Question about Thermador UCV36A 36" Universal Cook 'n' Vent Downdraft Kitchen Hood
How do you unlock the panel lock button on a glass top cooktop?
Hi, my mother has a Schott Ceran induction hob. It's very good but occasionally randomly locks itself and we cannot find a manual to tell us how to unlock it or locate the model number.
The reference to Schott is the maker of the ceramic glass. The label identifying which brand and model number will be located on the base of the cooktop.
If the cooktop itself randomly locks itself, it would most likely be related to the touch panel and the sensor plate that would require replacement.
The lock would be the child lock, and usually holding down the key symbols for a period of 5 secs should remove the lock.
Nov 07, 2016 | Cooktops
HOW TO UNLOCK JEN-AIR STOVE TOP MODEL# JED4536WR01
The All Off cooktop touch control turns off the downdraft exhaust
system and all surface cooking areas that are in use at the same
time.
The Lock cooktop control avoids unintended use of the surface
cooking areas. When the cooktop is locked out, the surface
cooking areas cannot be turned on by the cooktop touch
controls.
To Lock Cooktop: Touch and hold the ALL OFF/LOCK keypad
for 4 seconds. After 4 seconds, ALL OFF/LOCK will glow red,
indicating that the cooktop controls are in the lockout position.
To Unlock Cooktop: Touch and hold the ALL OFF/LOCK keypad
for 4 seconds.
Apr 24, 2011 | Microwave Ovens
How do you unlock a kenmore elite cooktop?
You can do this by:
Check the oven display to see whether the screen says "LOC." When "LOC" is displayed, the oven lock is activated and the door cannot be opened. You need to make sure it is locked so you do not mistakenly lock the door.
  • 2 Press and hold the "Stop" button on the oven control panel until "LOC" disappears from the display. Some oven models have a button marked "Oven Lock," which should be used instead of the "Stop" button.
  • Lock the oven again by pressing and holding the "Stop" or "Oven Lock" button until "LOC" appears in the display
  • Feb 03, 2011 | Kenmore Elite 44173 30 in. Electric...
    Glass top is scratched and discolored...can you replace just the glass top? Susan
    GLASS MAINTOP ASSY
    Part Number PS253905
    price around $812.92
    Replaced main glass cooking surface on cooktop
    First, shut of the breaker to the cooktop.
    Then removed two screws to release brackets holding cooktop down. Then lifted the cooktop out of the recess in the counter top and removed the screws around the outside of the glass top. Removed the old, cracked top, by unplugging from the motherboard.
    Turned the new cooktop upside down on table and placed weather stripping around the entire underside outside edge (to keep spills from going under the cooktop and cushion the cooktop from the counter top.
    Then plugged the new cooktop into the motherboard, replaced screws around outside edge, lowered the cooktop into the recess in the counter, and reinserted the two screws into the hold-down brackets.
    Turned the breaker back on.
    Note: Just need Screw drivers and 40 minutes of your time.
    Feb 03, 2011 | GE 36 in. Profile JP968 Electric Cooktop
    The stove top of my electric KitchenAid Superba is locked. How do I unlock it?
    keep your finger on the unlock button for about 10 sec.
    please rate this response, with the thumbs up selection
    Dec 19, 2010 | KitchenAid 32 in. KECC508 Electric Cooktop
    The cook top display control lock ? i need to unlock the controls
    To Unlock Cooktop: Touch and hold CONTROL LOCK for
    5 seconds.
    Jan 11, 2009 | Jenn-Air JED8430 Electric Cooktop
    Siemens glass stove top - locked mode
    you have to hold the powerbutton for a few seconds, and the children security lock should come off
    Sep 18, 2008 | Siemens 32 in. EH78754EU Electric Cooktop
    Kenmore 44083 Cooktop
    should be an unlock button.....press and hold the button until it unlocks
    Apr 05, 2008 | Kenmore 30 in.44084 / 44089 Electric...
    Kitchen Ranges Logo
    203 people viewed this question
    Top Thermador Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    butch welch
    Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
