I have a RCA HD50LPW62AYX2,5 years old. I need the cooling fan for the lamp. Part # AFBO(or 0)812LL 12 vdc 0.10A MFG.delta electronics. I can't find this on RCA parts or anywhere else. Can you please help me !!!
  • 4,889 Answers
Are you sure about the part number? It does not sound like the part number at all? Did you verify the part number by looking up the service manual?
Posted on Oct 06, 2010
Y need book for fuse box
Fuses are listed here
* = maxi fuse
1*=50A I/P fuse panel
2*=40A blower motor relay
3*= 50A 4 wheel ABS module
4*=20a Main light switch-Instrument cluster
5*=50A Ignition switch, starter relay
6*=20A Transfer case relay
7*= NOT USED
8*=20A Auto Ride Control Switch/on off switch
9*=40A Auto Ride Control relay
10*=30A PCM power relay
mini fuses
1=10A A/C relay
2=20A Aux power point
3= not used
4=15A Fog lamps-Daytime lamps
5=10A Air Bag diagnostic monitor
6=10A Powertrain Control Module (PCM)
7=30A 4WABS module
8=30A PCM relay
9=20A Fuel Pump relay and RAP module
10= 15A Horn relay
11=15A Park Lamp relay-Main Light Switch
12=30A Main light switch--Multi Function switch
13=15A Heated O2 sensors, EGR Vacuum Regulator, EVR solenoid,Camshaft position (CMP) Sensor,
Cannister Vent Solenoid, A4LD Auto Transmission
14=30A Generator-Voltage regulator
Interior fuse panel (mini fuses)
1=7.5A Power mirror switch
2=7.5A Blower motor relay,PAD module,Air Bag diagnostic monitor
3=7.5A Trailer tow connector
4=10A Left headlamp
5=10A Data link connector (DLC)
6=7.5A Air bag diagnostic monitor, Blower motor relay, Passive deactivation Module (PAD)
7=7.5A Trailer Tow connector
8=10A Right headlamp, Daytime running lamps (DRL) module, Foglight relay
9=7.5A Stop Lamp switch
10= 7.5A Speed control-amplifier assembly,Brake pressure switch, Generic electronoc Module (GEM)
Shift lock actuator, Blend door actuator, Main light switch, RABS resistor, A/C heater assembly
Flasher
11= 7.5A Instrument cluster, Main light switch, RABS resistor
12= 10A Power window relay, Washer pump relay
13= 20A Stop lamp switch, Brake pressure switch
14= 20A Rear Anti Lock Brake system (RABS) module
**10A 4WABS module**
15=7.5A Instrument cluster
16= 30A Windshield wiper Motor, Wiper Hi-lo relay, wiper run/park relay
17=7.5A Cig lighter
18=15A Drivers unlock relay-All unlock relay
19=25A PCM power diode
20=7.5A RAP module GEM module, Radio
21=15A Flasher (hazard)
22=20A Aux power socket
23=15A Turn signals
24===not used
25= 7.5A GEM module, Instrument cluster
26= 10A Battery saver relay, Electronic Shift relay, Interior lamp relay
Power window relay,Electronic shift control module, transmission control
27=15A Switch,DRL, Backup lamp switch, DTR sensor,Instrument illumination dimming control module
Dome/map lamp, GEM,electronic shift,Interior lights,Glove box lamp and switch
28=7.5A GEM module-Radio
29= 15A Radio
30=15A Park lamps, trailer Tow relay
31===not used
32=10A rear blower
33=15A Headlamps, DRL module, Instrument cluster
34=7.5A Rear integrated control panel, CD
35=10A RABS test connector
36=7.5A CD, rear integrated control panel, memory seat,
i copied this off another post hope this helps
Oct 09, 2016 | 2003 Ford Explorer
1995 Buick Century 3.1 V6, I am not getting the "switched" negative (-/0) VDC out of the ECM to turn on the cooling fans. Is this a "common" on the ECM board or is there an individual source/ supply wire I...
