Question about York Barbell Home Use Fold-Up Treadmill
My York t302 threadmill motor starts to keep strange noise after some running. Motor has been changed once as well as whole threadmill. So this is my third motor and problem still exist. Here is the video/audio of the problem. http://www.youtube.com/watch?v=PSHBZbO94-s Is this normal sound from motor? At least it is disturbing...
I just had a noise in my York T301 that sounds exactly the same as yours. It also came up with a E1 error code and stopped working. I pulled the motor hood off and noticed that the magnet in the drive pully had come dislodged. It was hitting the speed sensor near the belt. Glued magnet back in and all better. Hope this helps.
Posted on Jan 10, 2011
Threadmill does not always start
There would be some problem in wiring harness between motor control board and control panel. Try to remove form both side an reconnect it
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 10, 2016 | FreeMotion Xtr 90 Treadmill By Free Motion
Tip
How to prevent threadmill from shutting down.
Some threadmills will shutdown due to overloaded heat sensors on motor drives.To possibly prevent that from happening it is wise to keep machines away from dusty conditions and places where dust balls can form and to vacuum them at least once a month.
on Aug 06, 2011 | Sears Exercise & Fitness
I have different issues with threadmill
Sounds to me like the motor has a shorted field coil or open or shorted armature. The motor is bad, you can order a new one at the companies website.
Jun 09, 2014 | Nordic Track NordicTrack A2550 Treadmill
York Runner 61820 won't run
the motor is faulty. That is why its warming up fast than usual. Motor is consuming more current thats why the relay cuts the power. change the motor.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Feb 21, 2014 | Exercise & Fitness
When I step on the threadmill deck, it stops working. Why?
1) You must LUBE inmediately the deck belt, this problem happen because the lack of maintenance. The machine has a device for protection for the electronic system, producing a shut down for to keep safe the electronic.
2) You must LUBE the rollers bearings too very well
3) Test the voltage input for motor, if there are the motor NEED REPAIR.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the block .God bless you
Sep 03, 2012 | Exercise & Fitness
I have a proform 650 v threadmil, and the left side of the buttons panel (start button and incline levels) don't work. could someone help me?
1) tight all connector wires and clean
2) tight the ribbon cables from keypads.
3) Run the software calibration for diagnose, and troubleshooting, and fix it.
4) lube the shaft and gear in the elevation motor,
5) adjust the potentiometer for better running see the diagram.
God bless you
Jun 19, 2012 | Proform Exercise & Fitness
York T101, motor will not start, display is fine.
1) LUBE THE DECK BELT, IN ACCORDING WITH THE INSTRUCTION MANUAL.
2) lUBE THE ROLLERS BEARING
3) tEST THE INPUT VOLTAGE MOTOR, IF THERE ARE THE MOTOR NEED REPAIR.
4)tEST THE OUTPUT VOLTAGE BOARD, FOR INPUT VOLTAGE MOTOR, IF THERE ARE NOT THE BOARD IS FAULTY.
SEE THE BLOCK DIAGRAM ATTACHED.
God bless you
Jun 07, 2012 | York Exercise & Fitness
Motor drive belt on C2200
you must first loosen the screws on the back of the runner, once loosened the belt you still have the motor driver is also let up, remove the engine belt and you can see that the front roller has a screw, take it off and now withdraw the roller and belt bags on one side. to put the belt you follow all these steps again to reverse
Feb 09, 2010 | Exercise & Fitness
My kenmore refrigerator kept running.
from your description it sounds like your hearing the start relay trying to start your compressor. most likely this relay is bad and needs replacing.
Dec 18, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
York Barbell  Home Use Fold-Up Treadmill Logo
843 people viewed this question
Top York Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
ray gallant
Are you a York Exercise and Fitnes Expert? Answer questions, earn points and help others
