Question about Garden
16 hp onan twin with coil ,rectifier and keyed ignition
2 Suggested Answers
  • 148 Answers
SOURCE: Cub Cadet 2145 doesn't have a spark
Great!
Posted on Jul 22, 2009
My onan 4.0 grenerator motor will not idle and it is back fireing while trying to run is in the valves
If it is backfiring even during idle, there are a couple of possible issues. Check the obvious and least expensive first. Make sure you have correct OEM spark plugs, check ignition wires. Then check the ignition coil and trigger module, there is a procedure for doing that in the Cummins Onan manual. A manual can be obtained from http://www.advanced-power-technologies.com/ or local Onan RV dealer. This will give you the ignition coil resistance and the ignition module resistance. Also has anyone messed around with the carb, or has it sat for long periods, too lean a fuel mixture can cause backfiring. Good Luck ;)
Feb 11, 2015 | Onan CUMMINS 4.0 KYFA/6747 - Cummins...
Onan 4000 microquiet generator
Check the ignition circuit, and trigger coil for correct resistance on the trigger coil, and the ignition coil. The trigger coil is a small module on the engine shaft near the flywheel.
Jan 31, 2015 | Onan Microquiet 3600 & 4000 Generator
How do i adjust the governor on an onan 16 twin engine 1974 model
dont do it take it in to a shop or you will blow engine up messing with it the gonenor
Sep 02, 2014 | Garden
No spark. the plug is ok 3 HP b&S motor
Most these engine got a wire from under flywheel ignition coil to the the throttle plate where it is ungrounded - meaning, not electrically shorted to the main body of the metal of the engine. When the engine control is moved to off, stop, etc - that plate makes a short/grounded connection to that wire that causes the ignition coil to not function and
it quit making the spark. Now then. The coil is the only other suspect here unless the flywheel has broker it key.
Sep 01, 2013 | Briggs & Stratton Briggs Stratton Intek V...
Fitted new coil to briggs and straton 16 twin but have no spark
unplug the wire that comes from the tractor then check for spark if you do then stat by checking he safety switches
Mar 30, 2012 | Briggs & Stratton Garden
Have 303447 briggs 16 hp only fires one cylinder
Have you also changed the spark plug too. The ignition circuit is pretty simple, from the battery, the Coil is energized, the "points" or equivalent, through the "Distributor" or equivalent, and onto the Spark Plug. So it is a simple matter to work along the path, proving the "Integrity" at each, point by testing. IF it still doesn't fire after ensuring all Leads are OK, the Spark Plugs are proven OK, the Cables, the Points, & Distributor, . IT is either that or the Ignition Timing is OFF. Please check all those points.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
I have a 1978 Kawasaki KZ750 B3 Twin. I am currently trying to resolve an issue with it right now. I am trying to determine why the bike does not get any spark. I've replaced the points and condenser and...
The rectifier has no effect on the ignition system if the battery is fully charged. If you have access to a test light or voltmeter, check for power (12 volts) at one of the coil side-connections with the key turned on. If no voltage at either coil connection, then power is not coming from key switch. Check plug connections at key switch--may be loose or corroded from water entry. Do headlights, horn, starter work? Key switch should have one "always hot" connection which comes from battery. Wire colors should match through each connector. Hope that helps.
Jul 10, 2009 | 1981 kawasaki KZ 1300 A3
Garden Logo
271 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
