 2014 | U-Line Kitchen Appliances - Others
We have a Frigidaire Gallery side by side frig. We have had many problems, but yesterday it froze up with icicles hanging and big chunks of ice. My husband cleaned it out and thought it was OK. We woke...
First thing to check is where the ice maker actually fills up to make sure that its not full of ice and causing an over spray of water into the machine. You can actually take the tube out from the back of the machine. If there is no ice in the tube, next thing to do is make sure that the ice maker isn't over flowing and calling for to much water when its filling,. You can do this by either removing the ice maker and visually looking or by reaching in and feeling to see if the ice maker is completely full of water. If it is then either your ice maker is going back or the water valve is not closing when the ice maker is done calling for water.
Nov 07, 2010 | Frigidaire Refrigerators
No ice instead water dripping down into freezer making icicles
If you have icicles, where are they forming at? If on the front of the ice bucket, then look at the dispenser shoot door is closing all the way. The way to check that is to look into the shoot while holding a flash light (or bright light) up into the dispenser from the front side of door. You should see no light.
Now if you have ice buildup around the inside of bucket, mainly from the ice maker to the bucket then you either have an ice maker that is leaking water or you have a water valve that is not shutting off all the way. Suspect water valve if you have ice buildup within water inlet tube on top of ice maker. Frozen water within tube is good indication that water valve is leaking.
Look inside refrig side of refrig, usually located on right top side of wall, you will find a tag with model number and serial number. Need both to get you the right part number for ice maker or water valve.
Oct 08, 2009 | GE Profile PSW26P Stainless Steel Side by...
Icicle are forming around icemaker port inside of freezer compartment drips seem to come from around inmaker feed water area.
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Sep 17, 2009 | Kenmore 53642 / 53644 Side by Side...
Not making ice
replace complete im and water filter , 100 % it will work :)
Jun 26, 2009 | Amana Refrigerators
Ice maker is dripping and forming an icicle at the front right of the ice maker
you need to defrost the drain hole and clean it out... sounds like it is frozen
May 23, 2009 | Maytag MSD2756G Side by Side Refrigerator
Jenn-Air JCD2297KEY 36" 22 Cu. Ft. Floating Glass Side-By-Side Refrigerator w/ TriSensor Electronic ... Logo
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