The cooling fan circuit receives power through fusible link F and the 10A engine/AC in line fuse. Input from the engine coolant temperature sensor is applied to the PCM which, in turn, closes the primary and pusher coolant fan relays to turn on the coolant fans.
Jun 18, 2014 | Cars & Trucks
Fuses panel described in English
Hope this helps your out. I know the diagram and locator is a bit blurry but hopefully it gets what you need.
Drivers kick panel:
Front wiper 20A - Front wiper system Cigar 15A- Cigarette lighter Audio 10A- Audio, remote control mirror Air Bag 10A -Air bag diagnostics Stop lights- 15A -Rear brake light, high mounted stop light ECU B+ 10A - Shift lock actuator, transaxle controle module, radio, engine control module Room 10A - Interior light, clock, ignition key reminder, rear cargo area light switch ABS 10A- Anti lock brake system control unit ECU IG1 10A - Transaxle control module, shift lock actuator, ABS control unit, DRL unit Meter 10A - Instrument panel, back-up switch, electronics time control module, inhibit switch Turn signal 10A- Hazard switch ,front and rear turn lights, turn indicator IGN1 20A - Ignition switch ABS 30A- ABS pump motor TNS 30A- Tail light, license plate light COOL/FAN 30A- Cooling fan Cond/Fan 20A- A/C condenser fan Starter 15A- Start signal , Fuel pump Blower 25A- Blower Motor SR/ACC 10A - Ignition switch Hazard 15A - Hazard and turn signal light D/Lock 25A- Door locks ABS 30A - Anti lock brake system control P/W RH 20A- Power window motor right hand P/W LH 20A- Power window motor left hand IGN2 25A- Ignition Switch
Engine compartment :
Head 25A- headlights IG 2 30A- Ignition switch IG coil 15A -Ignition coil, condenser,generator IC regulator, diagnostic connector. O2 down 10A- Rear O2 sensor O2 up 10A- Front O2 sensor Fuel pump 10A -Fuel pump unit Injector 10A -Fuel injector ,camshaft positioning sensor, purge solenoid valve, EVAP, IAC actuator, Mass Airflow sensor, EGR stepper motor. fuel pump relay coil, vehicle speed sensor. A/Con 10A - A/C compressor controls, cooling fan BTN 30A- Brake light , high mounted stop light. Tail light LH 10A- License plate light, tail light , rear combo light, instrument panel illumination Tail light RH 10A-License plate light, tail light , rear combo light, instrument panel illumination Head low 15A- Headlight Head Hi 15A-Headlight Horn 15A- Horn jlmacman.png jlmacman_0.png
Mar 07, 2011 | 1995 Kia Sephia
Under the dash on the drivers side are relays (4es) right next to thge fuses...I have no idea what fuse goes to what and what the relays are there is no paperwork on the vehicle and chiltons does not...
From the top left, and listing straight down, they are:
1&2: 20Amp Rear Defog
3: 15A Fuel Pump
4: 10A Engine Control
5: 15A Stop Lamp
6: 10A Tail Lamp
7: 10A Air Cond.
8: 10A Dome Light
9: 10A Electronics (Connected to battery)
10: 15A Fog Lamp
11: 10A Hazard Lights
Back to top right
12&13: 15A Blower Motor
14: 10A St. Signal (not sure what that means)
15: 10A Audio
16: 20A Wiper & Washer
17: 10A Power Mirror
18: 15A Cigarette Lighter
19: 10A Airbag (if equipped)
20: 10A Electronics (connected to ignition)
21: 10A Turn signals
22: 10A Meter
Jan 24, 2010 | 1993 Nissan Sentra 4 Door
Abs fuse
* = maxi fuse
7*= NOT USED
mini fuses
1=10A A/C relay
3= not used
7=30A 4WABS module
8=30A PCM relay
9=20A Fuel Pump2.gif relay and RAP module
10= 15A Horn relay
4=10A Left headlamp
Flasher
17=7.5A Cig lighter
23=15A Turn signals
24===not used
29= 15A Radio
31===not used
32=10A rear blower
36=7.5A CD, rear integrated control panel, memory seat, Message center Attached images fuse%20box001.jpg?imgmax=800 __________________
Oct 29, 2009 | 2003 Ford Explorer
Need an user/owner manual for a Delta Shopmaster 12'' Portable Planer Model #TP300
Heres your Manual:
http://powertool.manualsonline.com/manuals/mfg/delta/tp300.html
Oct 15, 2009 | Delta TP300 Shopmaster 12-Inch Portable...
