Question about Celestron NexStar 5 SE (300 x 44.45mm) Telescope
I am unable to illuminate my Hand Control, either with a 12V AC Adaptor or with new batteries.
  • 3,186 Answers
Get a new hand controller cable. They fail regularly. If it still does not work then it is a problem with the hand controller or the internal circuit board.
If after you replace the cable it still does not light up-- borrow a hand controller and see if it works with a different controller. Beyond that you must return the scope to Celestron for repair.
Posted on Oct 06, 2010
Input is 240V-50Hz 250mA Output 12V-2.9A. The current adaptor is listed as Inspire M5300. It is for a Creative Sound Blaster 5.1 speaker system
In electronics, don't believe, be sure. When it does not say AC, see what is next to it. The ~ sign means AC. The = sign means DC. I know lots of speaker systems use AC, but check the sign.
Apr 16, 2015 | Audio Players & Recorders
No radio or AC after battery replaced
you have a blown fuse. make sure the battery is in correctly. the neg- neg the pos to pos.
Nov 21, 2013 | 2005 Nissan Murano SL
Where can I find a replacement 120v ac adaptor for a Thor X flashlight?
My Thor X 10 million candlepower spotlight takes a standard 12 volt, 1500 mA, center positive AC adaptor. You should be able to find one with an appropriate tip at any Radio Shack store, but you may find a cheaper universal adaptor at a Walmart or even at a "Dollar Plus" kind of store. An adaptor with a lower mA rating will take longer to charge your light, but it should still work (down to about 750-800 mA, I'm guessing).
Double-check the charging port of your Thor light to see whether there's any information about the input voltage requirements. On mine, the light itself has the charging port labeled for 12v, though I was reading the more detailed specifications off the adaptor itself. I can't recall whether the 2.5 million candlepower light also uses 12 volts of power (I think it does), or whether it takes 6 volts (a single battery vs. two batteries wired in series).
May 18, 2011 | Cyclops Thor 2.5million Rechargeable...
Batteries
I think you will find that one 9 volt battery would not last any time at all. the 6 AAs have a big capacity and that's why they use them, a little 9v battery is intended for low power equipment.
I see it is supplied with a 12v AC adaptor, if you connect a 12V battery via the adaptor socket you may get a longer run time if its a rechargable battery even better.
Jan 22, 2010 | Meade NIghtView NIght Vision Monocular
Ac adaptor on my 32 Protron inch LCD TV no longer work
What is the current output of the adaptor? If it is AC and you use only the 12v to 3v it is ok. But if the current output of the adaptor is DC and you use both 24v to 6v and 12v to 3v there is some danger if use the new one. Remember that DC current have polarity.
Aug 29, 2009 | Protron PLTV-32 Television
Alternative 4-PIN 12V AC Adaptor
I've got the same problem. Did you finally find a solution?
Jan 25, 2009 | Televison & Video
Defect in AC adaptor
Traggio,
It's seemd you need a new AC Adapter. You can get a new Universal AC Adapter for your LCD monitor. Check out this website @ www.3rd-rocks.com
Sep 07, 2008 | X2Gen MG19MY 19" LCD Monitor
Lightning strike ac adaptor is fried
Your phone did expirence a surge that probably blew the ac adaptor which happens most of the time, u can buy one of those universal adaptors and look on the back of the old adaptor for the output voltage it will usually read between 3 and 8 volts DC.Set the universal adAptor voltage to the setting right below the voltage output on the back of the ac adaptor.
Aug 04, 2008 | Uniden Cordless phone EXS9950
IBM R40 Problems AC adaptor plug needs to be adjusted (wiggled, coached on the female connector) minutely to have panel (green) lights illuminate. No battery, Windows gets on screen, password entered, then...
I recommend bringing this laptop into Best Buy for repair. This has several hardware related issues from what you've described. If the repair quote is any more then $200 (which i anticipate it will be) I would consider investing in a new laptop and not throw good money after bad.
Thanks
May 02, 2008 | IBM ThinkPad R40 2722 Notebook
Celestron NexStar 5 SE (300 x 44.45mm) Telescope Logo
94 people viewed this question
Top Celestron Optics Experts
Vernon Taylor
Lawrence Oravetz
Are you a Celestron Optic Expert? Answer questions, earn points and help others
