Question about Nokia 6650 Cellular Phone
My nokia 6650 turned itself into offline mode and wont turn back. Anytime I hit any button on the keybad other then menu, it says application closed and then closes. What do I do?
krizanto81
  • 65 Answers
SOURCE: NOKIA 6600 turns off by itself
try it with the 3key format trick. if your phone shuts off for 30 seconds the UEM is the faulty part.
Posted on Mar 30, 2007
  • 89 Answers
SOURCE: Turning itself off
hey bud, Your mobile phone is infected with a virus because you used bluetooth for getting something from untrusted source . now to fix your problem you need to format you mobile phone and lose your all personal data .. like contracts , photo , audio files , etc . if you are ready do it *#7370# (*#res0#) Soft-format the memory (Symbian) lock code (12345) *#7780# (*#rst0#) Reset to factory defaults, confirmation required (also known has a Hard-format), all phone contents will be wiped clean including contacts and smses if they are stored on the phone trun off your mobile then press green button + * + 3 + power on button for formating mobile and when you are done try to get antivirus for your mobile . bye
Posted on Sep 10, 2007
SOURCE: nokia n95 wont send text messages
N95 Memory Full Problem can not be resolve by simply restarting or by changing the network setting. You must "Manual Reset" it. Just Turn Off the Phone, Press the *, Call Button, Three and ask another Person to turn on your N95 by pressing the power button. Stay pressing the Three Buttons until the phone fully boot up and ask you to enter Date and Time. After that, youre phone will go back to Factory Setting.
Good Luck,
I'm just want to Share.
Posted on Aug 14, 2008
  • 4 Answers
SOURCE: Nokia e65 stuck in offline mode.
step 1>switch off your phone and turn it on again
step2>you should get a respond <: continue in offline mode>: select no
finally, i believe that everything should be ok.
if it doesn't there is alternative 2???/////
ALTERNATIVE TWO: this is useful for those who got INSERT SIM CARD RESPONSE.
WHY INSERT SIM CARD PROBLEM ?
my phone is 1yr and 6 months now and i discovered that as you remove and replace your Sim card numerous times, there is a big possibility that Sim card port will get expanded.
SOLUTION is very simple:.>>:1. buy a black solo tape
2. place it at the outer part of the sim card and use blade to cut exactly the same shape as the sim card.
3. finally stick the tape.
WARNING>>?do not stick the tape on where you have the Sim card service sensors.make use of your brain.
Posted on Jan 14, 2009
  • 137 Answers
SOURCE: My Nokia N95 is not sending Text messages n it
Firstly make sure all your important stuff is saved on pc or in ye olde pen and paper...........then type in this code...*#7307# followed by your security code which is defaulted to 12345 this should reset the phone completely ....It should solve your problem completelly.If issue still exist then you need replacement handset.
Posted on Jul 17, 2009
Nokia nuron wont read my sim card
When the phone is in offline mode, press the power button and you will get the options in list view. Choose the option General and the phone will become online.
Aug 29, 2012 | Nokia 5230 Cell Phone
There is a word "offline" on the upper screen and
Your phone might have switched to offline mode accidentally if your keypad is not locked and you have the phone in your pocket/bag.
Press the power button momentarily to bring out a list of profile options, and select "General";
or you can go to Menu -> Settings -> Profiles and choose Normal Mode;
or you can turn the phone completely off and then turn it back on; while the phone boots up you will be asked if you want to exit offline mode -> answer yes
In order to prevent the phone from switching modes, or making inadvertent calls, remember to lock the keypad when the phone is not in use:
Left selection key + functions key
http://europe.nokia.com/support/product-support/e63/nokia-e63-how-to/get-started/get-started-shortcuts
Mar 16, 2011 | Nokia E63 Cell Phone
My nokia e75 is in offline mode. i cannot received text and calls. how can i change my mode to online. thanks
Tap the power button once (do not hold it too long, because it will turn your phone off). Just choose any profile, and your phone will go to online mode. You can switch it anytime to offline mode, in case you want to use your phone and be unavailable at the same time, by doing the same thing - tapping the power button, and selecting offline mode/profile.
If this helps, please rate. Thank you.
Jan 17, 2011 | Nokia E75 Cell Phone
How to switch nokia e71 from offline mode to online
I couldn't find the above menu items however i found an alternative: press the on/off button on your E71 and select General. The phone will then ask if you want to change from offline mode and allow network access.
Oct 08, 2009 | Nokia E71 Smartphone
My nokia n81 automaticly quit applycations and menu...
click and hold menu button, you should see all the applications that are currently running, select them one by one and close all of them keeping the "phone" application only.
then click once to open the menu.
you can also turn off the phone then on again. but make sure to fully EXIT the application after you finish using it. this will keep your batter life longer and save phone memory on your phone, it will also preform much faster.
let me know if this helped :)
Jan 03, 2009 | Nokia N81
HP Photosmart C6180 goes Offline in Vista
Solution A:
Download and install this Critical Update for your printer directly from HP.
Solution B:
There have been cases where if the PC is turned off or goes into hibernate this can occur. To work around this issue the "HP CUE DeviceDescovery Service" must be disabled:
1) Click on the "Start Menu" icon on the bottom left corner of the screen, type "services.msc" in the "Start Search" edit box, and hit enter. This will trigger Vista to pop-up a "User Account Control" dialog to prompt for permission to continue. Click "Continue" to allow Vista to open the Services management console application.
2) The Services management console application is made up of 2 panels. The right panel contains a list of all services available on the system. Scroll thru this list and look for a service called "HP CUE DeviceDiscovery Service".
3) Right-click on "HP CUE DeviceDiscovery Service" and select "Properties" to open the "HP CUE DeviceDiscovery Service Properties" dialog.
4) From the "HP CUE DeviceDiscovery Service Properties" dialog, click on the "General" tab. If the "Service status" shows that the service has started, click on the "Stop" button to force the service to stop.
5) Change the "Start type" to "Disabled" and click on the "OK" button on the bottom of the dialog to apply the changes.
Solution C:
1. Set the printer to a static IP address
2. Logon to the machine as the administrator or with admin rights.
3. Remove/Reinstall the printer using the IP address
Dec 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
Nokia 6630 problem
hi! may be you do not close web and just switch to oher applications. this cause the current open application to run in background which consumes bettery! make sure to close applications properly.here is the tip "press and hold menu button, it will show list of opened application on top left of the screen, goto those applications and close them"
hope it will work!
Jan 30, 2008 | Nokia 6630 Cellular Phone
Nokia 6650 Cellular Phone Logo
280 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
