Question about Apple iPhone 3G
How to solve if my iphone 3G cannot be on, it stuck at the apple screen?
    Novelist:
  • 111 Answers
  • The quickest way to fix your iPhone 3G is to sync it to a different computer. When you do this the computer will recognize it as a new device and install the software on it like it's never been used before, that said everything you have on it is gone. It may take a while so be patient.
  • 2 If step one is successful you can sync it to your computer. It will recognize that it is synced with another computer and ask you if you want to sync it to this one; go ahead and do it. This may take a while too because you will install the applications, songs, data, etc. you had on it before.
    WARNING! DO NOT DISCONNECT YOUR IPHONE 3G WHILE SYNC IS IN PROGRESS OR ELSE YOU WILL BE STUCK IN RESTORE MODE AGAIN!
  • 3 If steps 1 and 2 did not work or you do not have another computer to sync it with the following steps will help.
  • 4 Backup your music, videos, and applications. Typically it would be the iTunes folder in the My Music folder. This is a precautionary step to the following steps to come, your music should be unaffected but stranger things have happened.
  • 5 Uninstall iTunes, Quicktime, and other Apple component software from your computer. Follow the steps listed on the Apple Support page, "Removing iTunes, QuickTime, and other software components for Windows XP" the link is available in the resources section. Restart your computer when done.
  • 6 To be sure everything is uninstalled completely run the Windows Installer CleanUp Utility. This program removes remnants of uninstalled programs from your registry and deletes files that the uninstall fail to catch. You can download and read more about this program from the Microsoft Help and Support Page, "Description of the Windows Installer CleanUp Utility" the link is available in the resources section. Restart your computer.
  • 7 If you have a registry cleanup utility like Registry Mechanic or CCleaner run the program and restart your computer. It is sad to say but the Windows Installer CleanUp Utility may not catch everything so having a secondary cleaner could be essential.
  • 8 Install the latest version of iTunes. Currently iTunes 8 is the latest, it could change tomorrow so download it from Apple.com. Restart your computer.
  • 9 Open iTunes and connect your iPhone 3G. It may take a while for it to recognize the phone, be patient. Once iTunes recognizes your phone it will prompt you to download the latest iPhone software, the current version is 2.1. Follow the installation instructions in the Apple iPhone - Software Update page, the link is available in the resources section.
  • 10 Hopefully these steps helped you recover your iPhone 3G. It is possible that even after a successful recovery your phone may revert back to being stuck. In my experience I was able to save my iPhone 3G from restore mode but when I downloaded the software update it got stuck again, luckily steps 1 and 2 fixed it.
  • Posted on Oct 06, 2010
    I phone 3 freeze just showing apple
    It sounds like you are stuck on boot. Hold down the power/lock button and home button together until the phone turns off and the apple logo appears again. Your phone should boot up normally.
    Feb 13, 2013 | Apple iPhone 3G
    Iphone 3g stuck in restore
    You may try default phone and security code to remove restrictions.
    ur defalt phones codes is 12345 or 00000 u can use it
    Default 4 Digit user code: 1234 or 0000
    Default 6 Digit Security code: 123456 or 000000
    Type *#06# at the mobile screen to know IMEI no of your mobile.
    send the IMEI no to me and i will reply you with unlocking code.
    IF Problem not Solved So
    Please New Software install in the Phone Problem will Solved
    Oct 29, 2012 | Apple iPhone 3G
    How do I Fix my iPhone 3G?
    What is wrong with him ?
    Mar 10, 2011 | Apple iPhone 3G
    Iphone 3g stuck in "recovery mode" (black screen
    To reset your iPhone settings,
    picexporterror From the home screen, Tap Settings > General > Reset > Reset All Settings.
    Still having problems?
    Try deleting all the existing settings.
    Note: The step given below will delete all the data on your iPhone. It will also give a reset to your settings.
    From the home screen, Tap Settings > General > Reset > Erase All Contents and Settings.
    Or:
    If iPhone won't turn on, or the display freezes or doesn't respond
    1. Press and hold the Home button for at least ten seconds, until the application you were using quits.
    2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
    3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
    Let me know if this helps or not, there are other resets available :
    If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Feb 19, 2011 | Apple iPhone 3G
    3gs iPhone froze at boot screen (apple logo)
    Re-download the ipsw file that was on your iPhone, Download Spirit to jailbreak, and that should do the trick.
    Jul 09, 2010 | Apple iPhone Smartphone
    My iphone 3g is stucked on the emergency screen.
    Re-sync the phone to iTunes, and upgrade to ios 4.0
    Jul 01, 2010 | Apple iPhone 3G
    Screen picture to big cant see all of it
    wat i normally do is use my three middle fingers and tap the screen 3 times. normally solves problem. :)
    Mar 29, 2010 | Apple iPhone 3G
    My iphone 3g has a blank screen and won't do anything, what can i do to make it work
    Try a reset. Hold the sleep button and the home button together until phone turns off and release buttons when you see the Apple logo. The re-boot should take a min or two. This generally solves a lot of problems.
    Jim
    Feb 01, 2010 | Apple iPhone 3G
    Iphone 3g 3.0 stuck on iphone apple logo loading screen
    1. Press and hold the Home button for at least six seconds, until the application you were using quits.
    2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
    More resets:
    Try This:
    1. Remove Sim Card
    2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
    3. Replace Sim Card
    4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
    Also, Try this:
    1.) Shut down the iPhone 3G.
    2.) Start up iTunes
    3.) Hold down HOME button on the iPhone 3G
    4.) While keeping the HOME button depressed, plug in the Sync cable
    5.) A message will pop up to ask if you want to reset.
    6.) Just click YES and the reset process should start.
    Aug 27, 2009 | Apple iPhone Smartphone
    Unlocked iPhone 3G
    Heyy Hii
    I got he iphone two days before, and i press by mistake Setting, General & ''erase setting'' than after it said it will take 2hours for format and restore, After finishing it got stuck it's shows only Apple sign and I its not connecting with Computer Itune software the devise is complitely unknown?
    Please if anyone can solve my problem?
    Oct 11, 2008 | Apple iPhone Smartphone
    Apple iPhone 3G Logo
    190 people viewed this question
    Top Apple Cell Phones Experts
    David
    Martin Murray
    Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
