When I turn my stylus SX515W on and select the language I want, an error message is displayed : "A printer error has occurred. Turn off the printer, then press On button to turn on. See your documentation." The problem persists after many tries, and the documentation says to contact Epson support in such a case.
  • 4 more comments
  • virgile_sylv Oct 06, 2010
    Thank you for your prompt reply.
    Unfortunately your method isn't working and I still have the error message after 3 tries.
  • virgile_sylv Oct 07, 2010
    Thanks for the prompt reply! Unfortunately your method doesn't work after at least 3 tries.
    Thanks for your reply, however I forgot to mention that the printer is brand new. Since no cartridges have been inserted in it yet, it's unlikely that waste ink is the problem.
    If it really is waste ink, then there is a small door at the back of the SX515W but it's not held by a screw so it is the same model than the one you have in mind?
    Lastly, will any of this void my warranty?
  • virgile_sylv Oct 08, 2010
    Thanks for your reply. The cartridges are fine, I double checked. The printer won't even let me insert anything. Before the error message appears, a small I've successfully downloaded the driver, though I will probably reinstall everything just to make sure.
    By the way, when I turn it on, it says open the scanner and insert the ink cartridges for less than a second and then the error message appears with a small noise
  • virgile_sylv Oct 15, 2010
    Epson Stylus SX515W
    After installing (and re-installing the required software) the printer does not work when turned on, despite protective layers being removed. Once language is selected, a message that asks me to install the ink cartridges is displayed for a very brief period of time before an error message appears :
    "A printer error has occured. Turn off the printer, then press On button to turn on. See your documentation."
    Resetting the ink counter (pressing On+Setup+Stop) or the printer itself (pressing On for 10 seconds with printer offline) has no effect, even after several tries. Obviously, ink is not the problem here as no ink cartridges have been inserted : the printer won't let me. Finally, the documentation says to consult tech support for this specific error message.
  • 712 Answers
Then have you contacted the Epson support?
Posted on Oct 15, 2010
  • 857 Answers
You will need to get the product serviced as it may be a hardware problem as well. Try these steps before you contact support :
1. Turn this product off, and then back on.
2. reset the waste ink counter.
To reset the waste ink counter, press the following three buttons simultaneously, until the unit powers off: Power, Setup, and Stop. Then turn the power back on.
After you reset the counter, you need to redirect the waste ink or you will continue to get this error. On the back of the printer is a little door that is held by a screw. Remove the door and look inside, looking down, for a piece of white absorbent. Under the absorbent is a "clear" tube. This is the waste ink tube. Pull the end out (there will only be a few inches that protrude from the back of the printer). Now, connect some tubing to this, fish aquarium tubing works well, and push the free end into a jar or bottle that has a hole cut in the top or lid.
Once you redirect the waste ink away from the absorbent and sensors, you will no longer receive the error message.
If this doesnt helps please call the manufacturer.
Posted on Oct 07, 2010
  • Jayant Jha Oct 07, 2010
    No it will not void your warrenty,
    if it is a rand new printer the better will be to call tech support as it may required to be serviced.
  • sikor_d Dec 04, 2010
    I have the same problem with brand new Epson Stylus SX515W. Does someone know how can I fix it?
    President:
  • 4,070 Answers
Hi! Please try this as a first course of action. Unplug the printer from power source then press the power button for 10secs. while unplugged to reset the printer's system. Once resetted you may get rid of the error message. Hope this helps and thank you for using FixYa!
Posted on Oct 06, 2010
  • dj_relly999
    dj_relly999 Oct 07, 2010
    Hows it going now?
  • 3,530 Answers
Since you mentioned it is a brand new printer, make sure that the cartridges are the right cartridges for that model. Other cartridges will fit but will not be recognized by the printer software. Make sure they are installed properly. Don't forget to download the driver as well.
  • Jose Cada
    Jose Cada Oct 08, 2010
    Thank you for the reply. Given the additional information, let me get back to check what could be possibly wrong.
    If you have downloaded the driver, uninstall first before reinstalling.
Printer 5550 laser color cood 59.c0
I am assuming you meant HP Color LaserJet 5550 Error Code 59.c0
Description
A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly.
Action
  1. Press the green (Select) button to continue.
  2. Turn the printer off, and then turn the printer on.
  3. If the error message returns, turn the printer off.
  4. Perform a cold reset.
    1. Turn the printer on.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the green (Select) button.
    4. Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    6. Press (Down Arrow) button once. The control panel will display COLD RESET.
