Question about GE GSS25JF Side by Side Refrigerator
GE GSS25JF has stopped working. No interior light, no hum to indicate it is receiving power. It's plugged in and the cable is not damaged. We have had it for several years with no trouble until now.
    Problem Solver:
  • 15 Answers
Try to use an other machine in the same power plug to be sure that it is ok .
Posted on Oct 06, 2010
Loud hum from subwoofer
The number-one cause of subwoofer/speaker hum is the coaxial cable connecting your cable or satellite receiver to your provider (either through an inground run to a cable box or through a satellite dish). Here is how you test for this:
  1. Turn your system on and get it to produce the hum by watching a movie. Pause your DVD or videotape so that the hum is all you hear.
    TIPDon't use a normal cable or satellite program for this; you're about to disconnect the cable that provides the audio and video for your cable/satellite feed.
  2. Find the coaxial cable running from your cable or satellite receiver to your service provider, and while listening to the hum, unscrew the connector and disconnect the cable.
Did the hum stop or reduce by a large amount? If so, the cable you disconnected is the source of the noise. If this is the problem, you have several ways to fix the issue permanently (if not, jump ahead to the next section):
  1. Call your cable or satellite company and ask for a service call. Sometimes you get a smart cable guy, and if you demonstrate the problem he can do something upstream to ground the coaxial cable and remove or reduce the hum.
  2. Buy a power strip that has F connectors as part of its surge protection. Plug the strip into the AC outlet and feed your main coaxial signal through these connectors. This ties the shielding of the coax (the source of the noise) to your AC ground and sometimes can solve the problem.
    WARNINGOddly enough, this solution (surge protection) can sometimes increase the humming.
  3. Go to your local RadioShack store and buy three inexpensive items: a Matching Transformer (part #15-1253), an Indoor/Outdoor Matching Transformer (#15-1140), and a Cable Coupler (#278-304). Connect your coaxial cable to the cable coupler, and then to the first matching transformer. The output is two screws for the old two-wire antenna wire. Your indoor/outdoor matching transformer has two connectors for the screws, and the other end is a coaxial connector. Hook your cable or satellite receiver into this connector and see if the hum goes away.
Here is why this trick works: the first transformer converts your 75-ohm coax into a 300-ohm antenna connector. The second transformer converts the 300-ohm back to a 75-ohm connector. The humming, which usually is at around 60 Hz, can't pass through these conversions.
Ground Loop Hum
The second cause of hum is called a ground loop, and it almost always shows up right after you bring home a brand-new, self-powered subwoofer, or perhaps an external amplifier.
Take a look at all the plugs on the power cords on your home theater equipment. In most systems, the receiver (or amplifier) has a three-prong power plug, but most of your other devices have only two-prong plugs. This is not by accident; the device with the three-prong power plug is grounded. This means that device "owns" the ground. As long as no other power device has a three-prong plug, everything works well.
When you bring home a self-powered subwoofer and plug it in, though, you might notice it has a three-prong plug; this is for safety reasons. However, when you connect an RCA cable from your receiver to your subwoofer and turn everything on, you suddenly notice a loud hum.
The external amplifier in your subwoofer is now fighting with the amplifier in your receiver for possession of the ground. Both devices want to define 0.00 volts. But because the wiring in the two amplifiers to your household AC ground is different, one device is really using 0.001 volt and the other device uses something closer to 0.003 volts. The subwoofer cable connects the two, and the fighting begins.
You have to stop these two devices from trying to own the ground, or get them to not "see" each other. First, make your system produce the humming noise. Disconnect the single RCA cable between your receiver and subwoofer. Did the noise stop? If so, you have a ground loop issue.
The proper, safest way to solve this problem is to buy a special subwoofer cable with little arrows on the wire to show the signal direction (see ).
[img src="http://oreilly.com/images/hacks/htheaterhks/figs/htheaterhks_0601.jpg">
Figure 1. Subwoofer cable with directional arrowUnfortunately, many people have been ridiculed when asking about these sorts of cables at their local electronics store: "But cables don't really have a direction. My expert friend at work laughed at me when I asked about this!" Yes, your friend is right. Cables don't have a direction, but these little arrows indicate that this cable will prevent or solve your ground loop problem.
Remember when I said the hum started when you connected the RCA cable? That RCA cable really contains two wires: the center wire and something called the shield. The center wire carries the audio signal, but the shield tries to define 0.00 volts. The shield is the wire that lets the two different components (the receiver or amplifier, and the subwoofer) see each other's ground, and causes the fight. What if you took your subwoofer cable and disconnected the shielding from just one end? Wouldn't that solve the problem? Yes, it would. This is exactly what a subwoofer cable with little arrows does. The shield is not connected at both ends. The shield has to be connected at one end, for connecting to your receiver or amp, so you should run the cable so that the arrows show the flow from the receiver to the subwoofer.
