Question about Intel Motherboard
I'm using a program called Speed Fan, and I'm getting a reading from a sensor that the program calls Remote 2 every time I try and do anything even semi graphics or CPU heavy, (like 30% cpu) this sensor jumps almost immediately up to 160F. The cpu fan also spins up to 100% immediately. There are no temperature readings in my BIOS for me to compare to, so I can't figure out what is causing this over-heating problem. I downloaded another temp monitor and it calls the temp sensor System. Could this be my northbridge?
  • Intel Master
  • 7,733 Answers
Here are a table of Max CPU temps ->link.
Posted on Oct 06, 2010
How do I re-program my Remote Control with automatic starter on my 2009 Town and Country Van
My experience with frequently-used vehicle remotes (any make) is this:
1. When relatively new or in good condition, if remote stops working, the button battery inside is dead or too low.
2. If battery is new, & remote still doesn't work, a solder joint on the circuit board inside may have come loose or broken.(You can try re-soldering using a low-heat pencil iron & thin RESIN-core solder -- even if you're not great at it, what do you have to lose?)
3. It's rather unusual for even an older, well-used remote to simply lose its programming.If this is the problem, it may be cheaper to buy a new after-market remote (or pair of remotes) that you can program yourself (only works with some brands & years of vehicles, so READ THE INSTRUCTIONS ON THEIR WEBSITE BEFORE BUYING AN AFTER-MARKET REMOTE), instead of going to the dealer for a normally HIGH-priced programming job.
4. Used OEM remotes that match yours exactly (check the part # of your remote & the used one you're considering) can often be purchased from a local auto wrecker (now called "auto recycler") for cheap ($5 to $10 is common), but will need programming.I always go thru the many they have, looking for one that appears new or like-new.
5. IF YOU MUST GET PROGRAMMING FROM A DEALER, usually it's the SAME PRICE whether you have 1 remote or several remotes/keys programmed at the same time.Since dealer programming is pricey, I always have 3-4 remotes and/or chip-keys programmed at the same time.(My dear wife loses chip-keys & remotes from time-to-time, so I keep a few spares on-hand.I've found inexpensive after-market chip-key blanks at some key cutters and/or auto parts stores, altho they still require programming after the copy is cut from yours.)
CAUTION
:Some OEM anti-theft systems require that ALL remotes & chip-keys be programmed/re-programmed at the same time, whether they're original, used or new.Determine this IN ADVANCE, so you know what you're faced with.The good news is that for those vehicle manufacturers, dealers normally don't charge more to program/re-program multiple remotes and/or chip-keys, if all are being done AT THE SAME TIME.
6. If all else fails & you MUST buy a new OEM remote (which will require programming), try 2 things -- First, see if the dealer will make you a package deal on buying the remote (or 2 remotes, or a remote & a chip-key) AND doing the programming for a lower combined price.Second, it may be cheaper to buy a new OEM remote from a dealer who's had one in stock for a long time & wants to blow it out (or buy from online OEM seller) & then pay the normal programming price.See the CAUTION above.
There are lots of options here, so hopefully something is useful to you.
Feb 23, 2015 | 2009 Chrysler Town and Country
How do i turn off the fan?
Normally, the fan is controlled by a temperature sensor located in the control compartment under the fireplace. If I remember correctly, the sensor activates at 110 degrees F. There should also be a speed control rheostat located above the valve. It will adjust the speed of the fan or you can turn it completely off. If the fan was running when the burner shut off, it will continue to run until the sensor cools to 110 degrees F or you can simply turn the rheostat to off. The Smart Stats dont control the fan unless you have the upgraded Smart Stat HNG. The upgraded version will have a button on the handheld remote that reads "Fan". If that button does not control your fan, you will need to call a service tech to check the wiring. The function could have been missed when it was installed.
Jun 21, 2014 | Skytech Smart Stat Fireplace Remote for...
How to increase fan speed acer aspire 4937 the diagram or the cable from the fan changed the connection to run continiuosly
Get a program called speedfan this will allow control of the fan regardless of anything.
http://www.almico.com/speedfan.php
link ABOVE
May 12, 2011 | Computers & Internet
Have a 2 stage 70000btu 2 stage furnace by goodman. I have hooked up a honeywell steam humidifier. and when it calls for humidity the high fan speed does not kick in. The only fan speed that kicks in is...
