Question about HP ScanJet 3970 Flatbed Scanner
Need set cd for scanjet3970. changed computers have vista
  • HP Master
  • 7,733 Answers
HP Support Drivres ->LINK.
Posted on Oct 06, 2010
Windows Vista won't load after a full factory restore on my dell dimension e521 ?
Go into your BIO's at startup and set it to load from the CD-Rom only. Then drop the Vista disk in the CD-Rom and restart the computer. After it loads you will need to go back into the BIO's and set it back to where it was before you made this change.
Oct 10, 2009 | Dell Dimension E521 (D10E16) PC Desktop
Tip
How to Change Windows Password on Windows 7/Vista/XP?
Setting a password on Windows 7/Vista/XP can add a level of security to your computer. So you are often advised to set a password on Windows. In addition, it is highly recommended to change Windows password regularly. And it is a good habit to keep your PC security by changing Windows password. Here are some simple methods to change Windows password among Windows7/Vista/XP.
Method 1: Change Windows password by using Control Panel.
The steps to change Windows password have a little different on different Windows systems. The following steps are based on changing Windows 7 password.
1. Click Start, Control Panel and User Accounts in order.
2. Pick the specified Windows account whose password you want to change.
3. Click on change my password.
4. Enter your current password and type a new password, and then click Change Password button.
Note: you may need appropriate privileges to change the password of another user.
Method 2: Change Windows password by pressing Ctrl +Alt +Del.
It is the easiest way to change Windows password for Windows 7, Windows XP and Windows Vista.
1. Press Ctrl + Alt + Del when you log onto your Windows XP/7/Vista PC.
2. Click on Change password.
3. Type your new password, type your new password to confirm it, and then press Enter.
Note:
1. If your press Ctrl+ Alt +Del when you log onto your Windows XP, it will show you the classic security options instead. Click Change Password to change Windows XP password of the logged on user.
2. If the security options does not appear. Task Manager shows up instead of the security options. Just go to Start, Control Panel, User Accounts and Change the way Users Log on or off. And then uncheck Use the Welcome Screen.
Method 3: Use lusrmgr.msc to change Windows 7/Vista/XP password.
The following steps are operated to change Windows Vista password.
1. Click Start button and input lusrmgr.msc into the Search box.
2. In the coming Local Users and Groups screen, double-click Local Users and Groups, and then click Users.
3.Right-click the account that you need to reset the password for, and then click Set Password.
4. Type and confirm the new password.
Method 4: Change Windows password with Windows Password Unlocker
Windows Password Unlocker Standard allows you to change lost or forgotten password on Windows 7/Vista/XP.You can adopt this method to reset Windows password when you are locked out of computer without a password reset disk.
1. Download and install Windows Password Unlocker Standard in any accessible computer.
2. Run the program and insert a bootable CD/DVD or USB flash drive.
3. Burn an ISO image file to the CD/DVD or USB flash drive.
4. Set your locked computer to boot form CD/DVD or USB drive.
5. Change Windows password with the burned CD/DVD or USB drive
These are the simple methods can be applied to change Windows password on Windows 7/Vista/ XP. Of course, there are some other ways for your choice. Please remember your changed password. It is often for one to forget Windows password after changing it. Otherwise, you'll need to bypass lost Windows password with Method 4 if you are locked out of computer.
on Oct 20, 2010 | Computers & Internet
I am trying to Downgrade an ASUS R1F from Vista Pro to XP Pro. How do I get the tablet to boot from the CD
Hi, if you have computer knowledge, the easiest thing to do is to take the laptop sata hard drive out and connect it to your computer with your sata cables and power and boot your computer up and the laptop drive will be a slave drive then. Now you can back it up if you want and then format it.
Now turn your computer off and put the hard drive back in your laptop. Because there in no Operating system the laptop will ask for a boot device. Now you will be able to boot from your xp cd.
I don't know why but I have found most laptops and computers with vista don't like to boot from a cd and over ride the boot options and go directly into vista which makes it hard for people who want to down grade to XP.
