Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
My Kenmore oven won't go on. Do I need a new stove, or is the problem with the energy source? The stove-top ranges work fine. Maintenance man in my building says I should hear a "clicking sound" before the oven lights, after which I can set the desired temperature. Does this mean I have a gas or an electric range? The stove was in my condo unit when I moved in 20 years ago, so it may be worn out.
SOURCE: Kenmore Gas Range/Freestanding/ Electronic Ignition
I have an electronic ignition Kenmore Gas Range. The Model Number is 790.78573407.
Am getting the error code F93 in the oven control panel. The manual says the likely cause is "Maximum oven door lock time exceeded". When I plug the oven the "door lock light" flashes and then the "F93" error code flashes. Am not able to use the bake or broil.
Posted on Oct 14, 2007
  • 213 Answers
SOURCE: error F5 on a kenmore electric range Model 911-469-8812
f-5 stands for faulty oven control called the EOC youll have to replace the control to fix problem
Posted on Nov 21, 2007
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
localwonder
  • 6784 Answers
SOURCE: oven quit working
Hi. this is common in many old gas range ovens. There is a set of coils that are attached to the gas valve assembly. These coils , when activated and operational, open and close the main and secondary valves in this unit. They are controlled by the main ERC(clock/oven control board). I recommend checking these coils and there respective wiring harnesses. if the clips and wires are worn and corroded, simply replace the entire wire harness.
Now, if the wiring harness and wires that are connected to the coils look good and there are no signs of corrosion on the wires and connector clips, this will confirm that the coils have failed and you will need to replace them.
You can also preform an additional test with a multimeter. simply connect your multimeter or voltage meter to both terminal posts located on the coils. once your meter is connected, start the oven cycle. you should register some sort of current during this test at this time. if the current is sufficient and the coils do not initiated the valve action, this will confirm coil failure. if the meter dosen't register a current during oven operation, this will confirm ERC(control) failure. you will have to replace the Oven control board in this case.
The Most common issue in this situation will most defiantly be the coil assembly and not the control.
Please rate and god bless:)
Posted on Apr 21, 2009
  • 31 Answers
SOURCE: I have a Kenmore Elite Gas Range. #790 series.
Possibly a malfunctioning electric gas valve. The electronics may be sending the message to open that valve, however it could be stuck, clogged or, worse, the electric servo that manipulates it could be fried (no pun intended).
Do you have your exact model #? {Not serial} I can research where to troubleshoot a valve problem or an electronics issue.
Posted on Jan 05, 2010
The oven heating element won't turn off
I would thing if you called an appliance service store or retailer and gave them the make and model number of the stove they can sell you one and maybe install it if you need them to but I would thing it would be called the oven switch
Jul 24, 2012 | Kenmore 91112 / 91114 / 91117 Electric...
I have a Kenmore Range Model 911.7378710. The oven won't turn on. The top burners are working. When I turn the oven knob, there's no sound, It's an old stove and I can't find if even...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
May 24, 2011 | Kenmore Kitchen Ranges
11 yr old range/oven ; oven stopped working (clock is out and everything) : stove top is fine. Major expense ro fix ? Am I better off getting new one ?
your clock controls the oven functions. replace clock. probally a little cheaper than a new range but depends on service call fees and labor
Jun 22, 2009 | Kenmore 63792 Microwave Oven
Kenmore stove oven does not shut off
Wow, this post is going to be extremely late. Actually, I was able to get a new control unit for my Kenmore gas range from Sears Parts Dirext for $156.06. That includes shipping and tax. The burners work without it. We just cannot use the oven until the new board comes in. It's very easy to replace. Remove the panel screws on the back (just the top) and you have access to unplug the unit and remove the 4 screws holding the assembly in.
Jun 05, 2009 | Kenmore Ovens
Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
Need help
heatman101
Aug 21, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
49 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
