Question about HP Office Equipment & Supplies
I have an HP J 5870 All-in-One printer; Error message says, "Carriage jam". There is no obvious jam, carriage moves freely and I cleaned up the ink puddle under the black cartridge. Can't clear the error message.
  • 3 Answers
If the carriage moves on it's own, then the message comes on, you may need to look for the carriage home possition sensor and clean it. the sensor will be located at one end of the carriage travel. THe carriage will likley have a tab that will pass through a slot in the sensor. the best way to clean this kind of sensor is to use canned air. good luck.
Posted on Oct 06, 2010
CARRIAGE ERROR
your ink cartridges carriage may be jam.
unplug the printer
check if the carriage can move freely
Jan 02, 2014 | Office Equipment & Supplies
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
My HP Officejet J4680 states that there is a cartridge jam. How do I fix this?
this issue is a little tricky as the unit may think there is a paper jam
first make sure the craddle - where the ink cartridge sit - can move freely, if it can then look for any bits of paper that may be stuck around it or in the machine, clean the rollers on the rear access door of the unit as well.
if the error message doesnt clear out then try the next step
If the carriage chute will not move then disconnect the power cord press and hold # 3 at the same time and as holding those 2 buttons re connect the power cord. if the carriage fails to move upon reset then you have a carriage jam and your printer needs servicing
Mar 29, 2010 | HP J4680 Office Jet All-In-One Printer
Carriage jam - Turn machine on, get carriage jam message, however the carriage can move freely if moved by hand. If I close and hit enter, carriage sounds like it's moving, then I get the error message...
Sorry about the B.S., you can move the carriage by hand, and all you need is to clean the encoder strip that runs across behind the carriage assembly. You can wipe the strip gently with an alcohol swab or a Q-tip moist with alcohol. The bars on that strip tell the carriage where it is and grease or ink on it will give the carriage jam error. No calibration necessary after moving the head or cleaning the strip.
Jan 07, 2010 | HP OfficeJet 7410 All-In-One InkJet...
The printer carriage is jammed
hi first of all open the front cover of the printer and try to move the carriage mannualy by your hand while the printer is on now if the carriage is moving freely look if you see any obstacle or any broken part in the carriage rod .... clean the carriage rod with a soft cloth and then remove the in cartridges and close the front cover now while the printer is power on press and hold # and 6 and unplug the power cable while pressing the buttons and then wait for 5 sec and then plug the power cable back and now relese the buttons
wait for the printer to initialize now power on the printer and then wait for the message to insert the ink cartridge insert the ink and see if this works
if you still face the same error then it means its not a firmware error its a hardware malfunction problem and the device needs service
if you face any other problem while following the steps do let us know
Aug 31, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My HP Officejet 7210 all in one is showing the following error message: Carriage Jam. Open carriage door, clear jam, then press ok". There is no jam, I have looked through the back door and the front of...
Carriage jam means the carriage, where you put the inks, can't move right to left properly. Sometimes ink on the clear strip behind it is the cause. You can carefully clean with damp Q-tip, and check also that the cleaning assembly on the right where the printhead parks, is not stuck.
Jul 24, 2009 | HP Officejet 7210 All-In-One InkJet...
I am receiving an error message on my HP Officejet 6110 printer screen that prevents the printer from functioning. The message is "Open door. Clear carriage jam and then press enter." I've tried opening...
yes, that is a carriage jam and not paper, the grinding is from the clean station that gets blocked with dried ink and cant move. you need to open the printer and clean the ink off of the clean station so it can clean properly and not cause a carriage jam.
Jun 29, 2009 | HP OfficeJet 6110 All-In-One InkJet...
E-90 error message on the printer
Hey Pretty Joy,
I had the same error and looked at the suggestions. It seems all of the user correctable problems are related to the ink carriage not being able to move freely (mine was a paper jam). Open the lid and see if the carriage will move,
May 05, 2008 | Epson Stylus CX6000 All-In-One InkJet...
Carriage is jam, black is in the wrong place
I have had frequent "carriage jam" messages from my HP 2355. I would open the lid, move the carriage back and forth many times, unplug it and then restart it, and eventually it would start printing again. Today, however, this did not work.
I resolved to either fix it, break it or throw the printer away. Lucky for me, I finally found the root cause of my problem.
Under the spot where the cartridges "park", there is a platfrom that has a few wipers on it. Mine was covered with old, dried ink. I discovered that this platform is supposed to move, front to back.
Mine would barely move. So, after pushing the carriage out of the way to the left, I pushed this platform toward the rear of the machine and then sprayed the area judiciously with Simple Green. Then, I used an old toothbush and paper towel to clean the sliding surface and generally removed crud from it. Latex gloves are highly recommended!
After this, I moved the platform back and forth and continued cleaning until it moved smoothly and easily. It solved the problem and the printer does not need to take up landfill space!
May 04, 2008 | HP PSC 2355 All-In-One InkJet Printer
Carriage Jam
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Apr 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
263 people viewed this question
Seeker5211
Seeker5211
