Question about Nokia 7610
Keypad of my nokia 7610 is not working - Nokia 7610
SOURCE: MY NOKIA 7610 KEYPAD CONNECTORS TWO PRINT BROKEN
just use jumper between key plate and keypad connector..
Posted on Mar 16, 2009
JAN_yuanjia
  • 470 Answers
SOURCE: in keypad the numbers 4,5 and 6 are not working
there is a cut line between the board, because the 456 a the same line in the outer key, so you need to jumper it , if you dont know let the technician do it, JUMPER
Posted on Apr 03, 2009
kram26
  • 544 Answers
SOURCE: due to rain, in mobile phone nokia 7610, only text & numbers of keypad not working, as cursor is absent. But, calculator is working.
it ssems that the inside part of the moblie are wet.
you need to bring it to a service center to open it for you and let them dry.
but i advice for you now that dont use until it is still un fix to prevent any short circuit that may occur of the parts in the board.
thanks,
Posted on May 30, 2009
SOURCE: nokia mobile 7610 key pad is not work properly
key pad not working
Posted on Jul 28, 2010
caroldon
  • 17130 Answers
SOURCE: my nokia 7610 supernova's keypad
It is possible that the pad switch is faulty. Use a switch cleaning solution to wipe clean the switch. If not the main board has to be checked with a continuity test to confirm the switch. replacing the switch might require help from an equipped service center and so it is better to seek help from Nokia support.
Posted on Jul 08, 2011
Where is the keypad ic
This is where the keypad IC of nokia 7610 is located.
Good Day..
Sep 04, 2011 | Nokia 7610
Nokia 7610 keys 3,5 and * not working. pls help. thanks....
i think this is a dusting problem so open your cover & clean your keypad if problem not solve then
change your keypad or check their hardware..
Jan 23, 2011 | Nokia 7610
My nokia 7610 light on the keypad no light on the screen
how to use a jumper? my nokia 7610 has a keypad problem, it had been repaired once, but it came back.. then later after i had just checked it without doing anything on it, it happened that the light went low and there's no more display on the screen..
kindly help me :( if there is a solution for this before i'll bring it to a cellphone repair shop.. so i can have lesser expenses..
thanks in advance..
Nov 04, 2010 | Nokia 7610
The navigation keys of nokia supernova 7610 are not working.. and its memory card has also locked up itself ... plz help.....
open your phone cashing than also 4 screws under LCD.pick key pad,use( - )screw or cutter eyes.clean keypad connector use pencils erraser (it safety).also open white plastic on key pad clean it up too. its often happen.Good luck.
Apr 14, 2010 | Nokia 7610 Supernova Cell Phone
In keypad the numbers 4,5 and 6 are not working
Apr 03, 2009 | Nokia 7610
MY NOKIA 7610 KEYPAD CONNECTORS TWO PRINT BROKEN WILL YOU SOLVE THIS PROBLEM?
Mar 10, 2009 | Nokia 7610
2,5,8 Keys are not working
This problem of ur's is simply because the keypad IC of ur phone has damaged(completely gone). so U have to replace it.Thats the only solution. BUT FIRST WAIT FOR TWO DAYS. KEEP THE CELL IN DRY PLACE.THIS PROBLEM ALSO COMES BECAUSE OF MOISTURE IN SOME NOKIA MOBILES
Nov 07, 2007 | Nokia 7610
7610 keypad not working
check bubble pad then change keypad ic
Oct 23, 2007 | Nokia 7610 Handheld
My Nokia 7610 Keypad Problem
my 7610 keys 2 , 5, 8 and * are not working. kindly give me any solution.
Jan 22, 2007 | Nokia 7610 Handheld
Nokia 7610 Logo
179 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
