Question about NRS Stex 8020T Treadmill
Error code 1 keeps popping up during every work-out session. This happens sometimes after 30-40 minures or sometimes as soon as 2minutes into the brisk walk at 5.2 km speed. I have a STEX X 6 treadmill.
  • shrutirao_ar Oct 06, 2010
    hi...
    once the error code appears the machine comes to a stop. I need to re-start the machine ( which it sdoes) and resume the work-out. This happens quite a few times during the course of one's work-out.
    By the way...I don't have a Stex 8020 T treadmill. Mine is a Stex X6 model. Appreciate your help. Cheers
    President:
  • 2,777 Answers
I see, does this unit keep functioning after the error code appears?
Let me know and I can definitely help here...
Tim
Posted on Oct 06, 2010
  • Tim Grayson
    Tim Grayson Oct 06, 2010
    That's definitely no good, still researching the exact cause but I know it refers to one of the modules in the electronics malfunctioning. Definitely not good either way, it's nothing with the configuration of the device and no real easy fix. Did you buy this treadmill new or get it from someone used? Is there a shop that deals with these machines anywhere near you? You are going to need a new part for sure, just not exactly sure which one yet.
    Thanks
    Tim
I have a Kenmore HE3t washer than continues to stop during the cycle and flash the F2 error code even after cleaning out lines, hoses, trap, boot and replacing the drain pump.
It is possible that the brushes on the motor that spins the drum are worn down. The drum will start and stop when this happens. Check the brushes.
Nov 07, 2013 | Kenmore Washing Machines
When i try downloading the update it says error code 2753, what does this mean and how do i fix it?
this happened to me too.. hook the internal sofware drive to the desktop awareness then when the title screen pops up enter "code lyoko" to find the 7th dragonball
Dec 29, 2010 | M-Audio Producer USB Microphone with...
Xerox error code 08,009.43
That is a media path motor fault.
That is the paper path motor and gear assembly on the left side of the machine looking from the front.
Since it happened during a cleaning session, I would suspect that the maintenance kit may just be stuck out of position of the head maintenance clutch may be bad, Here is that part number
033E05190
Head Maintenance Clutch
Jul 02, 2010 | Xerox Phaser 8560DN Printer
Schwinn 431 Elliptical doesn't register rpm's, distance, etc.
I have this same problem and called the customer service. The problem is that the rpm sensor is not working. It could be the sensor or something else. They had me check the connections first for the wiring harness at the top and middle and then sent me parts to work on the inside where I have my problem. I am still working on mine because the magnet was installed on the wrong side of the flywheel. Hope you don't have this issue.
Jul 02, 2009 | Schwinn 430 Elliptical Trainer
A flashing cam during c2c sessions
check for proper drivers as well as application
Jun 26, 2009 | Computers & Internet
Recording stops and recorder freezes with tascam 2488mk2
this has happened to me too- with different system error codes also not referred to at all in manual !!! i don't know of solution- and have lost the current recording session by having to just turn the device off and hope for the best... i plan on contacting tascam after this project is complete since my unit is still under warranty - GOOD LUCK out there
Jun 21, 2009 | Tascam 2488 Portastudio Multitrack...
Error light comes on when keying combination code
Try new batterys ,also sometimes if too full ,you will have to hit it hard to get the stuff off the lock bars that keep them from moving .
Dec 17, 2008 | Sentry Fireproof Safe
Nikon SB-80DX doesn't work
The symptoms and sounds you describe (pop, now rattling) point to the flashtube being blown. Sorry. You can get a repair estimate, but you may find it cheaper to buy a used on on eBay or craigslist. Around $100-110 on eBay if you are patient.
Dec 10, 2008 | Nikon Speedlight SB-80DX TTL Flash
Error 33
They are making updates to the servers.
Please be patient as they are trying to get the servers up and running.
And yes, some people can still connect to the servers while others can't. This is normal during updates. Just wait for about a week and this will go away. If there's still a problem, call Activision and tell them of the problem.
Aug 08, 2008 | Activision Call of Duty 4 Modern Warfare...
Freezing or shutoff on boot, setup or minutes into operation
Try this:
Boot the system with your Windows XP installation disk. When the boot options window appears select R for recovery console. Once you have logged into the DOS session type: fixmbr and hit the enter or return key and select "y" for yes you want to do this. Type: fixboot and hit the return key again, hit "y" for yes.
May 17, 2008 | HP Pavilion ze2000 Notebook
NRS Stex 8020T Treadmill Logo
205 people viewed this question
Top NRS Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a NRS Exercise and Fitnes Expert? Answer questions, earn points and help others
