Hiya Just purchased a Belkin G MIMO Modem Router. Followed the setup instructions and all seemed good until I got to the 'configure the Router' section. I am unable to acces the inmanagement user interface using the instructions given.
  • Coelura May 28, 2008
    Unfortunately not an option for me as I'm based in the UK.
  • 65 Answers
You need to bring this to best buy and have geek squad set this up, or you can get geek squad to your house, like I did, its not as easy as you think, and peace of mind is great
Posted on May 28, 2008
My Belkin wireless G router does not seem to work any more. If I connect my router to my DSL modem, I am not able to make a connection to the internet via the router to my iMac. However, if I connect the...
So if you connect the computer directly to the modem , it works .
That means your modem is working properly. Your ISP is DSL connection. Now connect the modem to the router and the computer to the router. Open the router xet up page and change the settings of the router according to the type of connection you have.
There are 2 types of connection in DSL.
DHCP and PPPOE .
Click Here for step by step instructions
Feb 01, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
We have followed instructions but canno connect.
I usually find that the security code you setup is the most common cause of this problem.
Try setting your security as WEP and use only numbers for your code
1122334455
Sep 26, 2009 | Belkin Computers & Internet
Belkin wireless G+ MIMO ADSL2 + modem routerF5D9630
You need to find out what settings need to be changed in the router to communicate to the new modem. Etisalat should have some type of instructions on how to configure it...Does the IP address get obtained automatically or is it manually configured. Does the modem require authentication..like a password. Did they replace the modem or just upgrade the system? You may just ahve to reset the modem and router to get reconnection. Most routers use the IP address of 192.168.0.1 or 192.168.1.1 to get to the router settings control panel. Just enter one of these addresses on internet explorer and a screen should ask for a password. The default password is usually ADMIN but consult the routers manual for instructions. Once you are in the router control manual you can configure the router to work with the new system.
Sep 08, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can't get my Router to work
re-configure ur router and the modem after then go to the router page in that option is the nat or port forwarding option give there ur mac ip adress then you get it
Apr 03, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have a belkin F5D8233-4 Router and I lost the inst. cd is there any way I can install it on my desktop?
Yes... if you don't have a manual either, you can download it from Belkin:
http://www.belkin.com/support/article/?lid=en&pid=F5D8233-4&aid=8340&scid=0
After you have connected the hardware as instructed, follow the instructions for 'Alternate Setup Method'. Most of the configuration is carried out through the web based interface, accessed by typing 192.168.2.1 in a web browser. Good luck :)
Dec 03, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Set up my belkin g router
You may have to configure the belkin router depending on the type of ISP that you have.
Basically, you can do these to configure your router:
1. connect the computer to the numbered port of the router and connect the modem to the internet/WAN port.
2. turn off the modem, router and the computer for 30 seconds
3. turn on the modem first, wait for the lights to stabilize then turn on the router, wait for the lights and lastly turn on the computer.
Sep 04, 2008 | Belkin (F5D7230-4) Router (587009)
Pass word to secure the wireless
  1. Then u have to setup ur router first
  2. Turn off the power on your computer.
  3. Securely connect an end of an Ethernet cable to your computer, as shown.
  4. Securely connect the other end to any of the router's four LAN ports.
  5. Connect a second Ethernet cable from the router's single WAN port to the modem.
  6. Make sure the modem is connected to the jack or cable to the Internet that was set up by your ISP.
  7. Start your network in this order:
    1. Turn the modem power off.
    2. Turn the router power off.
    3. Turn the modem power back on. Wait two minutes until the lights are stable.
    4. Turn the router power back on. Wait one minute until the lights are stable.
    5. Turn the computer power back on.
  8. Open an Internet browser, and type http://192.168.0.1. If a "Configuration Assistant" appears immediately, then do not follow the rest of these instructions. Follow the Configuration Assistant instructions, instead. Once you are finished, test your Internet connection by browing online,
  9. Type admin for User Name, and password for Password. (Older routers use 1234 as the password.)
  10. Click OK. This logs you into the router.
  11. Click Setup Wizard, on the left of the router settings page and set up your router , click wireless tab and setup wireless security for your connection
  12. that would fix your problem..
Nov 20, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin G+ MIMO Modem Router
unistall AOL, clean out temp files, clear history, go to control panel, internet options, Connections tab, remove anything in the dial up and virtual private networks....should be good to go.
Let me know.
Nov 11, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
