Question about DISH Network IR Remote Control
The remote to the secondary tv keeps requiring new batteries. I had the same batteries for years and then got the remote battery low signal on the screen. I replaced the batteries with new batteries. Remote began working again but with in a week remote battery low signal came on screen again and the remote stopped working. So again I replaced the batteries and they lasted on 4 days and the remote battery low signal came on screen and the remote stopped working. I can not afford to keep replacing batteried every few day. What could be the problem to keep requiring new batteries when the old set lasted for years.
  • 374 Answers
There is an internal component that has failed on the remote. Replace the remote and your issue will be solved.
Thanks for using Fix Ya.com.
Posted on Oct 19, 2010
Hisense TV, remote keeps using up my batteries, only last a week or two.
seen this battery issue reported online before with these remotes
depending on age and model of that TV
you can buy new original ones
dont buy universal types for a hisense
is it the original remote ?
what brand of batteries
lithium energizer?
info
rechargeable batteries never fully charge up
only two needed
size is AAA or AA
Oct 23, 2016 | Cars & Trucks
My remote is red light is flashing. I changed the batter and the battery in the unit is working. I can turn on the fireplace manually
  • The usual indication for a flashing light is a low battery. Suggest checking the remote again. Especially for corrosion at the battery terminals.
  • When you operate the remote will the receiver flash its LED indicator confirming that the command has been received.
  • The manual operation of the receiver located at the fireplace likely does not require batteries. For remote control operation good batteries are required.
  • If the red LED on the receiver is flashing the batteries need to be replaced.
  • If the LED at the receiver indicated that the command is received check the wires to the control valve from the receiver. The voltage is a very very low a millivolt signal.
Dec 01, 2015 | Heating & Cooling
Why do batteries keep going dead in my TV remote?
Short circuted IC or any other component.
Apr 30, 2014 | Televison & Video
Tv cable and dvd lights keep flashing and tv doesn't get signal
The remote is in safe mode, remove batteries and reinsert batteries while keeping the button 2 pressed.
Aug 04, 2012 | Logitech Harmony 200 Universal Remote -...
Remote will not charge battery
1) the remote do not charge any batteries.
2) if the batteries discharge vey quickly, this means that some components inside from r.control is in short circuit.
You must go to the repair shop TV for fix it. see the diagram attached
God bless you
Jul 16, 2012 | Televison & Video
The tv doesn't react when pressing the power button. What can I do to fix this?
Things You'll Need:
  • Batteries
    • 1 Press the "TV" button and then press the "Power" button on the remote. If the TV turns on, your remote was just switched off of TV mode.
    • 2 Reprogram your remote to your TV. Universal remote controls can be accidentally unprogrammed by sitting on the wrong combination of buttons or having the batteries disconnect from the inner connections.
    • 3 Unplug the TV from the electrical outlet for a few minutes and plug it back in. This will reset the TV in case a power surge caused the TV to become "confused."
    • 4 Replace the batteries with new ones. Do not use old batteries from a different device in your house because if the batteries do not work, you won't be able to determine anything because those batteries may not have enough juice to power the remote. Keep in mind that different devices have different needs, so the batteries may have had enough power for something else to work but not enough for your remote.
    • 5 Check the batteries to see if they are inserted in the right direction. It's possible that someone dropped the remote, the batteries fell out and then were inserted incorrectly.
    • 6 Press the "Power" button on the TV set to determine that the TV is not dead. A dead TV will not turn on from a remote.
    • 7 Program the remote to another TV. If the second TV works from the remote, the problem is with your TV's remote signal receiver
Jan 17, 2011 | Sony Rm-yd035 Remote Control
Tv keeps turning on an off on its own
This is a shot in the dark... but maybe your remote on/off button is stuck. remote broke/batteries low. Any new wireless devices in the room? If none of the above I would guess that the power button or the remote signal reciever on the TV itself is shorting out. I hope this helps.
Nov 29, 2010 | Hitachi 57F500 57" Rear Projection...
Remote does not work for samsung ht-c550 Lights work when the button is pressed but the device is not receiving the signal.
The batteries may be to low to operate the IR transmitter, but still turn the lights on when you press a button.
If you have a cell phone with a camera, turn the camera on and look IR transmitter end of the remote. It may have a dark red lens. Press some buttons on the remote, and you should be able to see the IR signal in the cell phone. If not, try new batteries in the remote. If that does not work, it could have a problem with the code for the TV. Try to reprogram the TV button.
Nov 11, 2010 | Samsung TV Remote Control
Don't have original remote control. Somehow, a window for PIP opened, and I can't get it to turn off. Have a new sony remote RM-V310A, but the PIP button won't activate the remote. Any...
Many TV functions can be controlled from the on-screen menus using buttons on the TV itself. These include all kinds of settings however Sony did not include PIP in these menus. Therefore a valid remote is required to operate PIP. One thing you could try is removing the cable from the secondary input on the TV which provides the signal for the other picture. Without an input signal PIP may be disabled. Also, try buying a universal remote and setting the proper code for your TV. Original remote could be hard to find but remotes.com may have one.
Aug 05, 2010 | Sony KV-27S45 27" TV
DISH Network IR Remote Control Logo
520 people viewed this question
Top DISH Network Televison & Video Experts
brian soufane
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