    7. Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
  5. If this message persists, contact an HP-authorized service or support provider.
Sep 06, 2016 | Laser Office Equipment & Supplies
Everytime I turn my printer on (Epson Artisan 700 series printer) it waits for about 5 to 7 seconds and then displays a message that says "A scanner error has occured. Please see your...
when I turn my printer on (Epson Artisan 700 series printer) it waits for about 5 to 7 seconds and then displays a message that says "A scanner error has occured. Please see your documentation". Then all the lights start flashing, And then I cant do anything, but turn the printer off.
I have turned it off and unplugged it and tryed again always same result.
bdl12920@aol.com
May 10, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Code ereur 59
A code error 59:
Description A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly. Action
  1. Press the green c00099346.jpg (Select) button to continue.
    3. When the memory starts counting, press and hold the green c00099346.jpg (Select) button.
    4. Continue holding the green c00099346.jpg (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    6. Press c00099347.jpg (Down Arrow) button once. The control panel will display COLD RESET.
    7. Press c00099346.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
Mar 02, 2011 | HP LaserJet 5550DN Printer
Regularly getting error code 50.9 on a HP color laserjet 3550 printer
Hey Joe,
This is what the HP Website has to say about it:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
BUT! you can try performing a cold reset, and maybe this would help:
500, 3550, 3700, 4600, 4650, 5500, 5550, 8500, 8550, 9500) use the instructions below. 1. Turn the printer on.
2. When the memory starts counting on the control panel, press and hold the green SELECT button. Continue to hold green SELECT button until all three Control Panel LED's are illuminated and on solid.
3. Release the green SELECT button.
4. The control panel will display SELECT LANGUAGE.
5. Press the DOWN ARROW button until control panel displays COLD RESET.
6. Press green SELECT button. The printer will perform a cold reset and then continue its power-on sequence.
Feb 07, 2011 | HP Color LaserJet 3500 Printer
When I turned on my printer for the first time, I selected my language and immediately the screen popped up printer error. This happens everytime I try to turn the printer on. SX515W
make sure all the shipping tape has been removed, specifically the tape holding the carriage unit in place, make sure there is no debris etc inside the printer
Jan 02, 2011 | Epson Stylus Multifunction Inkjet Printer/...
A PRINTER ERROR HAS OCCURED. SEE YOUR DOCUMENTATION. I RECEIVE THIS MESSAGE ON THE DISPLAY SCREEN. I HAVE NO PAPER JAMS. WHAT COULD BE THE POSSIBLE PROBLEMS?
Turn off your printer and unplug the power cable. Open the scanner lid. Double check for any obstructions. Move the print head to the left side and check again if there's obstructions on the right side. Close the lid and try to turn on the printer. If error message still displays on the screen, possibly it is a printer issue. It may require service.
Dec 16, 2010 | Epson Stylus RX580 InkJet Photo Printer
Change the language on hp laserjet 4000 to english
For the LJ4000 to change the control panel language:
Turn off the printer.
On the front panel, hold down the SELECT key.
Turn the printer on, while continuing to hold the SELECT key.
When the Select Language message is displayed release the SELECT key.
Initializing will display on the control panel. After 5-7 seconds Language=English will display.
Press the VALUE key until the desired language is displayed.
Press the SELECT key and an asterisk will appear. The asterisk indicates that the printer has saved the new setting.
Press the GO key to display Ready in the language that was selected.
NOTE: If Select Language does not appear in the display, hold down the SELECT button until you hear the motors rotate, then release. Following printer initialization, the Language= menu will appear in the display.
hope it helps, if so do rate the solution
Nov 30, 2010 | HP LaserJet 4000 Printer
HP 5500 can not print with 59.CK error code on display
You probally need to contact an engineer on this one, from HP trouble shooting manual
Description
Action
1. Press the green <Tick Symbol>(Select) button to continue.
a. Turn the printer on.
b. Watch the control panel.
c. When the memory starts counting, press and hold the green <Tick Symbol> (Select) button.
d. Continue holding the green <Tick Symbol> (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
e. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
f. Press (Down Arrow) button once. The control panel will display COLD RESET.
g. Press <Tick Symbol> (Select). The printer will perform a cold reset and then continue its power-on sequence.
Sep 22, 2009 | HP LaserJet 5500 Printer
Priner error occurred.Please see users guide?
Try turning off the printer and turning it back on. If the error persists, it's time to call Epson and have them service the unit.
Jun 20, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
810 people viewed this question
jasbo
jasbo
