Question about Minolta bizhub 200 Copier
My bizhub 200 has message to change pc drum what does this mean?
    President:
  • Minolta Expert
  • 347 Answers
This means that imaging unit of your photocopier machine should be replaced.its life is over now.
Posted on Oct 07, 2010
Monolta izhub 362 hwo to reset drum counter
Bh 362 is the upgrade of Bh 200, 250 and 350 and on that model you need change drum and developer together. The drum counter message can be reset in service mode by a qualified tech after replacing those parts.
Aug 23, 2014 | Konica Minolta Bizhub 362 Copier
How to reset drum counter on bizhub 200
Utility counter, details stop00 stop01. Counters. Has the drum been replaced? if not you reset the counter the machine will assume that a new drum is install and select the proper voltages for a new drum since the drum is not new? it might code and get poor image quality issues. Replace the developer with the drum. Machine uses the counters to determine setting in the machine, developer also has a counter. Does the front panel say replace PC drum? If so replace developer and drum and cleaning blade at the same time. You clear counters before pulling out the image unit. and you don't exit all the way out of service mode after clearing the counters you hit exit once the turn off main power, Rear left side. Once new drum and developer installed. RUN F8. Do not allow copies Prints or fax until F8 is run. Or start all over again.
Jan 03, 2014 | Minolta bizhub 200 All-In-One Printer
CLEAR DRUM UNIT COUNTER IN BIZHUB 200
Service mode, but if you clear the counter without replacing the drum image problems and code can appear on the machine. Machine bases certain voltages on certain assy's. for example drum and developer based on what the counter says because that is the only way the copier knows it got a new drum and or developer..
Sep 28, 2012 | Minolta bizhub 200 All-In-One Printer
Bizhub konica minolta 200 error code c2557
Does the control panel say replace PC drum? You need to have the Drum/Developer and the Developing unit replaced. Make sure that the counters are cleared before removing the old unit and make sure F8 is run after the new image unit is installed
Apr 23, 2012 | Minolta bizhub 200 All-In-One Printer
How do I change the PC Drum on a Bizhub 200?
Recommended that allow only KonicaMinolta tech do it, you must replace the developer, drum cleaning blade, Developing unit and run the required F8. AND THE COUNTERS MUST BE CLEARED FIRST BEFORE REMOVING OLD UNIT.
Oct 21, 2011 | Minolta bizhub 200 All-In-One Printer
Change PC Drum on Bizhub 200
AS your pervious question follow that
I have a message, please change the pc drum. how i can fix it?
This message means the pc drum life is over. You should call service center to replace the drum and reset the message (if you are not a technician).
Oct 05, 2011 | Konica Minolta Bizhub 362 Copier
I have a message that says "Change PC Drum". What is that?
This is telling you to replace the "DRUM" of the printer. This is different from the "TONER". Normally, the drum is attached to the toner cartridge. Check your printer documentation. You may be able to purchase a drum/toner kit. Drums last longer than Toner cartridges so you will replace the Toner cartridge more often than the Drum.
Jul 28, 2009 | Minolta bizhub 200 All-In-One Printer
Bizhub 200 blank pages no error messages
problem in hv unit ( ch corona ) in drum unit replace if necessary
Jul 10, 2009 | Minolta bizhub 200 Copier
In minolta bizhub 350 pc drum change
Two Options:
1) Reset the PC/life; I/C Life and DV counter and run F8.
2) The same than before but change the PC drum.
by : George Rivas ( OSI )
Feb 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Minolta bizhub 200 Copier Logo
820 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