Why someone would want Vista beats me.
You can also load up into bios and change your boot options in there. If not already set as first boot device to be you cdrom/dvd you can change it to be. But like I said most of the time with Vista it doesn't matter! Vista will still boot first. But it is worth trying.
Sep 26, 2009 | ASUS R1F Tablet PC
Can't install new OS
you need to install directly from the vista disc when the computer is powered on, put the disk in and it should ask you to press any button to start from cd..
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter boot menu, it will very likely be button F12 or similiar, it should say on the screen when you power on.
if it doesnt, then you need to go into the bios and change the boot order so that the computer starts from the CD first. the computer should say what button to press to enter bios or cmos or setup when its turned on
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
heres some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
ones you get into the vista setup you can empty the hard drive, getting rid of windows xp and then install windows vista over it.
Let me know how that goes,
Thanks,
Ekse
Jun 03, 2009 | Toshiba Portege R100 Notebook
Changing operating system from windows vista to windows xp; how to install a bluetooth device
You can change your OS from Vista to XP by try to follow the ff. steps:
1. turn on your computer then press Delete key to enter in BIOS Setup as to set your system 1st boot to CD thru the BIOS advance feature or you may press F8 key to select the CD 1st boot device. then F10 to save changes in your BIOS setup.
2. then, insert you CD with XP operating system in your computer CD/DVD device & just read / follow the next steps that will appear on Screen.
Hope this would help. Best regards.
Apr 22, 2009 | Computers & Internet
NEED WIZ HELP- UNABLE TO BOOT FROM XP OR VISTA
dont mind it...
if you want to install xp to your computer while you are using utimate vista you can install it...
but you must have a large space of memory to install xp, tnx anyway hope that i can help...
Jan 08, 2009 | Microsoft Windows Vista Ultimate Edition
NEED WIZ HELP- UNABLE TO BOOT FROM XP OR VISTA FROM DVD DRIVE
first you must check your XP/Vista cd if it is bootable then open the bios setting change the first boot to CD ROM save and exit the bios insert CD wait for a second if the CD is BOOTABLE if so then follow the instructions of formating drive. But before you do that you must be sure that you have all the driver need to you PC for security you must use the black drive then install the XP OS.
Jan 07, 2009 | ASUS A8N-VM CSM (00610839133826)...
XP and Vista
If you have the installer of windows xp you can change the vista to xp. First check if the booting options is set to cd/dvd boot. In the cmos setup change the booting option from hdd to cd or dvd. Then insert the xp installer to the cd in follow the setup instruction
Apr 14, 2008 | Computers & Internet
Windows vista home edition
Do you have the vista installation/restore disk that came with your computer?
First you need to backup everything thats important just to be safe (fotos/douments etc)
Then you need to make sure that the pc is set to boot from the cd drive first. Easy way to find out is to just put the disk in the drive and restart pc.
If it just starts normally then you have to enter the bios to change the boot order. This is normally done by pressing "delete" or "F2" just as computer boots.
If it is set to boot from cd then a message will appear "press any key to boot fron cd/dvd" and u push any key and it will start from the cd/dvd.
You will then need to choose the partition/hard drive that u want to install on which will be "c"
Then you will need to put in your vista seriel thats on a sticker on the pc.
It will then take a while to instal vista.
Once installed you will need to go to the manufactures website to download the various drivers for your computer model. To be safe do this before hand and save them to cd. Dont forget to make sure u have your modem drivers handy too!! :) No worries though if you are using a router.
Dec 28, 2007 | Microsoft Windows Vista Ultimate Edition
Donwgrade to xp
put in the xp disk and boot from the cd (restart the laptop)
if it does not pick up the cd rom on boot you need to enter the
bios settings and make the first boot device the cd drive
then follow the on screen instructions
if you need further help dont hesitate to ask
hope this helps
Nov 12, 2007 | Computers & Internet
HP ScanJet 3970 Flatbed Scanner Logo
21 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
