Question about Kenmore 24032\24036 Top Load Washer
It leaks from the bottom during the rinse cycle.
During the rinse cycle, it leaks from the bottom of the machine. I unplugged it, Looked at the back to see if the hose was connected. yes it was. i read a similar e:mail where it said check the bottle. What is the bottle. is that what the drain hose is connected to? What are the possible reasons it leaks from the bottom. please help? e:mail to elsalovessugar@earthlink.net  thanks, Elsa.
  • Kenmore Master
  • 744 Answers
This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Posted on Aug 05, 2013
  • Kenmore Master
  • 5,568 Answers
The most common reason for a leak is the pump that circulates and disposes of water.
The seals generally fail and when they start to go, they may not leak continuously.
Just remove the back panel and peer into the guts with a flashlight.
The pump is normally a semitransparent whitish plastic and will have 2, sometimes 3 hoses connected.
It is driven by belt too so it shouldn't be too hard to find.
Check around the pump for signs of deposits from detergent and possibly calcium that forms at a slow leak.
Replacing the pump is not difficult for the average home handyman.
Check your phone directory for a company called Johnstone Supply.
If you have one not too far away, it is worth ~ $20 US to buy one from them.
They are generally a supplier to tradespeople but I have never been turned away or charged other than the price quoted by phone and they are easy to deal with.
Have your model number handy or (if you can confirm the pump is leaking) go to the Sears site, go to the parts page and enter your model number. Their site is great for line-drawing illustrations that use reference numbers to find the part you need.
You could even do this first if you are unsure what the pump looks like; it will be identified in the parts list.
You can also check their price but it is often double that of Johnstone's.
Posted on May 28, 2008
Washer is leaking during rinse/spin cycle
What is the model number of your unit?
Nov 23, 2012 | Washing Machines
Washing machine leaks during spin and drain cycle
If the leak is still present after you replace the hoses , you may need to get a new water pump ( cheap part ) it is probably leaking , it removes the dirty water from the washer during spin and rinse cycle . hope this helps
Jun 28, 2012 | Washing Machines
Washing machine is leaking from the bottom of the machine and leaking after the wash cycle inside. 622797 style no. The machine leaks during the rinse cycle from the bottom.
Washing machine is leaking from the bottom This video will show you how to find the leak on your washing machine
Jun 07, 2011 | KitchenAid Washing Machines
Water leaking from bottom of machine - machine not washing well
It is important that you look underthe washer to confirm the point of leak so as to get a first hand information.If the leak is during the wash cycle it can be from fault of the celing gasket or a leak from the drum moving spindle.However if it is during the rinse cycle,the leak can be from the out let hose,drainvalve/drainpump.If so the hose can be tighten or the valve pump can be removed,repaired and reset.
Aug 31, 2010 | Samsung WF337AA Front Load Washer
Washer leaking from the bottom
make sure your drain pipe is not backing up when washer drains
Jan 10, 2010 | Washing Machines
GE washing machine leaks at bottom
If this machine has a place to put pour fabric softener in that's sits under the lid on the cabinet? If so, the hose that allows the softener drain into the tub is either leaking or is disconnected.
Please rate this solution if helpful
Aug 20, 2009 | GE Washing Machines
Washer leaks from bottom during rinse cycle
Take the cover off the back, and look up, next to where you put the soap in, when it's filling/rinsing. There is (like) a (white) plastic valve body, and look to see if water is dripping out of it. I haven't figured out a solution to that yet, other than to replace it.
Also check the boot, coming off the pump. You could have a bad/dry boot, or a loose hose clamp.
Mar 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool calypso model GVW9959K-0 leaking during rinse cycle
hi my name is joyce
Sounds like your pump is leaking. if it is leaking when you are on a spin cycle.
now if it is stuck on f1 cycle and wont drain unplug and let stay unpluged for 60 seconds and replug and see if you can restart on drain and spin cycle. let me know if I can help with any other problems.
thanks
joyce
Feb 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
60 people viewed this question
Sal De
fordexpert
Robert Rankin
