Question about Broan-NuTone QT100L Fan
My Broan Nutone Bathroom fan QT-100L model doesn't work properly. The fan makes a lot of noise. I would like to replace it. Where can I buy a fan unit to install in this model. The unit came with a night light and a regular light which are still working fine. Can I replace just the fan? Where could I order the part? Thanks, Gina
NuTone 0696B000 is the Replacement Motor Assembly. Search that in Google and you can find a number of sites to purchase it from. We've replaced our fan motor 4 or 5 times over the years. It just gets too much use. Very simple to replace, you plug it in and it saves having to replace the entire unit because they don't make anything that fits that same space.
Posted on Apr 21, 2011
  • Broan-NuTone Master
  • 43,501 Answers
Here is a tip that I wrote about cleaning bathrooms fans that also addresses that issue at the end...
http://www.fixya.com/support/r6871896-broan_bathroom_fan_care_cleaning
heatman101
Posted on Nov 17, 2010
2 Suggested Answers
SOURCE: QT 100L replacement
Forget it. I also had the same problem with the QT100L. Cannot buy this unit and the replacement unit is the LS100L by Nutone/Broan. Good news: it is more powerful 110CFM and the housing is the same size. Bad news, the motor assy is completely different and it cannot be mounted in the existing housing. To install the new unit, you will need to cut the ceiling around the fan housing and install the new housing and wire it as well. Be aware that the wiring comes into the housing 180 degrees from the old QT100L unit. That means I hope you have enough romex to reach the hole. My advice is to get another unit from any other company because the quality sucks. It will be as much work to install any other brand as the LS100L.
Julius in CT
Posted on Nov 25, 2007
I want to upgrade a nutone qt 80 ca
Hi, parts can be found on amazon, here: Amazon com nutone qt 80 also new one if you want to buy. I hope this was helpful. Cheers
Jul 23, 2012 | Broan-NuTone Dryers
Our bathroom Nu Tone Model QT-100l fan is sounding loud and Rough. Can I purchase the motor part for this? If so will the motor be attached to the metal housing and I should be able to simply replace the...
The replacement motor is available from several sources online. The best way is to purchase the new motor assembly. All you need to do is remove the blower housing from the ceiling, there are three screws that hold the motor assembly in place. The whole job takes about five minutes. Here are a few sites with the motor.
http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/0696B000-Motor-Assembly.php http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=qt100l&Search.x=0&Search.y=0 http://www.cshincorporated.com/product_info.php/manufacturers_id/33/products_id/11272
Aug 22, 2011 | Broan-NuTone QT100L Fan
Our exhaust fan is really noisy. Nutone QT 100N-B model. Where can we purchase a new one?
This model has been discontinued but replacement motor assemblies are available. There is no off the shelf model that will fit in the existing housing. If you do not want to replace the housing then the motor assembly is the way to go.
You ca purchase the replacement from either site below:
Jun 07, 2011 | Broan-NuTone QT100L Fan
NuTone QT80 is not clearing moisture/condensation from the bathroom / 33 cubic square feet / no elbows / about 10 - 15 straight duct length
This should not be a problem. If you think you need a more powerful fan a there is a 110 CFM replacement fan that will fit in the same housing. The NuTone part# is 0696B000. There are some generic versions out there on ebay and amazon that have been causing people a lot of trouble. I would recommend buying from an Authorized NuTone dealer only.
http://bit.ly/8WYtJd
Nov 11, 2010 | Broan-NuTone Dryers
Problems with exhaust fan NuTone Model LS 100SE
The fan/motor part of the Broan fan is replaceable. They are actually very simple to take out and install a new part.
The part can be easily purchase here...
http://parts.broan-nutone.com/broan/Shop
Heatman101
Feb 27, 2010 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Nu tone model QT-100N-B. looking for a replacement. Were can I buy 2 of them in sacramento, ca?
There is no replacement fan for that model that will fit in the existing housing. You can buy the replacement motor assembly.
You can buy these online and have them shipped to you:
or
http://www.centralvacuumstores.com/search/search.php?keywords=qt110&x=47&y=15&asug=
or
http://www.partstore.com/Part/Broan-Nutone%20Group/Broan/0696B000.aspx?s=froogle
Jan 07, 2010 | Broan-NuTone QT100L Fan
The Fan in my Nutone bathroom light/fan is not working...
It is really easy to change the motor yourself. It is about a 15 minute job. You just need to find your model number and then you can buy the complete motor assembly. https://www.centralvacuumstores.com/model_number_help.php
Mar 28, 2009 | Broan-NuTone N-8663RP Combination Light...
Where can i get a replacement motor for a qt100l BATH FAN?
Go to the link below and you can order replacement parts for the QT 100L
http://parts.broan-nutone.com/nutone/Shop?DSP=30115&PCR=1:21000&IID=QT100L
Nov 08, 2008 | Broan-NuTone QT100L Fan
Fan Light
try reducing the wattage of the light bulb.
Apr 03, 2008 | Broan-NuTone QT100L Fan
QT 100L replacement
Don't worry, you can purchase just the fan from amazon (not entire motor). here: NuTone 0696B000 Motor Assembly for QT100 and QT110 Series Fans. I hope this was helpful. cheers
Oct 12, 2007 | Broan-NuTone QT100L Fan
Broan-NuTone QT100L Fan Logo
849 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