I need a fuse box diagram for a 2003 Ford Explorer Sport
I believe that this is what you are looking for.....
Fuse and relay locations--2nd generation power distribution box Layout- I think this is a good sticky candidate--
* = maxi fuse
7*= NOT USED
mini fuses
1=10A A/C relay
3= not used
7=30A 4WABS module
8=30A PCM relay
10= 15A Horn relay
4=10A Left headlamp
Flasher
17=7.5A Cig lighter
23=15A Turn signals
24===not used
29= 15A Radio
31===not used
32=10A rear blower
Oct 10, 2009 | 2003 Ford Explorer Sport
Fuses
Hi - Fuse Box
This illustration is based on RHD
C/B-1 C/B-2
C-10
C-20
C-9 C-8 C-7 C-6 C-5 C-4 C-3 C-2 C-1
C-19 C-18 C-17 C-16 C-15 C-14 C-13 C-12 C-11
C-21 C-22 C-23 C-24
FUSE BOX
No. RHD
C-1
C-2
C-3
C-4
C-5
C-6
C-7
C-8
C-9
C-10
C-11
C-12
C-13
C-14
C-15
C-16
C-17
C-18
C-19
C-20
C-21
C-22
C-23
C-24
LHD
10A STARTER RELAY
15A SEAT HEATER
10A TURN, BACK
10A ELEC. IGN.
15A FRT WIPER AND WASHER
10A RR WIPER AND WASHER
10A H/LAMP WIPER
15A ENGINE
15A IGN. COIL (GASOLINE)
15A FUEL CUT (4JG2)
10A METER, GAUGE
10A AUDIO, MIRROR
20A CIGARETTE
10A ANTI-THEFT
15A STOP, A/T CONT.
20A TELEPHONE
10A CLOCK, ROOM
25A RR DEFOG.
20A DOOR LOCK
25A BLOWER
10A AIR CON.
10A SRS-1
10A STARTER RELAY
15A SEAT HEATER
10A TURN, BACK
10A ELEC. IGN.
10A H/LAMP WIPER
15A ENGINE
15A FUEL CUT (4JG2)
10A METER, GAUGE
10A AUDIO, MIRROR
20A CIGARETTE
10A ANTI-THEFT
15A STOP, A/T CONT.
20A TELEPHONE
10A CLOCK, ROOM
25A RR DEFOG.
20A DOOR LOCK
25A BLOWER
10A AIR CON.
10A SRS-1
FUSE
No. RHD
C/B-1
C/B-2
LHD
30A P/W, P/S, S/R 30A P/W, P/S, S/R
Thats the one in the car by your feet ,this is the engine bay one .
F-12 F-11 F-10 F-9 F-8 F-7 F-6 F-5 F-4 F-3 F-2 F-1
RELAY AND FUSE BOX
RHD
FUSE FUSIBLE LINK
MODEL
No.