WARNINGIt is unsafe to use a two-prong to three-prong "cheater" plug on the subwoofer power cord to solve the hum problem. Even if the subwoofer came with a cheater plug in the box, it's REALLY not safe to do. Don't do it.
Sep 01, 2013 | Denon Audio Players & Recorders
How do I eliminate the humming on my Vizio VHT-510 system
see this instruction and fix it. God bless you
    • 1
      Disconnect the coaxial cable at the back of the satellite receiver or cable box by unscrewing the coupler on the cable end.
    • 2
      Attach the cable to the RF IN jack on a surge protector and tighten the coupler clockwise.
    • Sponsored Links
    • 3
      Connect a second coaxial cable from the RF OUT jack on the surge protector to the input on the cable box or satellite receiver. If this stops the hum, congratulations: You're done.
    • 4
      Unplug the subwoofer's electrical cord from the power strip or wall outlet if it is connected to the same circuit as the AV receiver. The amp in the AV receiver and the amp in the subwoofer are in conflict over the grounding of the electrical circuit.
    • 5
      Plug the subwoofer into its own surge protector and connect the surge protector to a different wall outlet than the AV receiver uses.
    • 6
      Disconnect the subwoofer cable from the back of the sub and the AV receiver if all other measures fail to stop the humming. Reverse the plug connections so the plug that had been connected to the receiver is now connected to the subwoofer. Turning the cable around may solve a problem known as ground-loop hum by reversing the shielding wire inside the cable.
Read more: http://www.ehow.com/how_6979184_eliminate-sound-home-theater-subwoofer.html#ixzz2ZdzrgBSa
Jul 20, 2013 | Vizio Vht210 2.1 Home Theater Soundbar...
My AV receiver turns off a couple of seconds after I turn it on. I did what the manual said, unplugged the power source and removed all of the speakers but it continues to do the same thing. Anything else...
you may have a bad Earth power 110 V AC cable connection which makes such hum / buzz even nothing connected..
Check the connections between components and make sure they are secure before proceeding to the next Step. Sometimes, loose connections can cause a hum.
  • Separate the audio cables from the power cables; electromagnetic interference from the power cables can cause stereo hum. Use cable ties to secure the audio cables away from the power cables.
  • Plug in a surge protector to the outlet, and then plug all the components into that surge protector
  • Connect a ground plug to the surge protector and then plug the ground plug into the main outlet. A ground plug is available at any hardware store, and turns a three prong connection into a two prong. Ground plugs help eliminate 60 cycle hum.
  • 5 Connect the ground wire from your turntable to the ground wire connection on the receiver. If this doesn't work, looking on the back there should be a grounding point,
    Unplug your receiver.. Split a wire and attach one of the splits to the receiver where you will see the text, "ground" or something similar. Attach the other end to something metal such as a pipe that goes into the ground. Secure with electrical tape. Plug in.
    connect the ground wire to a screw on the electrical outlet.
    Read more: How to Fix a Hum on a Stereo Receiver ' eHow.com http://www.ehow.com/how_5183193_fix-hum-stereo-receiver.html#ixzz1PpFHs1Mv
    Take care and please remember to rate me"AS THUMBS UP" Thanks
  • Jun 20, 2011 | Onkyo TX-SR606 Receiver
    I have an older model Harman Kardon AVR and have started hearing humming from the speakers that are attached to it. Is my receiver going bad or is there something else I need to do to fix this problem?
    Take care and please remember to rate "AS THUMBS UP" Thanks
  • Jun 20, 2011 | Harman Kardon AVR 85
    My nad 3020 is making a buzzing noise when i connect to peakers even when nothing else is connected to it. any solutions ?
  • Read more: How to Fix a Hum on a Stereo Receiver ' eHow.com http://www.ehow.com/how_5183193_fix-hum-stereo-receiver.html#ixzz1PpFHs1Mv
    Jun 20, 2011 | NAD Audio Players & Recorders
    Major hummimng noise when sub is connected to receiver.
    Is the hum in the receiver-attached speakers or the sub?
    Self-powered sub?
    How is the sub attached - RCA or speaker-level?
    Disconnect the input(s) and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
    If it hums with the sub attached, unplug the sub's power cord. Differences in AC ground potentials will generate hum across linked devices.
    Mar 25, 2011 | Yamaha RX-Z9 Receiver
    After a power outage I have a loud hum.
