Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint hd640 washer/dryer
No light on on/off switch,fuse ok
  • mikhdaj May 29, 2008
    Thanks for that but i'm getting power to the control module but no on light on the start button
    Genius:
  • 1,224 Answers
Ok make sure of a couple things waters on settings not in standby mode or safe mode clean all traps and filters
circuit breaker not trippin out or had been tripped out
Posted on May 28, 2008
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
Ultra sense dryer won't start
-Possibly bad door switch, burn heater element, bad thermal fuse,
bad starter switch
Mai
Nov 28, 2013 | Hotpoint WMA50 Front Load Washer
Wd645 has no power to on/off switch. changed plug
Could be mains choke. Mains power comes into mahine via wall socket /worth checking this then onto mains filter/Choke..then to switch..So if no power here check this..wish you well
Oct 07, 2009 | Hotpoint Aquarius WD640 Front Load...
Drying Problems with a Hotpoint CTD00
There is a thermal fuse at the back that you must check. The thermal fuse can be tested using a multimeter.
If the fuse is ok, then check the heating element , the temp probe, wiring harness to heating element and temp sensor, and if there is nothing in there , then test control timer board.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Apr 27, 2009 | Hotpoint Dryers
Hotpoint aquarius washer dryer wd63 1100 spin - my fuse went just as i was switching the machine on - so the door locked and wont open - changed the fuse, door was still locked so thought id let the wash...
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD 865- washes ok, dryer won't work makes loud popping
sounds like the dryer heater element has worked loose perhaps and shorted out against the metal dryer box which sits on top of the drum.
best to get an engineer out i'd say.
Jan 14, 2009 | Hotpoint Aquarius WD63 Front Load...
Turn washer dryer on ok, then close door then curcuit trips
check the wiring and make sure nothing metal is on the motor because your dryer has a short in it somewhere
Dec 23, 2008 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint Aquarius 1100 washer dryer
probably not door switch, but to access, remove door gasketf rom cabinet in area of door switch and door switch is only held by 2 screws. more likely to be the suppressor capacitor. remove top and look at suppressor - they sometimes go pop
Aug 17, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint ultima WT9 60
the internal circuit board has come loose, switch off power take the top off and tighten the connections on the plugs inside
Feb 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
83 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