FL-1
FL-2
FL-3
FL-4
FL-5
FL-6
F-1
F-2
F-3
F-4
F-5
F-6
F-7
F-8
F-9
F-10
F-11
F-12
LHD
80A MAIN
50A KEY SW
30A ECM (GASOLINE)
30A CONDENSER FAN These are the square ones
50A GLOW (4JG2)
40A ABS
10A O2 SENSOR (GASOLINE) This is F2 going from the steering wheel
15A HORN HAZARD
15A H/LAMP-LH
15A H/LAMP-RH
15A ANTI-THEFT
20A FOG
20A ABS
15A FUEL PUMP (GASOLINE)
15A TAIL
80A MAIN
50A KEY SW
30A ECM (GASOLINE)
30A CONDENSER FAN
40A ABS
15A HORN HAZARD
10A H/LAMP-LH (HI)
10A H/LAMP-RH (HI)
10A H/LAMP-LH (LOW)
10A H/LAMP-RH (LOW)
20A FOG
20A ABS
10A TAIL-LH
10A TAIL-RH
Aug 16, 2009 | 1999 Isuzu Trooper
Dont have a owners manuel so i dont know what the fuse numbers are 93 ford taurus
1996 is all I have. Look on back of cover for fuse chart.
Location
The fuse junction panel is located to the left of the steering column. To expose the fuse junction panel, remove the fuse panel cover (14A003) as outlined.
Fuse Loc. Number Fuse Amp Rating Fuse Color Circuit Protected 1 — — Not Used 2 5A Tan Instrument Illumination 3 10A Red Left Low Beam Headlamp 4 10A Red Right Low Beam Headlamp 5 5A Tan Brake/Shift Interlock Rear Window Defrost 6 15A Lt Blue Back-Up Lamps/Air Conditioning, Speed Control, TR Sensor 7 10A Red Starter Relay Power, TR Sensor 8 5A Tan Radio Mute, Power Antenna, GEM Module 9 10A Red Anti-Lock Brake System, Central Temperature Monitor 10 20A Yellow Electronic Engine Control (EEC) Relay, Ignition Coil, PATS, Radio 11 5A Tan Air Bags, Alternator Indicator Lamp 12 5A Tan Gauges, Warning Lamps, Transmission Control Switch, GEM Module, Integrated Control Panel Autolamps 13 5A Tan Air Bags, Blower Motor, Electronic Automatic Temperature Control 14 5A Tan Light-Out Module 15 10A Red Multi-Function Switch (Turn Signals) 16 — — Not Used 17 30A Lt Green Front Windshield Wipers/Washers 18 5A Tan Headlamp Switch Illumination 19 15A Lt Blue Rear Window Wiper/Washer 20 5A Tan Radio Memory, Phone, Remote Anti-Theft Personality (RAP) Module, Integrated Control Panel (ICP) 21 20A Yellow Cigar Lighter 22 5A Tan Power Rearview Mirrors, Antenna, Decklid Lamps, Autolamp 23 5A Tan Generic Electronic Module (GEM) Power, Remote Anti-Theft Personality (RAP) Module, Passive Anti-Theft System (PATS) Module 24 5A Tan Integrated Control Panel, Radio, Speedometer 25 10A Red Diagnostics (Data Link Connector) (DLC) 26 15A Lt Blue Decklid Release 27 10A Red Battery Saver System 28 15A Lt Blue Stoplamps, Speed Control 29 15A Lt Blue Multi-Function Switch (Hazard Lamps) 30 15A Lt Blue Highbeam Headlamps, Daytime Running Lamps (DRL), Instrument Cluster 31 5A Tan Tail Lamps 32 5A Tan Heated O/S Rear View Mirrors, Integrated Control Panel (ICP) 33 5A Tan Power Window and Lock Switch Illumination 34 — — Battery Saver Relay 35 — — Driver Unlock Relay 36 — — Rear Defrost Relay 37 — — Interior Lamp Relay 38 — — Driver Power Window Relay (One Touch Down) 39 — — Accessory Delay Relay
Apr 09, 2009 | 1993 Ford Taurus
Getting system error E805
E805 (The fan rotation is faulty.)
If no detail code is indicated, suspect the feeder fan (FM1) or the reversing guide cooling fan (FM9). Is the connection of these fans normal? Is the drive signal of the fan identified in the previous step about 22 VDC while the fan is rotating or about 12 VDC otherwise?
Secondly, if the fans are found right, then for sure you need to change the DC Controller.
Sep 16, 2008 | Canon Office Equipment & Supplies
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Electro Med Services...