    Hi, The Ground Rules Of all the annoyances that can afflict any audio/video home theater or even a simple stereo installation, the notorious "ground loop" may well be the most difficult and persistent one to track down and eliminate. A "ground loop" is caused by the difference in electrical potential at different grounding points in an audio/video system. (All the grounds in an A/V system should ideally be at "0" potential.) A ground loop typically adds a loud low-frequency hum or buzz as soon as you plug in any of various audio or video components, including subwoofers, cable-TV outboard boxes, satellite-TV feeds, TV displays, amplifiers, A/V receivers or turntables. The buzz/hum is a byproduct of the multiple power supply cables and a ground voltage differential within your system and its network of interconnecting cables.
    Here are some methods to help you get rid of ground loops. Try these first and don't waste money on a power "conditioner" which, in most cases, won't help. (There is no need to "condition" the AC power for your system. Your receiver or amplifier already has a power supply with its own filters and transformers. No further filtering is normally required.)
    If you get your system up and running and hear an audible buzz or hum, the first culprit to look at is either the powered subwoofer or your cable-TV or satellite-box feed at the entry point to your system.
    First, the subwoofer: unplug the coaxial cable that connects to your powered subwoofer to see if the ground-loop hum disappears. If it does, it's likely coming in through your cable/satellite TV feed.
    Reconnect your subwoofer's coaxial cable from the subwoofer input to your receiver's subwoofer output and disconnect the cable-TV feed (or satellite feed) from your outboard set-top cable box or satellite tuner. Be sure and disconnect the cable before any splitters. Now see if the hum/buzz from your subwoofer stops.
    If that eliminates the hum, you can install one of these inexpensive in-line ground isolators from Parts Express or Bass Home. Note that these transformer-based ground isolators will work fine with analog cable-TV feeds, but depending on their design they may interfere with or block reception of HDTV signals via a digital cable or satellite dish feed.
    Install the ground isolator between the cable-TV feed and the input of your outboard cable-TV box or satellite tuner (or the TV display's antenna or cable input if you have a set with a built-in TV tuner or a cable-card ready set). In many cases, the ground isolator will "break" the loop and remove the annoying hum or buzz by isolating the TV-cable ground.
    If a hum remains with the TV cable completely disconnected from your system, or you don't want to risk degrading reception of HD signals from a cable or satellite system, then you may have to add a ground isolator like this Radio Shack Model 270-054 between the line-level coaxial subwoofer cable from your A/V receiver and the line-level input jack on your powered subwoofer.
    In all cases, if your subwoofer has a ground-lift screw like some of Axiom's subwoofers, try first removing the screw (or replacing it) to see if it increases or eliminates the hum. It may or may not make a difference.
    If you do not have easy access to the aforementioned ground isolators, here are a few more tips:
    Try plugging the subwoofer into a different AC outlet in the room, one that isn't supplying power to your components (A/V receiver, TV, cable box, etc.). That might fix it.
    Try reversing the AC plug for your A/V receiver or the powered subwoofer. If it's a 3-wire plug or a polarized plug, which has one prong wider than the other, you won't be able to reverse the plug. For safety, do not use a "cheater plug" to bypass the 3-wire plug.
    With the power OFF, reverse the AC plugs one by one of any other components that have a standard 2-prong AC plug that isn't polarized. Each time you reverse a plug, turn on the system with the attached component and your subwoofer and see if the hum disappears. In some cases, reversing one or more plugs will eliminate the hum.
    If you have a turntable, try connecting a separate ground wire to a chassis screw on your preamp or receiver and see if the hum disappears. If you already have a turntable ground wire, try removing it from the preamp. One or the other may eliminate the hum.
    Finally, here is another solution that worked well for a member of our message boards who decided to discard his ground-loop isolator on his subwoofer: "I took off the ground-loop isolator I'd been using and connected a plain 14-gauge wire to chassis screws on the sub and the receiver then powered everything on. Although hum was still there, it was far lower than before. Next I unscrewed the ground-loop screw on the back of the sub and that took care of the hum completely."
    Almost certainly sounds like an earth loop to me, but can be caused by a poorly made transformer or phase shifts on the mains supply. Visit some power conditioner web-sites like Isotek or Isol-8 (or google "earth loop") where there's plenty of advice on how to reduce/eliminate earth loops and other causes of mains-induced hum (transformer problems etc).
    Hum on the speakers usually indicates that there is a DC voltage on the speaker line. DC voltage on the output lines would be caused by a shorted output transistor.
    Have a nice day...
    Feb 16, 2011 | Cambridge Soundworks BassCube 12 Speaker
    Indicator light not working and humming noise
    your circuit board is bad not repairable i have the same prob but not kenwood they said it would cost more then its worth.
    Jan 03, 2008 | Kenwood 103SW Speaker
    GE GSS25JF Side by Side Refrigerator Logo
    143 people viewed this question
    Top Refrigerators Experts
    Sal DeAngelo
    Charles T Nevin
    Charles T Nevin
    Andrew Taylor
    Andrew Taylor
