Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
I have a error message f 2 what is wrong - Whirlpool Duet 3.8 cu. ft. Front Load Washer
  • 5,911 Answers
"F02" is a Long Drain error code. This is usually an indication of an obstruction somewhere in the drainage system, or a failed drain pump. In most cases, the drain pump reservoir just needs to be cleaned out. The following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you check the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, as well, and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage these small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
NOTE: For a full explanation of all the error codes, each one of these appliances come with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided, and if you require additional assistance, please post back with your MODEL NUMBER and let me know.. I hope you find this information helpful.
NOTE: "SUD" is a suds error detect that can commonly occur in conjunction with the "F02" error. This is a result of too much air being detected in the drainage system. In most cases, correcting the drainage problem will corect BOTH error codes
Posted on Oct 07, 2010
Having trouble with king games on Facebook
https://care.king.com/en/candy-crush-saga/e-error-error-1034-ccs-error-message-something-went-wrong-after-a-saga-api-call-https-candy watch the video
Jul 16, 2016 | Apple iMac 24" Desktop
Put wrong code in radio now cant clear the error display
try hold number 2 & 5 while radio off while holding switch radio on this should go to factory settings
Aug 31, 2014 | 2003 Renault Megane
Candy Crush Saga "got this error message "[IO-Error= [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032"]]"
[IO-Error= [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032"]][CCS error message: A saga api call went wrong.]
Candy Crush Saga on Facebook Facebook
Aug 08, 2013 | King.com Facebook Apps
USB Port can preform faster error message
This is because you are plugging in a USB 2 device to a standard USB port, or a USB 3 device into a USB 2 port. The computer is just telling you that if you upgrade the hardware, the device will work faster. Its more of an information message than an error. Your device should still function fine.
Jun 28, 2012 | Dell XPS M1530 Laptop
Error message after copying 5100
This error takes place when a encoder sensor is dirty on a back side print head.
Jun 21, 2010 | Canon Pixma MP480 All-In-One InkJet...
When i install cd it says error 6 on my clarion dxz465mp
Clarion Audio error codes:
Error Codes:
Error 1 Battery inside CD Changer needs to be replaced.
Error 2 CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3 CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4 Connection problem. Reconnect the data cable.
Error 5 CD error message. Could not read correct data due to CD ROM.
Error 6 CD error message. Could not read data from disc because it is upside-down.
Error 8 Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9 Weak RF. Try alternate frequency
Even though it says error 6 is an upside down cd, it just means the disc cant be read. usualy means the laser is dirty, out of adjustment, or not working.
Aug 19, 2009 | Clarion DXZ465MP CD Player
Maytag MAF 1675 showing an 'Error 2' message
sounds like money, well it might just be money
probably money stuck in the pump
Jun 11, 2009 | Washing Machines
KONICA 7020 GIVES ERROR MESSAGE F-35-1O WHAT IS WRONG
hi
error f 35 is fixing error,try to reset on 25 mode
Jan 08, 2009 | Toshiba E-Studio 3511 Color Copier
Oracle 10g Error
You're using the wrong password.
Sep 10, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
Washing Machines Logo
23 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
