Question about Asrock K7S8XE Motherboard
The wiring basically i cant seem to get the wiring for the power switch and reset switch etc in order can you help me wth this please?
  • Anonymous Dec 15, 2008
    PC locked in power saving mode (warning on monitor screen). How I can unlock PC?
    President:
  • 2,351 Answers
Hi cloudius, do you have you're manual for this board? If not download it from this link. (Click on the link).
http://www.asrock.com/manual/K7S8XE.pdf
Go to page 14. System panel connector.
Most people get confused with wire color. If you're case connector wires have white as a common color, than the white is ground. Positive wires can be colored blue, red, and white with a strip. Ground (For a case speaker is usually black). The front panel connector description uses 9-pins. According to you're manual (Looking at page 14.) Pin 1(bottom left of two rows of pins). Is for the hard drive LED. (Up from pin 1 is pin 2). Pin 2 is the power + for the Power LED. So to hook up the Hard drive LED, Place the + wire on to pin 1 & the - ground plugs onto pin 3, (Which is to the right of pin 1). Now you have the basic pattern. Next connector. Power LED uses pin 2 + Positive & pin 4 - negative. PWRBTN#, known as power button. + positive connects to pin 6 & - negative connects to pin 8. Lastly is the RESET# switch. Connect + to pin 7 & - to pin 9 also shown as
Dummy. That’s it.
Good Luck cloudius!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
Posted on May 28, 2008
    Genius:
  • 1,027 Answers
89 f150 changed key switch,ignition switch,starter solenoid no power anywhere now
Do you know anything about automotive electrical ? How to follow a wiring diagram ? Basic electrical testing ? Using a DVOM - digital volt ohm meter etc.... You could go to http://bbbind.com/free_tsb.html free wiring diagrams ! Enter your vehicle info ,year ,make , model an engine size . Then under system click on electrical distribution ,then under subsystem click on power distribution . It will show 2 diagrams found . Click on the search button an two blue links will pop up .Click on the first one scroll down to last diagram . This is a diagram of ignition switch an power feeds ! Check the two yellow wires for B+ voltage . No power there would mean one of the fusible links blew . Scroll back to the top diagram ,the fusible links are shown at the top left .They hookup at the starter solenoid > There are videos on youtube showing basic electrical testing , how to read a wiring diagram , how to use a DVOM . This is how you have to find the problem ,testing !
Aug 14, 2016 | Cars & Trucks
Am facing pblm wth my 26 inch lcd.. cant get sound output from the tv whenever i switched it onn, after several on nn offs of the power am getting sound output.. wat may the pblmm
The problem in that case is loose connection.Plss check first the wiring of the speaker then the speaker then the amplifier located at the board of your television.Try to fix wiring use soldering iron if there's a loose connection at the board..
Aug 21, 2011 | LG 26LX1D 26 in. LCD HDTV
Which color is the memory wire im tired of resetting time and audio configurations plz help
basically you have a power wire which should be wired to a switched connection and a memory wire which should be wired to a unswiched connection. look on your fuse box under the dash and connect the power wire first to a switched fuse (one that shuts off the radio when you turn off key) then look for a fuse (with same power wire )that when you turn off the key the radio stays on, this is the fuse that you connect the memory to,or you can connect the memory wire directly to the battery but you must use an inline fuse or you burn up your radio,car etc.
Jul 05, 2010 | JVC KD-G120 CD Player
The dryer 'On/Off' switch not working. Dryer does not turn on.
Sounds like the internal parts of the switch are damaged and not allowing the required circuit to be closed. There are many kinds of dryers and switches. If you can pull the switch out and observe the wiring on the back, it may be possible to "jump" the wires. Use extreme caution not to electricute yourself. Basically if it's just a push on to start dryer, all that needs to be done is the two wires in the switch to contact each other for a second. DO NOT TOUCH THE ELECTRICAL CONNECTORS. Hold the insulated wire in each hand and touch together briefly. This should start the dryer. DO NOT LEAVE THE WIRES EXPOSED. Put back onto swith being careful not to touch the metal connectors.
Feb 26, 2009 | Estate TGDS840JQ Gas Dryer
Dryer won't run
No reset switch, you can try unplugging the system for 1 minute then plugging it back in. If I where you I would check the outlet and make sure you are getting the correct volts, 115 or 220. IF you are then you need to open the top behind the knobs and make sure that the fuse is not popped if it is not then you need to replace the control board. Start from the basics and follow the power flow. So basically, wall, into dryer, transformers, fuse, etc.
Feb 11, 2009 | Kenmore 63942 Dryer
Cisoc 2950 with odd Problem
I recently had a client switch do this to me. The only way to get it working was to manually put the NIC on my laptop to 10 Mb and Half duplex. After calling Cisco and opening a TAC case, it was deemed faulty hardware.
If you have SmartNet (anyone buying Cisco should always buy SmartNet) on the switch, call TAC and open a case. It's probably faulty hardware.
Good Luck!
Feb 02, 2009 | Cisco Catalyst 2950 24x10/100 Mbps...
My motherboard vt8235 I cant figure witch order they go
i'm guessing your talking about your power LED, HDD LED, reset button etc.? Look closely on the board, there are small hints printed on it. eg... pwr, reset, spkr etc. and on the colored wires, there ought to be printed reset, power etc. just match them and plug them in. you can't do too much damage if they are wrong.
Jan 04, 2009 | Computers & Internet
Labeled Technical drawing of where the power switch, reset switch, power led, HDD led etc. connectors go on my comp
Most motherboards have near where the pins the wires go what goes where and the wires from case switches have writing on them as well give it a try
Jul 30, 2008 | Computers & Internet
Power Switch
This board I think is an OEM board built by Asus for HP computers. Also named Pegasus.
Go here to find a PDF manual for that particular board -
http://www.ctechinfo.org/manuals/pegasus_manual.pdf
On page 22, the last page, it shows you the pin-out for the connections for the front panel, ie - power button, reset, led's, etc. Hope this helps.
Oct 23, 2007 | ASUS CUV-NT (CUVNTWOTVWOV) Motherboard
Asrock K7S8XE Motherboard Logo
334 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