Sorry to read about your problem, I hope this helps you out.
well its best to let the low fan do the humidity work, and not the high.. you did not provide the model of the goodman, but you ether went direct to the heater control card, to the humidity connection . or wired to the low side call contacts. you can hook the humidifier to the high fan speed contacts
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Goodman Heating & Cooling
When the Casablanca fan remote control wall button is pushed the fan beeps and progresses to the fastest fan speed and stays there. How do I adjust the fan to be able to vary the fan speed so I don't have...
the button may get stuck or the sensor may be off.... also it could be that the setting is backwards on the fan to start on the fastest and end on the slowest
Dec 01, 2010 | Casablanca Fan Dryers
I have a ceiling fan that has no reverse switch or speed chain, it was bought used...the fan obiviously can work only from a remote....i'm always going to use the fan in the counterclockwise position on...
You're going to have to have the remote control for it. Call Hunter at 1-901-745-9222 when the recording comes on, press 8, then 1, then 1 2 or 3. Give them your model # and they will get you hooked up with a remote. They may even give it to you for free, but they may make you pay for it.
Apr 01, 2010 | Hunter Ceiling Fan Control Switch
Macbook pro, high CPU usage caused by HPImager? HELP! :S
Try going to system preferences, then click on accounts, then click on login items, and then delete all the startup programs you see there. It doesn't delete the actual programs. It just deletes them from automatically starting. Also, there is a free utility that you can use to adjust fan speed upon startup. Its called SMC fan control and you can Google it for download.
Jan 26, 2010 | Apple MacBook Pro Laptop Computer with...
2001 volvo s440 1.9t
Volvo Radiator, Thermostat and Sensors Your cooling system's temperature controls include all coolant temperature sensors, Volvo thermostat, Volvo radiator or expansion tank cap, cooling fan(s) and fan clutch (if equipped). These cooling system parts function primarily independent of the engine but control the engine either through cooling or by sending control signals to your Volvo's electronic systems.
The Volvo thermostat is a spring-loaded valve that opens and closes based on the temperature of the coolant flowing through it. A high temperature reading followed by a drop to normal temperature (or a continuously low temperature) is a common first sign of a sticking Volvo thermostat. However, many other conditions may cause these symptoms, so you need to know how to eliminate each possibility.
The Volvo radiator or expansion tank cap is also a spring-loaded valve reacting to system pressure. It serves to maintain proper system coolant level at predetermined pressures. It must always be replaced with an exact replacement cap with the same pressure setting. Never use other caps except for short-term emergencies!
A belt-driven fan blade for pulling air through the Volvo radiator is usually on the Volvo water pump pulley and should have a fan clutch to control it. The fan clutch allows the fan to turn with the belt at low engine speed and "free-wheel" at higher speeds. A bad fan clutch either doesn't allow the fan to spin at low speed (overheating in traffic) or doesn't allow it to free-wheel at high speed (potential overheating on highway or reduced gas mileage).
An electric fan can be either by itself (usually front-wheel drive) or auxiliary (used with a mechanical fan). Both types are controlled via a temperature sensor - in the Volvo radiator or upper Volvo radiator hose or on the Volvo thermostat or Volvo water pump housing. This sensor is usually an on/off type switch with a fixed temperature setting. (Some vehicles may have 2-3 settings for multi-speed fans.) This sensor is commonly called an "auxilliary fan switch".
Other common temperature sensors are: 1) gauge sender (variable output); 2) warning light sender (on/off type); 3) lambda and/or fuel injection sensor(s) (variable to control fuel injection settings); 4) thermo-time switch (cold start valve control). Your Volvo may have other sensors as well.
Temperature control is critical to both performance and emission control. Unfortunately, this system is the most difficult to troubleshoot without proper equipment and diagrams. It's even more difficult with computers that adjust timing, idle speed, vacuum and fuel delivery automatically to make up for potentially faulty temperature sensor signals.
Maintenance of your cooling system sensors is virtually impossible since there's nothing really to "maintain". Keeping them clean both internally (coolant replacement) and externally (engine cleaning) is the best way to ensure trouble-free driving. Checking and replacing all parts at the factory-recommended time or mileage limits helps as well
Jul 23, 2009 | 2001 Volvo S40
Fan is slow
I dont have a solution, but I have a similar problem with a Bonaire evap rooftop cooler which only started after a tech came to look at the unit when it stopped operating properly last summer. He said it uses less water now, but the issue is that it doesnt cool any where near as effectively with the fan speed so low. I am located in Melb Australia, and wonder if you are in the same area. I am going to call service AGAIN & get the minimum fan speed returned to what it was previously. I wonder if my original unit is too small for the house - but nevertheless, it used to work beautifully and now is a very poor example of evap cooling. The service guy said the base fan speed could be altered from the controller, but we dont know how to get into the setup menu.
Jan 30, 2009 | Dometic Rooftop RV Air Conditioner
Intel Motherboard Logo
75 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
