Question about Samsung DV218AEW Electric Dryer
Are there other reasons (besides a defective dryer heater) why the air in the running dryer will not heat up?
Briskeylogis... I am having the same problem and have purchased the service manual. I also purchased a few extra parts just in case, one of which is a new dryer heater. I'm in the process of replacing it now. However, from everything I have read it can also be a Thermistor, and/or Thermostat. (The sensor assembly, basically.) That will be next on my list.
Posted on Oct 20, 2010
  • rpa12 Oct 21, 2010
    briskeylogis... a follow up. There are 2 possible things that I did that fixed my dryer. My Samsung DV218AEW was not heating up. Using the service manual I took apart the dryer so I could get to the heater assembly. I replaced the heating element (costs about $38). While replacing it, I vacuumed out the heating assembly and the area under the heating assembly. Once replaced, as I was putting the dryer back together, I took the Sensor Assembly out and vacuumed it also. The door and front panel will have to be removed to properly access either the Sensor or Heating Assemblies. The dryer is now working. So, there are only 2 options:
    1. Heating element was bad
    2. Sensor assembly was blocked
    However, my dryer wasn't heating up on sensor dry or timed dry. So my guess is that the heating element was the issue. Are you having the same issue (no heat on both sensor and time dry)? If so, it's possible it's your heating element is bad.
I have a frigidaire gallery series dryer that will run on low heat setting just fine but when I set it on medium or higher it shuts off after a minute or so. ..I replaced the thermistor but it didn't help....
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Nov 04, 2014 | Dryers
My dryer isnt heating
That could be a bad element, the motor runs on 120 the heater need 240 you might have a bad breaker, the timer could be bad. A safety limit could be tripped. Lots of reasons for no heat, mostly though
it turns out to be the element but not always.
DRYER PROBLEMS AND SOLUTIONS repair page for American dryers
Dec 17, 2012 | Dryers
Dryer does not heat
Whenever I see this problem I look for reasons why the dryer stopped heating. You might think the heating element is the priority thing to check and you would be right. But their are other things to look for besides the element. I inspect the dryer inside and out for signs of lint buildup and vent blockage. If I see a lot of lint I know it might very well be a safety limit has popped. Most dryers have 2 limits mounted next to the heater element on the heater housing.A lager one is rated @250f and a smaller one is rated @300f. If that smaller limit is tripped then you will have no heat,however, the dryer will still run. If the filter housing and blower area really get a lint buildup then a melting fuse rated @350f will kill the dryer so that the thing won't catch fire. I have manuals and repair photos for most American models HERE
Jun 18, 2012 | Dryers
Not drying
Runs but will not heat
1.loose wiring--check terminals & wiring
2. Defective thermostat--replace thermostat
3.defective centrifugal switch in motor--replace switch (check linkage to motor)
4. Defective timer--replace timer
5. Open heater element---replace heater element
6. Heat switch set to off----set switch for desired heat
Sep 22, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
The timer didn't lose ant time off of it and the dryer didn't get warm at all? What is the problem do you think?
Dryer will not run
1. No power--check fuse & power supply
2. Loose wiring--check terminals & wiring
3. Door switch--make certain door closed properly to actuate switch
4. Defective motor---check motor.
5. Defective timer---replace timer
Sep 21, 2011 | Kenmore Dryers
Replaced thermostat and heating eliment still not heating up dryer runs and blows ari just not heating up.
ALWAYS UNPLUG DRYER BEFORE CHECKING
1.loose wiring---check terminals & wiring
2.defective centrifugal switch in motor---replace switch (check linkage to motor
3.defective timer---replace timer
4.open heater element---replace heater element
Jul 31, 2010 | Whirlpool Dryers
Dryer will only blow cold air
always use caution around electrical appliances
electric dryer-runs but will not heat
2.defective thermostat--replace
3.defective centrifugal switch in motor--replace switch--check linkage in motor
4.defective timer--replace
5.open heater element--replace
gas dryer
1.faulty ignition or reset valve or thermocouple
2.thermostat
Jul 31, 2010 | Samsung Dryers
Just quit drying clothes
If it does not dry them all then the element is a good guess or the thermostat.
If it dries them but not all the way check that the moisture sensor is not turned down too far.
The following should help you.
How to Repair Heating Elements A dryer sometimes won't heat or heats too slowly because of a variety of reasons. By following the guidelines below, you can inspect the heating elements on a gas or electric dryer to pinpoint the source of the problem.
Troubleshooting the Gas Heater
In a gas dryer, heat is provided by a gas heater that is controlled by an air shutter. The gas heater is generally the source of no-heat or drying problems. You can often correct such problems by adjusting the air shutter on the gas burner, which is located along the bottom of the dryer.
To adjust the shutter, take out the screws and remove the panel that covers the gas flame. Turn on the dryer so the flame is burning. If the flame has a deep blue color and you hear air whistling around the burner, the air/gas mixture is receiving too much air. If the flame has a yellow tip, the mixture is not receiving enough air. Turn the thumbscrew or loosen the two screws slightly to increase or decrease the flow of air to the burner. Keep turning until the flame is a light blue color, without any yellow, and the whistling stops.
Gas dryers use an electric ignition device rather than a pilot light to light the gas heater: An element becomes hot and glows like the filament in a lightbulb. Electric ignition systems are always sealed; you can't adjust or repair them. If an electric ignition device fails, call a professional service person for replacement.
©2006 Publications International, Ltd.
In a gas dryer, heat is provided by a gas heater, controlled by an air shutter.
Electric dryers have self-contained electric heating elements.
Servicing the Electric Heating Elements
Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with a volt-ohm-milliammeter (VOM) set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher than 20 ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
The heater may also malfunction because it's grounded. To test for this, set the VOM to the RX1 scale and remove the leads to the heater. Clip one probe of the VOM to a heater terminal and touch the other probe to the heater housing. The meter needle should jump to a fairly high reading. If the needle flicks back and forth at a low reading, the heater is probably grounded and should be replaced. Here's how to replace the heater:
Step 1: Remove the back of the dryer. If necessary, also remove the cabinet top.
Step 2: Disconnect the leads and remove the screws that hold the duct in position. Then lift the entire heater unit out of the dryer.
Step 3: Remove the screws that hold the heating element in the duct.
Step 4: Slip the new heating element into the heating duct the same way the old one came out. Be careful not to damage the resistance coils. Replace the screws that hold the heating element in the duct, reconnect the leads, and screw the unit back into position.
Servicing the Fan
The most common dryer fan problem is lint clogging the air passages through the heater and through the dryer drum. To clear a clogged air passage, remove the back service panel of the dryer and back out the screws holding the air duct in place. Then reach into the duct and remove all the lint and dirt possible. Reassemble the parts.
Also inspect the fan for a loose screw connection where the motor shaft is set on the dryer's drum. Remove the back service panel, tighten the screw, and replace the panel.
May 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Timer / heater malfunction
The heater coils or going bad. It has two wire rings that heat up. One are two has burned out.
Jan 17, 2009 | GE DCSR483EA Electric Dryer
Kenmore gas dryer 110.97566200 gas dryer is running throught the cycle but no heat.
Your Heating Elements could have problemA dryer sometimes won't heat or heats too slowly because of a variety of reasons. By following the guidelines below, you can inspect the heating elements on a gas or electric dryer to pinpoint the source of the problem.
Aug 04, 2008 | Kenmore 63942 Dryer
Samsung DV218AEW Electric Dryer Logo
354 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
