Question about Poulan Pro Gas BlowerVacuum ()
Both lines from carb to gas tank rotted off inside of gas tank
    Scholar:
  • 150 Answers
These lines need to be replaced. If you can do it yourself go to shop and buy about 18 inches of line, also new filter. It has been my experience that you will probably end up having to go through the carb.
Posted on Oct 06, 2010
Craftsman chain saw 358.350870 starts but will not continue to run
look for gas tank vent. if clogged it will cause a vacuum in the gas tank and not let gas flow to Carb.
Dec 17, 2012 | Garden
Poulan chain saw model #2025 - fuel lines dry rotted and disintegrated. There are 3 fuel lines: l from gas tank and 2 from primer button but only 2 fuel ports on the carb. What goes where and how?
You should have 2 to the tank, the one with filter coming from tank goes to nipple on right side of carb, the nipple on left side by primer bulb goes to primer bulb and other from primer bulb back to tank as return line, how it should work is when you push primer bulb it pulls fuel from tank through carb and back to tank on return line so watch in tank orleave one line out that you think is return line and see if gas comes out when you prime, but remember it goes through the carb first before it goes back to tank, had a pic but too big to put on site sorry, 2StrokeJim
Oct 11, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I need to know how the fuel lines are hooked up in my ryobi gas trimmer. All of the fuel lines rotted out. I took them out and I need to know the correct connection sequences (what goes where).
line runs from little filter in tank to carb.
line from carb. to primer bulb
line from primre bulb back to gas tank.
lines are 2 sizes
need to cut at angle end of lines in tank so you can get them thru holes
and grab with needle nose plyers and pull them thru.
make sure you put the little filter on end before you pull line thru and leave
enough so filter can move around the whole tank.
second line in tank is smaller and need to cut and pull it thru hole in tank to primer bulb
Jun 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
The engine will not run unless you pour gas in the carb. It ran before i charged the fuel line which was rotted off. It is 2 cycle blower vacuum and i do not have the model nomber handy
its that new fule line you put in,,,its not letting any fule down to the carb you have proved there is nothing wrong with the engine, by tipping fule into the carb,,,,
have another go at fitting the new fule line,,, rember to put on the fule filter on the end that gos inside the fule tank if its not on it the pipe will not lay in the fule tank right and wont pick up any fule out the tank,,,
i bet thats were you went wrong?
Nov 10, 2009 | Craftsman 4 Cycle Blower/Vac
Fuel lines rotted, unsure of routing new ones
Bottom of the tank one is an overflow, 2 in the top are connected to the bulb
. The bulb pumps gas from the gas tank to the bowl of the carb then back to the fueltank in a loop to prime things up, prime too much and the overflow comes out the bottom tube.
Sep 23, 2009 | McCulloch 26cc Gas Blower Mcb3208
My homelite weed eater sx-135 the fuel filter broke of the tube
The longest, and sometimes smaller in diameter, fuel line goes from the carb. to the bottom of the tank. It should rest comfortably on the bottom of the tank. The other line should go from the primer bulb to just inside the gas tank, (about an inch).
HINT: Cut the fuel lines at an angle before inserting them into the gas tank. This will allow you to get them in much easier.
If you need further assistance, just let me know.
Jim
Jun 07, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
My weed eater is leaking gas, and i dunno where from
your fuel lines are probably old & brittel they are the first thing to leak on those sometimes they leak around the tank but they are really thin lines & they get hot from engine heat & dry rot easly replace both lines from carb to tank & the leak will be gone most lines are 1/4 lines in most cases
Jun 05, 2009 | Troy Bilt Tb70ss Gas Trimmer
Which fuel lines conncets to the carburetor?
Well I finally got my saw running - it occured to me that my older chainsaw never had a primer bulb - so I bypassed it and...pull started it with the choke on till it chugged - then turned the choke off and held the gas full on - pulled the starter cord and was cutting trees - LOL
I did speak with a small engine guy - he explained that the primer is to pressurize the gas tank - so your return line from the carb goes to the suction side of the primer bulb - output to the tank - and pickup line with filter goes to the intake of the carb - FYI - hope it helps ya!!!!!!!!!!
Mar 18, 2009 | Garden
Poulan Pro Gas BlowerVacuum () Logo
204 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
