I have a RISO paper duplicater GR1700. When I make a copy, the image only burns on half of the master. When the copied sheet comes out of the machine, the copy displays half and the rest of the dupicated sheet is blank.
    Genius:
  • 1,456 Answers
Hi there
Turn off equipment,open cover remove drum and toner unit.
Set aside on old newspaper and cover it with cloth so the light wont damage the drum.
Take your flashlight and look for a shield or glass about 8 inches long
usually on the surface that the cartridge rests on. Clean with swab and alcohol.
If you cant find a glass or shield look towards the cieling of the inner chamber of the copier it may be there or you may find an led array which is dirty. Clean carefully.
Insert cartridges and test.
sometimes the cartridges are dripping toner and the shield gets recontaminated .so now you have a different void. Reclean shield make sure you don't drip toner on it.
Posted on Oct 06, 2010
Why is my photocopier only printing half a page?
Sounds like one of the sensors in the doc feeder that detects the size of the paper has gone bad.
Also, make sure you always close the document feeder when making copies. Sometimes it helps to put a blank sheet of paper over the back of a small object if you're copying something small.
Copier Collin Houston TX Copier and Imaging Expert
Aug 18, 2014 | Sharp Office Equipment & Supplies
When i copy using my ricoh aficio 3350 the machine cut the image in half, please help
Have you checked that you are 'telling' the copier to use the correct size of paper? You need to tell it that you are using eg an A5 image sheet and an A4 output sheet. The normal default is A4 for both.
Jan 07, 2014 | Ricoh Aficio MP3350
Can you use Riso GR1700 drums in a GR2700 or GR2710 machine? If so, is the ink also interchangeable?
The masters and ink should work. Cannot remember if the drum does. Put in the duplicator it will either fit or it won't. It will not damage the machine unless you try to force it in. If compatible it will slide right in and the machine will recognize it when you close the front door.
Mar 09, 2011 | Riso Office Equipment & Supplies
Spots on master
THE DRUM THAT MAKE THE COPIES IS DURTY OR HAS DRYED INK ON IT AND IT TAKES A SPECAL CLEANER, I CAN NOT EVEN SAY THE WORD OR EVEN SPELL IT FOR YOU
TRI ETHI LINE, CALL A COPY MACHINE COMPANY OF GO ON LINE TYPE IN MANIFACTURE NAME ONLY RETURN ,
THE CORRONA WIRES THAT MAKE THE ELECTRO STATIC IMAGING MAY ALSO NEED TO BE CLEANS, Q-TIP AND ALCOLHAL WITH A VERY SOFT HAND OR YOU WILL BRAKE THE WIRE AND THAN YOU WILL BE WITHOUT A COPIER
CANDYMANGANDY
Jan 29, 2009 | Riso RZ310 Duplicator
Riso rc6300 registration not correct
ou need to either advance (paper feeds quicker) or elay paper feed there has to be a registration adjustment
It can be as simple as adjustment of the feed wheels or some type of delay in the drum rotation
take alcohol and clean the feed rollers they may be slipping
Dec 27, 2008 | Riso RZ220 Duplicator
E11 on riso gr 1700
When machine displayed E-11 it’s interrupted the operation.
Its means Pressure Control Motor Lock –
If the Pressure centering sensor does not detected on & off within 5 seconds from the start of the machine.
This problem is the engine of pressure, this is located by uncovering the back, more or less in the middle and bottom, there is a small motor that is attached by screw(s). When the machine is turned on its intial position should be detected and if not , the sensor can be bad or the starting position is dirty or broken cable, or motor cables are bad, inspect them, reset the code and turn the machine off and back on.
Dec 21, 2008 | Riso RZ220 Duplicator
Problem on Riso GR1700
Sometimes it is a one way pully inside the drum that is slipping.This is a mission to repair.
If you want to try it let me know.
Sep 30, 2008 | Riso RZ220 Duplicator
Feeding error
need to clean or change the tires that pick up and seperate hte paper in the paper tray
Sep 23, 2008 | Riso RZ220 Duplicator
Riso
probably needs a new adf stripper pad.. the first little rubber pad on the bottem of the inside of the adf
Aug 11, 2008 | Riso RZ220 Duplicator
49 people viewed this question
k24674
jasbo
jasbo
