Question about Sportline 346 Niteview Pedometer
Accidently opened the whole thing instead of just a battery drawer. Every small piece fell out. How do i put this thing back together?
How o solve the scanner error 6 in hp laserjet 3055
1. remove cover from control panel
2. open all screws from top, that you can uplift scanner cover
3. check in all corners from underside for a small piece of paper4. remove piece of paper and clean glass
5. put together the whole thing
Nov 16, 2017 | HP Office Equipment & Supplies
A small srew has fallen out off of the ********, however the piece that it was screwed into still remains inside the ********. I called bowflex and they advised me to buy a whole new ******** which I...
I am not the person to give you advice on fixing your ******** yourself but I did want to give you a link where you can look at a Bowflex SelectTech diagram in case that helps you think about taking it apart or putting it together. You can zoom in to view all the different parts. (If that's not the right one here is version 2). They also have individual parts for sale which may be better than buying a whole new one.
Mar 21, 2011 | Bowflex Selecttech Dumbbells
Bought a KB classics build & load track set. The small car fell apart when I thought I was putting in the battery. Instead when I unscrewed the car, the small motor just fell apart. There are...
i have the same exact problem, tried to put the gears back together myself and couldn't figure it out. i tried to see if i could just order another car car but no luck with that either. please let me know, as well
Jan 01, 2011 | Toys
A rubber piece fellout and there is a white wire hanging out.
This just happened to me.
The waxy piece has a clear plastic bracket, if its not connected, look around your freezer. The waxy piece fits inside the bracket, and attaches to the ice maker, just in front of the ice tray.
The white wire fits inside the waxy piece. It is the thermostat that tells the ice tray when to dump the ice.
This is impossible to feel around for, so you will need to remove at least the bottom freezer compartment as well as the ledge piece from just inside the freezer door. If you are a relatively thin/small person, you can extend the top tray fully outward, and slide underneath. Looking up at the ice maker, the plastic bracket should have a little prong. This prong will attach just behind the ice maker, with the thermostat facing the ice tray.
Mar 02, 2010 | Samsung RF265AA Bottom Freezer French Door...
Dvd door keeps opening on toshiba rd-85dt
same problem i had, there is a small microswitch under the top left corner of the dvd door, the microswitch is broken, it breaks if you put stuff on top the unit and move it about, it catches the door and breaks the end of the switch, easy fix for average electronics enthusiast
Jan 23, 2010 | Toshiba RD-XS52 DVD Recorder
Ball bearings on bottom drawer assembly fell out. Can't figure out how to put it back together.
If the ball bearings fell out, you have to put them back in one half at a time. The thing that houses it is half the size of the length, so put the top one in at the left and the bottom one in at the right and then you can push them together once they're in.
Sep 14, 2009 | GE Profile PSW26P Stainless Steel Side by...
Paper shredder does not turn off. I have to open
I'm assuming that it automatically detects the presence of paper... .
By opening the drawer you're disabling it from the safety switch. (they dont want you to shred your fingers from the bottom) There is probably a small piece of paper holding the feed sensor down.
If you're confidant, unplug the unit and take apart the plastic cover. Do not remove anything inside. Look for the small switch between the blades which 'feels' the presence of paper. There is probably a small piece of paper wedged between the housing and the switch which would fool the unit into thinking it has paper that still needs to be shredded.
Carefully put your unit back together and happy shredding.
This may happen often, remember what you did!!!
Jul 30, 2009 | World Office Products Papermate PM-1550CD...
Similar problem
That would be the thread guide. You need a small allen wrench to put this whole thing back on. There is a hole in the right side,looks like a hole, it's blackish, but is for allen wrench. The curved metal piece slides up into a tiny hole from the bottom near where needle enters then slide whole thing back on machine and tighten with allen wrench.
Jun 29, 2009 | Brother XL-5340 Mechanical Sewing Machine
Sportline 346 Niteview Pedometer Logo
54 people viewed this question
Top Sportline Exercise & Fitness Experts
Ansel Alberto
Ansel Alberto
Are you a Sportline Exercise and Fitnes Expert? Answer questions, earn points and help others
